I keep trying and it’s not working. I’m logged in. I have tried copying and pasting, and entering manually. I use Safari browser. Am I spacing out? Should i try Firefox?
edit: Tried Firefox. Coupon not working. I tried using the coupon both at checkout, and while looking at cart. Frustrating. I reloaded browser. I’ll try checking out as a guest and see. Does this work on all Supfire lights?
But seriously, the Meteor seems like a good opportunity for mixing. I wonder how something like this would look? (one bullet per optic, outer-most emitter first)
Nichia, WW XP-L, CW XP-L
Nichia, de-domed XP-L 1A, de-domed XP-G2 1D
Nichia, WW XP-G2, CW XP-G2
Nichia, de-domed XP-L 2A , de-domed XP-G2 1D
I think it might give a nice neutral tint with vivid color rendition and a balance of flood and … um, slightly throwy flood. Might want to mix up which optics are used too, since the 10507 produces lots of artifacts. Maybe 10511 on the de-domed optics and 10508 on the regular ones? Not sure, it’d probably take a fair amount of experimenting to figure out what works.
Well, I know it can handle 8A+ without collapsing, but it does drop some voltage and generate some heat. 3 or 4 chips is no problem. Djozz measured a 82mV drop across the spring at 6A (much less than most longer springs). That's not a ton of juice, but a spring bypass always helps.
The spring shouldn’t melt at that current, but it’s not exactly going to help either… A spring bypass reduces resistance/heat (and increases current) even if the spring isn’t in danger.
i usually use 62/36/2% tin/lead/silver solder for all my soldering vs my 60/40 and 70/30 and do that. usually have to get solder on the star and then on the ring, let cool and then quickly bridge it. i have 4 different kinds of solder and never really experimented.
and on the note of springs, i usually replace steel springs with the fasttech copper springs. on qlite drivers i solder the small end to board. if the spring is braided i dont worry about it.
