Ok, I feel like this has to have already been asked, but I did a ctrl-F for ’S2’ and went several pages back. So, is there any estimate on when you might be getting any red or blue hosts along with the shortened tubes I have a pretty large order to place and wanted to do it all in a single order. If it’s going to be a while on the S2 hosts I’ll just place the order for everything else. And, thank you.
The thermal performance is pretty good; much better than the small tube light triples. There is a lot more mass and more important, surface area to help transfer heat.
It is definitely not a thrower. The beam is smooth and creamy, but is only slightly tighter than what you get from the smaller triple optics like the 10507, so it is fairly floody but manages some distance due to sheer output. I imagine that if you polished the face of the optic to get rid of the texture it would tighten up a bit, but the point of a light like this is pure lumen output and not throw. If you want throw then you would be better off with a single XP-G2 and a reflector.
Sounds like just what I am looking for! I already have some of the Kronos X5/X6 sets which offer nice throw so I am now looking for something more like what you described. If the Lumintop Tool promotion is still live, I could throw one of those in as well as some batteries for my first Mtn Electronics order
Well, I give up! that is the second or third time I have put a light in my cart and it is gone before I check out. I guess I am just not meant to complete a Mtn Electronics order.
You asked too many questions first, should have asked later . Or, Richard should be charging more $$$
My triple does close to 4000 lumens, and throw is bout 27 kcd at about 10A at the tail, about the same as a simple stock C8. I’ts using XPL V6’s though, not XP-G2’s, so the XP-G2 version probably has better throw. I also have a XPL quad, but the quad is even more a flooder - didn’t measure the throw, but it’s much less.
