I’ve built one of your 26mm MTN MAX-HP drivers last night, 0.04 ohm sense resistor for 5 amps with 2S battery setup. I’ve tested it before fitting on my bench power supply and I’m only getting around 2-2.5 amps @ 8.4 volts. If I bring the volts down, the amps go up to around 3-3.2 amps? I’m running the optional C2 capacitor, no C_OUT capacitor - don’t have. I’m running this coilcraft conductor. All the other components are according to your 22mm driver configuration described here.
The other problem I have is the LVP. I’m seeing it kick in only around 4.0-4.5v. I’m using a value of 161 for ADC, R1 = 36k, R2 = 4.7k.
Do you maybe have any recommendations on the above?
The MTN-MAX driver you have is a bit different---it's the newer one with the gate driver. Ditch the extra input capacitors, you only want a small amount. Just use the smaller C2 if you can get away with it.
Thanks Richard. I’ve removed C1. Still only seeing 2.5 amps @ 8.4v instead of 5 amps. At least now if the volts drops, the amps does not increase. Any other recommendations Richard? Regarding the LVP that seems to be out, is my value of 161 correct?
The LVP issue and the incorrect output are related. I need to know exactly what parts you used---send me a PM and we can work through the details. The bigger boards are more temperamental, especially with the higher voltage setups.
I got an e-mail this week from someone who thought we were out of business....I am not sure why someone would think that. We have closed down for a few days several times before (we do have to take a break sometimes too!). We're not going anywhere anytime soon---except for onwards and upwards. We need more space and I need more help, so we're going to be moving to a new place, but we're not going anywhere.
Ouch, didn’t see this notice when I visit the international site, and made the purchased.
No wonder my email and order went silent until today.
My hope to get it fast, end up with long delay. sigh
We're back! Working to get through the backlog of e-mails, messages, and orders. Be patient, we're working hard to get your stuff out!
For those of you who are newsletter subscribers, your e-mail will be coming soon with the moving sale deals---for those of you who aren't, I will post the message here this time:
Mountain Electronics Moving Sale!
Dear Customers,
We ran out of space! :-) --- well...not really, but with our growing lineup we decided that we could really use some more room so that we can continue to grow and give you the best service possible.
We all know that packing and moving stinks, so we decided to offer some great deals both site-wide and on Nichia LEDs ---- it's a win-win: we get to move less stuff, and you get some great deals!
Here are the deals (coupon codes can be combined!):
3% off everything! Use coupon code: MTNMOV3
6% off Nichia LEDs. Use coupon code: NICHIA6 --- We just got in a bunch of 90+ CRI 4000K Nichia 219BT LEDs that we are offering at an unbelievable price. Get 'em while they last!
As always, we appreciate your support. We couldn't do it without you!
P.S. In case you haven't seen it yet, we are now building the brightest light bars on the planet! Check 'em out at mtnlitebar.com
These deals are good until Wednesday, February 15th, at 11:59 PM MST. No rainchecks. Promotional discounts cannot be applied to orders that were already placed prior to sending this message. Coupon codes are case sensitive and must be entered by the customer at checkout (we will not enter the code for you!).
