Not sure... I know that the package has shipped but the tracking hasn't updated yet, probably sometime next week.
On another note... I am up here near midnight and I just finished another crazy late night project... I took an FET and mounted it directly to a qlite (105C). It is a beast! 6 amps on a 20R into a XM-L2 5B1 on Noctigon (I installed it into my S2) and it still has a good moonlight mode (when flashed with custom firmware)! This is only 0.5A below what it was doing direct drive with heavier gauge wire (I am still using 26 AWG wire!) I tried to test this setup with a 20R into 3 XM-Ls and it blew the fuse on my meter... which means that it measured well over ten amps. I bypassed it and ran it for a minute, the FET doesn't even get hot. With this setup why even bother with the East-092 driver? Better mode selection and low voltage protection. Got it working great with no added capacitor. Stripped all 7135s and bent legs of FET so that it solder directly to the factory ground pad and PWM pad. The LED - hooks directly to the FET. I need to take some pictures and post more info later but I am pretty tired... just floored at the performance of this thing, pretty crazy.
Next step is to try it with the MT-G2! How many amps you wanna guess? I guess we'll have to wait and see!
I am also going to try the XP-G2 triple... 7 or 8 amps? 2000 lumens out of a pocket light? Meltdown? Sudden death? I don't know, haven't tried to direct drive one yet but I'm guessing this will come close! Needs lots more testing to verify functionality and durability but for now it has been solid.
 No worries, it has a 10A+ capable switch already.
 No worries, it has a 10A+ capable switch already.  .  He did all the work and was kind enough to share it with all of us! The Attiny13A can only do one PWM out at a time I believe, so we would have to go to a different controller if we wanted to independently control three FETs.  However, I think that it could run three FETs, although that might not be needed.  These FETs can handle a crazy amount of current (37A continuous, 100A pulsed), I'm guessing that 1 or 2 would be sufficient to run three MT-G2s...I guess there is only one way to find out huh?  I've already got two test MT-G2s that have been subjected to a lot of abuse and been involuntarily dedomed...guess I would just need to add a third!  Hopefully within the next couple of days I will have an answer to that question.  The limitation would be that you would still only have two cells driving them, unless you throw two more cells in parallel.
