Welcome to the MTN Electronics Group Discount Thread!
Group quantity discounts, without the drama! ![]()
MTN-slDD Driver
1. Introduction
i. What is this thread all about?
This thread is where you will find the current "group discount" item from Mountain Electronics. Instead of creating a new thread for every new item, all "group discounts" will be found in this thread.
ii. What is a "group discount"?
The idea is a mix between a normal group buy, and a regular promotional sale. Essentially, once a minimum amount of interest has been shown for a product, the discounted listing will begin. In some instances, the greater the interest, the greater the discount will be.
There will not be promotional codes sent; instead, the deal will be directly available to everyone once enough interest has been shown. This saves the time and hassle of generating, sending, and managing hundreds of promotional codes.
iii. How do I place my order?
Once the promotional deal has enough interest, the link to the item will be listed here, and the listing will become active until the specified time frame has ended or until the specified quantity limit has been reached (item sold out).
2. Current Deal
i. Current Deal: MTN-slDD Driver
Do you want to hop up your AAA light or fit a driver into a tiny space? Look no further! This driver offers all of the performance of the big FET drivers, but in a very small size.
The driver is approximately 12mm in diameter, with additional tabs on the side. The tabs can be filed off if needed, and the total driver diameter can be reduced to ~10mm without getting into any major components.
These are built and tested in the USA by Mountain Electronics using high-quality components.
For more information, please see this listing (price and some options are different from the "group discount")
ii. Options:
- PCB Thickness:
- 1.0mm - Red PCB
- 1.6mm - Purple PCB
- Firmware:
- guppydrv Rev.1
- guppydrv Rev.2
- Standard w/ Memory
- Standard No Memory
- moppydrv (E. Switch --- Tiny wire soldering skills necessary!)
- Wires:
- Installed
- Not Installed
iii. Pricing:
Price does not include shipping. Shipping cost varies based on weight and location. No additional discounts on group discount items.
- Base Price (std. firmware; no wires installed):
- 50+ Interest: $7.50 each
- 100+ Interest: $7.25 each
- 150+ Interest: $7.00 each
- 200+ Interest: $6.75 each
- Upgraded/Additional Items:
- Install Wires: +$0.50
- guppydrv / moppydrv FW: +$0.75
iv. Timing
The interest list is open from April 27 through May 3.
If there is enough interest, the drivers will be available to order at the group discount price from May 4 through May 11.
3. Interest List for Current Deal:
Post below in the thread with how many you are interested in. Your name will be added to the list.
- Solar - 2
- MG - 2
- ReManG - 3
- Joat -1
- Mattlward - 1
- MtnDon - 2
- Sprinkles - 1
- gangstead - 2
- muellihenry - 2
- zipelgas - 1
- djozz - 3
- Beachlogger - 1
- TNT - 3
- Sparkey762 - 3
- LSX - 2
- troisanh - 2
- Texlite - 2
- leroycp - 6
- andyman - 1
- HighCaliber - 4
- Dwantink - 2
- CS - 2
- Fritz t. Cat - 1
- OldLumens - 4
Running total: 52
