My Collection (scroll down for beam shot comparisons)
The Lineup:
2D Mag-Lite (far left) for size reference. I also own a 6C Mag-Lite. Although they both have Xenon bulbs, I don't use these "old school" flashlights anymore...
SkyRay 3800 3xT6 (Revision 2, three-mode version)
This is my collection’s current king-of-the-hill in terms of sheer light output. This light provides flawless operation, its output on high always makes me smile, and this photon cannon impresses whoever sees it in action. The SR3800 is basically a powerful floodlight that produces throw via 3xT6 brute force. I’ve owned this light since the summer 2011. The only issue I have with it is that its 2x18650 configuration is not really comfortable for belt carry.
FandyFire HD2010 (newest member of the collection)
This is my second most powerful light, but currently my farthest thrower. The T6 driven @ 2.3A and reflector measuring 52mm wide and 38mm deep work together to produce a pretty bright hotspot. While the inner corona is not as bright as the beams produced by my UltraFire MCU-C88 or TrustFire TF-R2, the overall spill area is a little larger – about the same as a typical P60 light – than these two "patrol" lights. The HD2010’s reflector is high quality; the finish on the body/head/tailcap not so much. I might upgrade this to a hard-driven U2.
UltraFire MCU-C88 (superb host modded by E1320)
Currently the prize of my collection, the C88 is my favorite “patrol” light – I’ve been carrying and using it at work for several weeks – and second best thrower. Erik modded this C88 host by adding a Cutter U2 1C emitter driven at 3.5A with an H-L-strobe mode. He also beefed up the AA battery holder. See his post: https://budgetlightforum.com/t/-/1907?page=3#comment-99865. This light provides a nice flood/throw beam that I prefer.
When I use a King Kong 26650 in this light I can screw down the tailcap 60% of the way (3 full turns compared to 5 with the AA battery holder), which leaves a 2mm gap between the body and tailcap (see above photo). Erik plans to see if he can shorten the tail cap switch, making our modded C88s "pure-blood" 1x26650 lights as opposed to makeshift ones. This will prevent the tailcap spring from being fully compressed and will reestablish the light's watertight seal.
TrustFire TF-R2 (next project on the upgrade agenda)
This is the “sleeper” in my collection. The most impressive aspect of this light is the ability to screw a P60 drop-in into the head. Right now it has an anemic T6 1.4A drop-in, but my plan is to spend $50 or so to get a “hot-rod” U2 drop-in from Vinhnguyen54, who drives them up to 4.2A (regulated). I intend to order one of these U2s soon to wake up this TF-R2 and see what it can really do. I’ll update BLF members when this upgrade is performed.
UltraFire NH-T60 (compact and bright "mini-thrower")
The UltraFire NH-T60 impresses me most by its relatively small size – it is only slightly larger than a regular P60 light – and its sleek, ergonomic form factor. Also, its fairly bright hotspot produced by a T6 @ 3A enables the NH-T60 to out throw P60 lights while retaining an overall spill area that equals the size of a comparable P60 light. The switch is a little mushy, so I plan to upgrade it in the future with the same $5 switch that comes in the UF-980L.
SkyRay S-R5 (nice host now sold as RQ-07)
This is my back up duty light. It has one of Erik’s T6 emitters driven at 3.1A with H-M-L mode. Even though it’s rated as a 1A tint it looks like a 1C in use – it has a slightly yellowish corona and a decent hotspot that throws well for a light this size. Erik's T6 drop-in performs superbly in this host, which is my personal favorite for this type of compact P60 light. Despite its appearance, it doesn't really look all that much like a mini light saber in real life.
UltraFire WF-502B (my general purpose house light)
This is my general around-the-house flashlight. It has a U2 P60 drop-in that was anemic, but the emitter was "woken up" by Erik, who added a 3.1A driver, useful H-M-L modes, and smooth reflector alignment. This U2 is cool and floody, but Erik's T6s are a little brighter.
UniqueFire UF-2100 (a pair of compact/useful lights)
These lights started life as the generic BLF group-buy versions for $15 each. As-is they performed well, but I didn’t like direct-drive on high. So off they went to Erik, who gave them a tamer 1.4A high that still provides decent light output but far less heat generation. Even better, he created a five-mode operation (with memory) consisting of 1.4A, .67A, .32A, .06A, and .002A – at the lowest “moon-low” setting you can stare at the lit emitter.
UltraFire P10 (very small 18650 "flooder" host)
This is my "flooder" flashlight that resides in a belt-mounted Nite Ize swivel holster. This is actually my most used light, which has an R5 emitter (SkyRay also sells a version of this very compact light). I converted this P10 into a flood light by removing the reflector and bezel. Then I reattached the glass lens to the pill's raised rim using silicone adhesive, and screwed the pill forward in the head. This light emits an extremely wide curtain of light.
BeamTech BT-4000 (in the mail, so not pictured)
http://www.tmart.com/BeamTech-BT4000-CREE-XMT6-18W-2700LM-5-Mode-Flashlight-Gray_p136640.html
I'm anxiously awaiting this light so I can perform field testing... I love 3xT6 output.
This is my first attempt at posting beam shots. I still haven’t found what I consider to be an “ideal” location that best captures the output of my flashlights. Nonetheless I went ahead and selected two locations – one with a maximum distance of 100 yards and the other at a 50-yard distance – to capture beam shots of the nine main flashlights in my collection.
All light testing was done on high setting only, and the digital camera – a Nikon Coolpix L19 – was set on nighttime landscape mode. All 18650 lights were powered by fully charged Panasonic 3100mAh batteries, and the MCU-C88 and FandyFire HD2010 were powered by fully charged King Kong 4000mAh 26650 batteries. All 18650 and 26650 batteries are charged using a TrustFire TR-003P4 I bought recently on DD for $12.
I’ll continue scoping out an ideal test location for future BLF beamshot captures and postings.
Control for 100-yard series of beamshots
SkyRay SR3800 (3xT6)
FandyFire HD2010 (T6 @ 2.3A - 52mm reflector)
UltraFire MCU-C88 (Cutter U2 1C 3.5A created by Erik - E1320)
TrustFire TF-R2 (generic T6 drop-in driven @ 1.4A)
UltraFire NH-T60 (T6 driven @ 3A)
SkyRay S-R5 (T6 3.1A drop-in created by Erik - E1320)
UltraFire WF-502B (U2 3.1A drop-in woken up by Erik - E1320)
UniqueFire UF2100 (5-mode T6 1.4A with .002A "moon-low" setting - created by Erik)
Ultrafire P10 (floodlight with R5 bare emitter)
Control for 50-yard series of beamshots
FandyFire HD2010 (T6 2.3A - 52mm reflector)
