There has been some thread about ideal charger recently and since these Asians have some wicked idea that 3 Amp charger is what makes us happy, I’d like to put it straight.
My idea is something between Intellicharger i4 and BC-700 aka IPC-1L,with these attributes:
- Charging/discharging current 10-700 mA
- Switch between 3,6-4,2-4,35 top voltage placed VISIBLY ON TOP of the charger with big letters and even color - green-yellow-red. You know… these sliders that hide what is not selected.
- Detachable or retractable battery holder to prevent charger electronic to heat batteries-with SHORT-LONG-SHORT-LONG slots:
- Short/narrow bay - should accommodate anything between 10280 cell and protected 14500.
- Long/wide bay - should accommodate anything between AA and 32700.
This should prevent sliders to have loose contact with small batteries and stiff loading long batteries. This arrangement should also prevent heating surrounding cells and sensors.
- 5 thermal sensors - one loose to sense ambient temperature and one at each bay. Selectable delta t 1-20 degree Celsius for Nickel cells termination. Should also include auto option to set appropriate value based on current.
- Detachable big heat-sink with discharge resistors.
Auto-Detection table
0-Li protection reset
0-1.5V Ni-XX
1.5-3 Li revive 10mA
3-3.5 Upper switch decides LIFEPO4 or Li-ion
3.5-4,2 Li-ion
Charging should start with 100mA in small slot and 350mA in big slot. Current setting should get easily changed for each slot using left and right arrow. Steps should be 10-25-50-100-200-350-500-700mA.
For lowest currents - 10-50mA, there should be voltage or timer safety cut-off included as delta t might not trigger. It should also be possible to turn off this safety feature.
- On-Off button for back-light.
- Input 12V and optional usb 5V.
Input should handle 15V for charging in car and up to 18V for solar panels.
