A new DQG tiny 26650 just showed up on BG: http://www.banggood.com/DQG-Tiny-26650-3th-7x-XP-G2-CW-2500LM-4modes-EDC-LED-Flashlight-p-1110730.html
7x XP-G2, 2,500lm, 93mm lenght! That is about 25mm longer than the cell it uses. I never bought a DQG before but this one seems to be a good start
Specs translated from Chinese taobao store:
ββββββββββββββββββββββ- Information update bar - βββββββββββββββββββββ-
(Coming soon)
This version compared to the previous version of the improvements:
- Increase the output capacity of the stall, where super-bright stall almost doubled, from three to seven amplification, still maintain the original volume.
- Re-create the structure, the more lean.
- Increase roll tail cover design.
ββββββββββββββββββββββ- Body of the dividing line - βββββββββββββββββββββ-
D.Q.G Tiny 26650 3th Flashlight
It is the worldβs most compact single section 26650 lithium-ion battery-powered 7-power LED flashlight, only 91-96 mm long, 31-38Mm in diameter. T6061 aluminum alloy surface of the body hard to do fine for car oxidation process, the first ring of stainless steel and refined side to press the switch pressure ring embellishment, modeling simple, compact. Weighing only 93 grams, and finally the 26650 Battery giant flashlight into the EDC areas, it is to carry an excellent companion.
Specially designed PMMA lens to form the desired light range
GITD lamp luminous effect
Tail stand mode
Anti-anti relieve over-discharge protection
High reliability, waterproof design
26650 Compatible Battery size: maximum diameter 26.8 mm, maximum length: 70mm (not recommended to use a protected 26650 batteries, battery size may be due to excessive and circuit current limit protection that does not work)
CREE XPG2 using high-power high-efficiency LED, life over 50,000 hours.
Advanced high efficiency constant current control circuit, has a 4-speed output brightness:
Extremely bright: 2,500 lumens (90 seconds after the turn highlighted);
Highlight: 800 lumens / 2.5 hours;
The bright: 250 lumens / 8 hours;
Low light: 8 lumens, 200 hours. (Data 5000mAh capacity battery as a reference)
Instructions:
Unscrew the end cap, a 26650 lithium battery cathode lamp mounted above specifications toward the barrel body, tighten the end cap, this time the torch is in the standby state.
In standby mode: Click the button to turn on the bright side; double-click on the highlighted; three strikes and low light; press 1s turned super bright.
After the boot: hold down the switch to perform high-low cycle, let go to keep the currently selected gear; double-click to open ultra-bright, 90 seconds after the downshift to highlight (or double-click to exit during Super bright return to the previous position); click shutdown.
Precautions:
Super bright stalls tremendous heat, being careful not to super bright continuous dimming gear.
Prohibited for children, non-irradiated others and the light source directly or animal eyes, glare can cause discomfort or even injury; rigorous brachytherapy skin, to avoid being burned or allergic reaction to light.
Use cover is placed on the desktop, super light and heat output may cause overheating of the torch and related materials and even cause a fire hazard in non-shaded lamp light parts, or torch is open.
