ACTIVE GROUPBUY MT40: [M4D deal ACTIVE] Haikelite MT40 for $ 45.99
NEWS
2019-06-19: M4DM4X arranged a groupbuy here: [M4D deal ACTIVE] Haikelite MT40 for $ 45.99
Another new Haikelite light. 4 x SST40, 4 x 18650, 8000 lumens, MSRP $69
Haikelite New MT40
Product characteristics:
The flashlight uses the highest grade Luminus SST-40-10W beads with a maximum brightness of 8000 lumens and a maximum range of 850 meters.
IPX8 waterproof. Super heat dissipation design, flashlight heating fast, cautious use, carefully ironing hands.
Four 18650 pointed or semi-pointed batteries are used to ensure the consistency of battery voltage.
(Note: If you insist on using flat-end batteries, you need to buckle down the anti-backlash patches at the cylinder body and tail to prevent the anti-backlash batteries from being released by yourself.)
High efficiency constant current circuit, constant brightness.
Luminance gear and endurance:
Low brightness: 200 lumen 30 hours
Mid-bright gear 1:1300 lumen 12 hours
Mid-bright gear 2: 2800 lumen 300 minutes
High brightness: 4500 lumen 180 minutes
Double-click Ultra-bright: 8000 lumen 140 minutes
Double-click on Ultra-bright Gear again: Flash
Hidden Bright Mode: 2 lumens (turn off, press switch for 2 seconds)
Temperature control defaults to 55 degrees Celsius. When the temperature of the flashlight reaches 55 degrees Celsius, it will automatically slow down to the middle brightness level. When the temperature is below 40 degrees Celsius, it will automatically slow up to the high brightness level.
Operating interface:
Click the button to boot; click Close.
Low-Medium Bright 1-Medium Bright 2-High Bright-Double Click Ultra Bright (Changing Gear by Long Press Switch,
Gear memory function, flashlight memory last closed gear)
Double-click on any gear can quickly enter the ultra-bright gear (click the gear before reply);
Ultra-bright gear, double-click again to enter explosive mode
In turn-off state, press the switch for 2 seconds to enter the light moonlight mode. In moonlight mode,
Flashlight locking: Quick double-click switch do not let go, can lock the flashlight, to prevent the flashlight discharge knapsack from opening by mistake.
It can also spin a little head power off protection.
Switch indicator:
100~50 power: Blue light is always on
50~9 power: blue light flickers, frequency flickers twice every 10 seconds
Less than 9% electricity: red light flashes. At the same time flashlight flash prompt, and automatically enter the ultra-low bright gear
