【New Product】XTAR AA 1.5V 3960 Li-ion Battery
You got too many batteries to tell which one still has power? We released the industry’s first battery with touch-activated power level display - XTAR AA 1.5V 3960 Battery. Simply touch the positive terminal to instantly see the power level and stay in control anytime. :blush:
This new xtar AA Li-ion battery has 2500mAh high capacity, delivers 1.5V constant voltage output and max 3A discharge current. With low battery indicator, it can provide warning that the battery needs to be recharged and prevent devices sudden shutting off. So it’s more reliable and powerful than regular NiMH and alkaline AA/AAA cells, very suitable for devices that require long-term, steady high-voltage output.
Pls check details online: XTAR AA 1.5V 3960 Battery - XTAR
Hi, please don’t upload images to the Commercial Sellers' Spot. Instead you can display the images that are already uploaded to your own website.
I have edited your post according to the method described above.
Duracell had powercheck in 1998.
【Updated】 Test of XTAR AA 1.5V 3960 Lithium battery - Capacity, Discharge & Thermal Results
Sharing a detailed review of the xtar AA 1.5V 3960 Lithium battery, which is the industry’s first rechargeable battery with touch-activated power level display. Admiral134 performed a full series of tests including capacity, discharge current, internal resistance, and thermal behavior in his video.
Some discharge tests were carried out with the HIT ASK 2.5.10.8 battery analyzer under several current loads: 0.5A, 1A, 2A, 2.5A, and 3A. At 0.5A discharge, the measured capacity was around 2415–2475 mAh, very close to the rated capacity. Even at 3A high-current discharge, the battery still delivered around 1970 mAh.
Please check more info online: https://www.youtube.com/watch?v=WIRDewAY1qM
