Just received my Black Sky Ray King from Ric along with 4 Keeppower 3400mah 18650 batteries. I took it apart to take a look at the driver and this is what I found:
It looks different than what I have seen ppl posting on here. The batteries are currently charging, but I did check the modes which are LOW, HIGH, OFF and hold for STROBE.
I will attempt to check the current draws and see how this simplified version compares to the other version going around.
Btw, the driver is held down by a threaded ring and the two red thinner wires go to the e-switch.
It’s potentially horrible… there appears to be no way for it balance the currents to each LED… and I seriously doubt that they matched the LEDs for Vf and I over the operating temperature range.
First post here, long time C*F member. Can you hold the Sky Ray King in your hand on high for extended time? Is there a way I can be sure to get the old style driver when I order? and last what brand batterys are best to use. Thanks
