Andychrist, so the lens is the same height as the SP33 reflector? I long suspected it was shorter.
Did you have any issues getting the 7mmx7mm square hole to center up on the 5mmx5mm led?
Well Jason there’s a white plastic gasket that fits around the emitter and the base of the lens’ shell meshes with that, just have to line them up. Easy-peasy.
Didn’t compare heights side by side; though initially I too was under the impression that the lens was shorter, once installed it came up to the correct height inside the lamp head so that when screwed back on over the silicone O-ring the bezel held it in place perfectly. Can’t tell you how surprised I was!
Does it come in other angles , like 45 or 60?
Well pennzy there’s also a 25 degree one on Kaidomain’s website but that’s all I could find there.
32.5MM (D) X 18MMM (H) 25-DEGREE PMMA OPTICAL LENS FOR CREE XHP70
Of course if you apply d-c-fix to the underside of the original cover glass it will spread out the beam considerably further.
https://forums.mtbr.com/lights-diy-do-yourself/diy-reflector-shields-magicshine-clones-flashlights-1125295.html#post14529051
DYAC!
That TIR is sized to fit the xhp70. The xhp50 is smaller. I was assuming it might be tricky to get it centered properly.
Yeah Jason I’d have thought the same. But the white plastic gasket has two levels of raised circles so guess it’s made to adapt to either size XHP. And the square base of emitter itself is flat and flush with the star, only its round dome is significantly three dimensional. White plastic shell encapsulating the lens comes to the same height of the reflector minus the latter’s inner ridge that helps seat the silicone O-ring, which simply sits on top of the lens’ shell without that ridge, it all fits perfectly inside the lamp head itself so no worries. (Interestingly the aluminum reflector seems to have the same size hole at its base as the naked lens.) Anyway once dropped in and rotated under pressure until it clicks into place that lens will stay centered. Still needs the cover glass though to hold it down, but that’s just one more opportunity to apply some d-c-fix.
Just as a heads up if you are interested in using 21700 cells in this SP33v3 or another compatible light the highly regarded Molicell 4200mAh P42A is the deal of the day at 18650batterystore dot com.They are being offered at $4.99 ea until Feb 4th
Does the SP33v3 take 21700 cells?
I tried a Brinyte 21700 cell and couldn’t close the cap. I was afraid I would damage the springs. Maybe that cell is extra long at 75-76mm since it is a protected cell with a built-in charger.
I checked the specifications for the SP33v3 and it states only 26650 and 18650. I thought it would also support 21700 since it seems nearly identical to the Astrolux EC01, and that one states support for 21700 or 18650 (but not 26650?). I do wonder what the differences are if any.
Takes unprotected cells only.
The Molicell I referenced is an unprotected flat top cell.
The SP33v3 user guide recommends the use of unprotected 26650 and 21700 while stating 18650 as not recommended.
The 21700 cells have a lot of wiggle room without a sleeve to hold them.
Without a device to measure lumens I observe by eye greater brightness shown on a wall in total darkness 5 feet away with my Sp33v3 and a fully charged Molicell 21700 over the SP33v3 with a with a fully charged ShockLI 26650 5500mAh.This is on the turbo setting.
As with some other lights the cell used matters.YMMV
Good point. I just confirmed this in the manual too.
I had previously done a quick check on the aliexpress listing which states: “Battery Options: One 18650 Li-ion battery or single 26650 battery” Interesting that they sell with 18650 despite not recommending it.
I think it will fit flat top 21700 just barely. I can fit 21700 cells in my v2 model, but the springs get fully compressed.
Protected 21700 is way too long. No way those will fit.
I had no problem putting the unprotected Molicell flat top 21700 in the SP33v3 and putting on the tail cap.Granted that it's a bit harder to start the threading than with a 26650.I see no dents or marks on either end of the cell after being in the light for several days.The springs recover when the 21700 is removed..
I'd like to see lumen measurements done using various high drain cells in this light.
Which ones can reach the Sofirn claimed 3500lm or exceed it?
I don't think the ShockLi 26650 5500mAh can do it but a 21700 has the potential.
What amp battery would I need to use to give the max output/light on Turbo ?
Probably any cell capable of doing 20A+ continuous. Such as:
Golisi 4300 Gold
Samsung 30T
Samsung 40T
Molicel P42A
You are drag racing someone I assume? Otherwise you don’t really need such an extreme battery.
A balance of good capacity and high current IMO would be the ShockLi 26650 5500mAh.
My discharge capacity tests show this cell in the 6000mAh range and having a 20A max continuous discharge rating.
For best turbo lumens the Golisi 26650 4300mAh and the high current 21700 from Samsung and Molicell will probably test as best turbo brightness with fully charged cellls.
The Golisi Gold 26650 may be harder to find and get shipped to many locations.
Thanks for the battery information.
Just as a side note for anyone interested,the 2 Molicell 21700 P42A I have had a discharge capacity of 4294mAH and 4291mAh.
The tests began with both cells fully charged and measuring at 4.19V.The tests ended with the cells measuring 2.62V.
Both cells are new and only fully charged twice including the charging done before the capacity testing.
Again the question of a higher capacity using a Samsung 50E 5000mAh 9.8A and Efest 5000mAh 10A vs less capacity of the Molicell P42A or Samsung 40T but with higher continuous current.
I have solved the biggest issue with the SP33v3 for me, the cursed ring of pee, with some diffusion film (#4A from DC-Fix Diffusion Film Sale for smoothest beam profile which is my preference, or #2C for more hotspot/throw).
Without that ugly corona, and with drastically reduced tint shift, this flashlight’s brightness is now useful without distractions. Really happy with the result and this flashlight!
