Hi all
There have been so many reviews on these two lights so i decided just doing beam shot comparison to see how they perform with Convoy L6 and discussion to the driver modification.
I got myself two Thorfire S70S because I love Convoy L6 so much but it seems that there are some good features on S70s which L6 lack of terms of batery indicator and shoulder strap. The light specification can be found on Amazon link Thorfire S70S
Below are sets of beam shots i have done in comparison.
Location 1 control shot (Manual camera setting and the parameters are the same for all shots)
Distance for beamshot measured 156m which is equivalent to 513 feet
Looking at the beam shots I’m guessing Thorfire S70S is about 6000k which is a bit cooler than Convoy L6 (5000K).
Thorfire S70S (upgraded version) beam shot
Convoy L6 (modified with R100) beamshot
Convoy L6 (stock light)
Beamshots combined
My Convoy L6 tint rated 5000K whereas Thorfire S70s tint is unknown and I would of guess around 6000K base on the beamshot. Thorfire S70S seems to beat stock light Convoy L6 from the beamshots comparison based area its lid up also the throw.
The warm tint is more pleasing to your eyes and it tends to saturate the tree colour abit more compare to cool tint which gives you the impression it it more lumens but it’s not ![]()
Reflector comparison. Left side is S70S and right side is L6 so theoretical S70S should throw abit more than L6
S70S base reflector is approximately 2.44cm
Whereas L6 is 2.7cm
Both have same diameter at the front
Thorfire S70S - no anti reflective coat
Convoy L6 - with anti reflective coat (purple tint)
Side by side
Standing alone
Reflector textures
S70S stacking R100 resistor on top of R080
So far I can say the new driver is excellent as it can pump turbo for 5 minutes then step down to the mode below. The temperature measured 0 to 5 minutes peak at an average of 43 degrees then it remain regulate about 50 degrees for the next 30 minutes running. I can comfortably hold the light at this temperature maybe my skin is thick and i’m not sure if other people have issues holding.
The mod S70S reached about 50 degree from 0 to 5 minutes and I noticed it’s brighter than stock light. It then step down the mode below at 5 minutes and the temperature stable around 56 degrees. I need to do more testing to see how it performs and more long distance beam shots coming soon so stay tune ![]()
I will post more beam shots at longer distance next couple of days modified L6 Vs modified S70S, some lux reading, temperature graph, current measure
Things I like Thorfire to improve:
- Anti reflective coat to the lense to get more lumens out
- More tint selection for the LEDs especially warm tint people on this forum love
- Better quality control ( i did pick up some minor issues and it’s easily fix but some consumer won’t be able to fix)
- I prefer stainless steel bezel like older version to avoid damage
- Redesign the light to make it sexy like L6
Ps im new here so be nice me ![]()
28 February 2018
Both lights with batteries LiitoKala 26650 5000mAh 20A
Temperature measuring points for both lights
Temperature reading for Thorfire S70S (stock light) on turbo mode
lovely temperature regulation at 5 minutes ![]()
Temperature reading for Convoy L6 (stock light) on turbo mode
The temperature continuing climbing up and I stopped the test to avoid damage. At 65 degrees it felt burn to my hand holding the light which is not usable at all.
This graph im comparing the hotest point (deep fin) on both lights to see how it perfom
From the result I also analysed the temperature difference on the extreme ends ( tail area vs deep fin) to see how efficient the heat transfer throughout the body and the winner to go Thorfire S70S
Link to my excel file if you want to play around the data / graph
http://s000.tinyupload.com/download.php?file_id=08197786549416313992&t=0819778654941631399291532
i will conduct other tests next few days as I’m busy with other commitments.
Also mod L6 Vs mod S70s ![]()
Stay tune for more ![]()
