The R5-A3 is 98mm long x 21mm wide which is about average for a torch that uses one 14500 battery.
18650 batteries have almost 4 times the energy capacity of 14500 batteries. And a compact 18650 torch is about 115 to 120 mm long and 24mm wide. They are not much bigger.
I like the pictures, good to see a nice pic of a light with some wear on it. Yeah if that light is using lithiums then the lenser is really going to be a bummer. Might as well have ordered a Sipik SK68.
Probably ought to show him some beam shots to make sure sees the different leds - an XML in 2100 tube size is pretty different from what he has - for close up work he’ll like it (especially with lots of modes like Erik does).
My guess is he just has crap batteries ..he says it's bright when first turned on and then goes into the dumper ..he bought it as a combo off ebay ...I love how people don't want to buy from chinese vendors like dino or dx kd or the like yet buy stuff off of ebay ..Probably from much less reputable vendors (In China)..
There isn't a thing wrong with your trustfire light ..
you just have crap batteries ..
Do you have a multimeter ? Are you charging them properly ? fully ?
Do some research (on blf) and buy some decent batteries
I personally think you will like the led lenser . The build appears to be fairly well put together.Lots of people like them ....until you know better ,then you'll probably wish you spent your dime somewhere else ..We all do it and we all have a set of trash batteries or a dumb charger from when we thought we were being extra smart to catch a deal .. Best lights to buy on Blf are the ones the whole forum is falling all over themselves to get.Spend some time just watching and reading and it will be obvious what to buy .
You may be expecting too much out of the trustfire or a 14500 battery ..In which case the led lensers output will disappoint you ...and like someone suggested an 18650 light might be more appropriate for the kind of output you're looking for.
Charger looks pretty slow (good for battery) - are you charging one battery at a time with it? Some like that need two depleted batteries in it to charge properly. How long does it take to fully charge (4v+) your 14500?
Boaz’s comments about the battery and using a meter to do some readings with it sound very valid.
If you can, what is the voltage of your suspect battery now? Is it fully depleted, or charged?
