Thanks, what tints are they supposed to be?
And what amperage are they each driven?
@JackCY: What benefit would switching bring? I mean, what you described is pretty much what AMCs do. As long as Vin > Vf, they burn off the excess voltage. Once Vin < Vf, it just goes DD.
XML triple idea is great, problem is: driver. There are so few drivers to power LEDs individually..
Both lights are Old-Lumens mini-mag mods
The Nichia 219 is a neutral white 4500k 92CRI
The XP-G2 were mistakenly sent to Old-Lumens instead of Nichia 219 by illumination supply, and the switch was not discovered until after he had already modded several lights. I think it might be a 1D tint.
Link to Nichia 918 Mini-Mag.
Link to XP-G2 Mini-Mag
I don’t know what amperage they are driven at, but if you PM Old-Lumens he could probably tell you the amperage and what drivers he used.
Yeah, I know that's what the datasheet says too. I'm talking about actual use. Just because it's rated for 1.5A max on the datasheet doesn't mean that it's best suited to be put to actual use at 1.5A all the time.
But its only up to specs CRI-wise at 1.4A and above.. so it should be made for that. ;)
The Nichia 219 is already horribly inefficient at 1.5A, a mere 60lm/W (at 600mA it is 90, at 100mA it is 125), but most people care less about efficiency than about output (I run mine at 1.4A as well ). The led does not seem to suffer from that.
The CRI is very good at all currents, it does not vary so much that you would notice I think. Example: at 800mA CRI is 90, don't think anyone will have a problem with that.
You wont notice a difference in brightness from 1.2A to 1.5A either, I was just talking about the specs.
And who cares about efficiency. I have low and medium for that. :P
XML triple idea is great, problem is: driver. There are so few drivers to power LEDs individually…
Similar yes, but not exactly. The AMC7135 drops 0.1V because it has high impedance and what it does as far as I was able to understand is limit the current. So the excess gets burned out as heat somehow, such as it increases the resistance of the switch and it heats up and limits the current throughput.
Where as using a power mosfet, it’s just switching full power on and off the battery, with ~2mOhm switch resistance there is 0.01V drop on the switch at 5A. So if the Nichia can handle 4.2V being switched over it, which should yield close to or little over 2A through it.
Maybe it could handle, maybe not, it seems simple and delivers nearly full voltage as it is nearly direct driving the LED. There is just a little resistance added by the mosfet.
Triple yes, custom driver. If the ATTiny can control 3 outputs or some other Atmel or other chip, it seems quite simple to make. In he worst case and need of full power, just use 3 Nanjg 105C each to drive one LED and program/modify them in such a way that it results in a desired color output. Some big hosts seem to have room for big drivers.
Buck-boost would be nice but I couldn’t find any on Digikey that could do over 1A, one seemed to be 4.5A but I think it can do only 1A and that 4.2A means something else in the DS. LTC3478
LT3478 - 4.5A Monolithic LED Drivers with True Color PWM Dimming
FeaturesTrue Color PWM™ Dimming Delivers Constant LED Color with Up to 3000:1 Range
Wide Input Voltage Range: 2.8V to 36V
4.5A, 60mΩ, 42V Internal Switch
Drives LEDs in Boost, Buck-Boost or Buck Modes
Integrated Resistors for Inductor and LED Current Sensing
Program LED Current:
100mA to 1050mA (LT3478-1)
(10mV to 105mV)/RSENSE (LT3478)
Program LED Current De-Rating vs Temperature
Separate Inductor Supply Input
Inrush Current Protection
Programmable Soft-Start
Fixed Frequency Operation from 200kHz to 2.25MHz
Open LED Protection (Programmable OVP)
Accurate Shutdown/UVLO Threshold with Programmable Hysteresis
16-Pin Thermally Enhanced TSSOP Package
60mOhm is heck a lot for a switch. Means 0.1V drop at 1.5A.
Still it seems it can only put 1A on the output. So the 4.5A switch there is useless. Plus effectivity at lower voltage seems to be poor.
Driver with LTC3454 is what is being built right now in one other thread, 1A only.
Bare Nichia enroute from IS, they are stock again
Can somebody share their experience of putting an XP-G or Nichia 219 into a light with an XM-L reflector?
What is the change compared to using an XP-G/Nichia 219 reflector for it?
You can also replace the input diode with a jumper and pick up a 1/10 volt on output run time, just be careful with your battery. :zipper_mouth_face: Is it just me or do all “C” tints seem greenish? I always try to get 1D or 3D instead. The 1D by itself appears very white to me and only next to a Nichia(which is yellow/magenta) does it appear bluish and the 3D is even better.
You are not alone. I want to find some 3D XM-Ls.
Cutter has them.
3C is yellowish, 1C and 2C are probably greenish. 3D should be good, but no XM-L2 is available in 3D, XP-G2 is, should have bought it maybe (along with 20mm TIR Carclo facepalm), not only the Nichia.
XM-L T6 3C is nice, will see if the XM-L2 T6 3C will be a bit less driven high in tint as it’s higher temperature binned. Could be a bit more in the red/yellow than it’s predecessor.
Still waiting for them to arrive. XM-L2 T6 3C and Nichia 219.
I have a question. Has the 3.7A @ 1.5A figure been independently verified by anyone? Or is it just a figure taken from the datasheet?
I tested one from IS and values are almost spot on as in datasheet. I measured 3,3V@0,8A / 3,5V@1A / 3,7V@1,5A
I can offer XP-G2 R5 4C VS Nichia 219 - they both have the same colour temperature (4500k)
XP-G2 R5 4C in Solarforce L2N (P60 drop-in OP textured)
Is that 4c xpg2 p60 something you built? Or prefab?
This is a great discussion. Will be following it closely.
Nichia 219 on the left XP-G2 R5 3D on the right. Wall is not white but a pastel green. Nichia is in an OL modded AA Maglite and xp-g2 is in a Solitaire mod.
