I have been looking at 2 AA type lights for a while. After sending back a Foursevens Quark pro, I decided to step up to a 18650 light. After reading a lot about this light, I decided that it might be the way to go. Well, I was wrong once…now twice.
Im not a real flashlight aficionado, so excuse my incorrect use of terms.
Ok, the good. Damn, this thing puts out a bunch of light. Moonlight mode is kind of a waste to me, but level 2 is good for most things at closer distance. Level 3 is too bright for close up work, but plenty bright for outdoor use. Level 4 is pretty amazing. I can light up my whole yard with it. I turn it on in the middle of the night and it looks like daytime. Impressive.
The UI is good. I’m not convinced that the side switch is the best method of control for me though. It has always bothered me that I have to cycle through all the modes to get the one I want. Its the same as my Fenix lights, so its annoying but not a deal breaker. Thats not limited to this light, and I knew what I was getting into. With that said, the UI does exactly what it was supposed to. The voltage indication through the side switch is pretty slick too. No need to remove a battery to check voltage, just hold the side switch, click the rear switch and release. Count the flashes.
Now the bad. I don’t buy a flashlight for gee wiz gizmos and impressive lumen numbers (although, I admit that was a factor in this purchase). I need a good beam with no “dead spots”. This light, while very bright is not brightest at the center. There seems to be 3 levels of brightness to the beam. The dimmest is the outer portion of the beam, I guess thats called the spill? Then, the brightest is a ring around the center. The center is slightly less bright than the ring. Sorry, that is unacceptable to me. If I want a dim spot in the center, ill dig out my 2D cell Maglight. It is most pronounced at longer distances, and the effect in not visible below about 3 feet. I find myself pointing the light off center so the object will be illuminated by the ring, and not the center. Very annoying. The question now is if this is a defect in a new model, or is this the way they will all be?
A bit off the subject, but I think the FL1 standard has caused as many problems as it solved. While this light blows away my Fenix L2D on paper, the Fenix wins in beam quality by a large margin. I wonder if its all about lumen count, and not so much about usability or overall quality anymore? So, I still need a light that runs on an 18650, and has a good beam with no dark spots, especially in the center. Back to Fenix? PD 35?
I’m new here, and I hope I posted in the right place. I wanted to get this info out before a bunch of people were disappointed by this light. Feel free to move my post and slap my hand….RB
