Ok, so I finally had a change to open up the light. I only disassembled the NW head and pulled the driver for modding potential. Here's some pics for anyone who gets one of these lights in the future or is thinking about it:
Contact board on the back of one head (led side). +/- wires with an 075 resistor on each lead. Anyone know what these resistors are for? Should the value be changed for a low vf Red color led? Could changing the value increase output or change something, or bad idea?
Front of head with TIR removed. The 16mm does not appear to be DTP which sucks, and as you can see, a 20mm board is just barely too big to fit but probably could be sanded. The stock board are copper though, but I tested the portion of the thermal pad sticking out from the lead and the bottom of the board and nothing, so I'm going to say non-DTP until I removed the led and make sure I'm contacting the thermal pad. The stock board is sitting on the back of a 16mm noctigon for comparison. The 20mm mtn board was closer to fitting, but no dice without sanding.
Bezel and optics. The optic really grips the footprint of the led and wont come out without prying up the sides. I like the 3000k XM-l2 side since I like warm white, but if I find a better option maybe I'll upgrade for output or CRI if possible. Why won't they make a high cri or sub 5k SST-40??? Only messing with the NW side for now.
Here's the driver where the battery tube makes contact with the head. The wires are long enough to partially pull it out for a visual. Once the retaining ring is removed (somewhat carefully, it's relatively thin aluminum), the driver can be pulled out without disconnecting the leads to the two heads by untwisting the two red wires and twisting it out. I tried different photo tints for clarity of small parts hopefully.
Anyone see potential mods to this driver or have info on it? It looks linear to me, but I have no clue about that just by looking at it. Is that two fets or mcu controllers? Sorry I'm no driver expert. Resistor modding is as crazy as I have gotten with drivers. The driver would be easy to totally remove and re-install post-mod I think just but unsoldering the red wires.
Any speculation of what the driver would do if I replaced the NW side with a red led? Either the red 5050 red from KD or an sst-20-DR if I find 3535 optics that fit.
I didn't remove the tail switch because it's glued or loctited on there and I didn't feel like freezing it, heating it up and getting the strap wrench today just to bypass the tail spring. Maybe I will in the future. I didn't see a point since it's probably just a standard e-switch.
Anyway, for what I paid it seems like a pretty decent value, other than the driver retaining ring everything else feels high-quality IMO.
Thanks for looking and please share any mod ideas. Cheers
