I wanted to say this in your build thread, but since everyone is here, will do in this one.
Never but this light blue chinese hacksaw blades. There are no decent words to describe their properties.
There are many vendors is EU that provide great EU made blades. Choose from:
-Bahco
-Zebra (Wurth subbrand)
-RUCO
For soft metals/hard woods use biggest teeth (smallest TPI - 24 or 18 if it is available).
Do not use blade that you use for brass/bronze/copper for cutting steel (specially stainless steel).
Use WD-40 or substitute for cutting aluminium.
I hate hacksaws (this strokes brings pain in my back), in past I always tried to avoid this hand cutting tools and tried to use circular saw/angle grinder/reciprocating saw/bandsaw instead. But since I have quality blades, I use it more and more. You will be satisfied when you see how fast it can cut.
I buy one from the list above for under $2 blade, this is price of four cheapest chinese blades, but brand ones last 10 times longer and work 5 times faster.
And yes, bimetall blade can not break like on photos - it is flexible because strip is made of spring steel and just tooth are hss. Such fragile blades are made from carbon steel (that was common cutting material in 19th century.)
Actually, I used that saw blade because I wanted to save the best one I have for the tough materials (brass, copper) that I need to cut sometimes.
So I put that on the frame instead because I knew that there was a risk cutting that still humid piece of wood.
The ānormalā saw blade I use is - according to the seller - Italian ( ? ), it is a bit more expensive and surely cuts well. Brand is Sadyflex.
I donāt have the possibility to have machines at home, so I had to stick to what I have, even if it was a bit more harsh in some moments!
I made it through, though
Still , thank you for the suggestion given and the observation made! I will surelly take into account on my next works/mods
Are they AR coated?
I would like some 310mm, 260mm, 620mm and 1m but they are hard to find those sizes so I have about 10 different size borosilicate 3d print bases up to 310mm ordered.
