Thank you Joe, very helpful.
Yes, Im starting to think that the 0 Volts condition that my Utorch 16340 USB Protected battery achieved from triggering Turbo at 3.9v, was caused by Thermal protection In the Battery (not the light), and not Low Voltage Protection in the Battery. (the light has no built in LVP)
Here is a discussion about currents and differences in heat production of N219b and XPL.
[QUOTE=ShineOnYouCrazyDiamond;4646979]the thermal resistance of the N219B… will be much less efficient at dissipating the heat than the XP-L so the N219B will run significantly hotter
[/quote]
I dont fully grasp the info, and have no skills in measuring the current draw of the N219b, but it seems like the N219b is capable of triggering the thermal protection in the Utorch Protected and USB rechargeable battery.
I have avoided using Turbo completely for the past 24 hours. I have not had any dimming, and no 0 Volt conditions.
IF I was to switch to unprotected IMR cells, then use of Turbo would not trigger a 0 Voltage condition in the battery. I think the light will still use its own built in Thermal protection to dim the light, as you report, after 40 seconds on a full charge, and after 3 seconds once the battery gets below 3.8v.
Your report is very helpful, especially since you let the battery cool off between Turbo heat build ups. So your report that LVP kicks in around 3.0 volts is great info, that I had not yet discovered on my own.
I really appreciate your thorough and detailed testing and reporting.
fwiw, I have no regrets having the N219b 4500k 9080 instead of the stock XPL. The Nichia has awesome Red Rendering, which is what I wanted. When I had the XPL Red things looked brown. I could still tell them apart from other colors, but the N219b makes the Red things really POP!
I have no problem with the super pink and super violet Tints of the N219b in actual use. My brain adapts pretty easily, as long as I dont do white paper comparisons with other LED lights. The same was true with the stock LED btw, its piss yellow tint is not noticeable in actual use, as long as the light is used alone, and is not being compared to other LEDs.
It is a new education for me, to realize that the N219b runs a lot hotter than the XPL. Since I did not buy the aspheric light to use on Turbo, the extra heat is not a problem, the way I use the light indoors at lower levels.
One thing I really like about the Utorch is how low the moonlight is, even in stock form it reads just 0.2 lumens on my meter. The N219b dropped it to 0.1 lumens, and Im glad. It is plenty of light when I wake in the dark to go to the bathroom, dodging cat toys and hairballs in my half sleep.
Now for some rampant speculation. I wonder if the heat generated by the N219b is inversely proportional to the reduction in Lumen output compared to the stock XPL. The N219b dropped output by almost 50%. I wonder if it is also running twice as hot. This is the largest lumen drop I have measured on any of my few converted lights. When the light went 0 Volts with the N219b, it was very warm in the hand, but not painful. When I opened the lens, it smelled a little toasty in there, but so far, no magic smoke has escaped
