My Olight S10 Baton arrived today :bigsmile:
So far i’m really impressed with this light and it’s tiny size. It looks like a miniaturized ‘big’ flashlight because of it’s design and the side switch. It’s nice to have such a small light with a button and simple UI, rather than a twisty.
The clip(as mentioned elsewhere) isn’t great. I removed it anyway as i don’t intend to use it.
Here’s the manufacturers spec’s:
High = 320 lumens (1 hour 30 minute runtime)
Medium = 70 lumens (7 hour 30 minute runtime)
Low = 5 lumens (4 day 12 hour runtime)
Moonlight = 0.5 lumens (15 day runtime)
Double click from off goes straight to strobe, and a press and hold from off goes straight to moonlight mode.
I will update this thread later with a bit more info and some more pics after i have compared it to my Trustfire Mini-01, and tried a few different 16340’s in it.
Cheers
Matt
A couple more pics for size comparison
Here’s a beamshot of the S10(left), and Mini-01(Right). Both are running a fresh AW IMR16340. There doesn’t look to be as much difference in brightness in the flesh, whereas the mini-01 looks far brighter in the pic. The difference in colour came out ok though.
Update:Here’s the results from testing a few different cells in my S10.
Ultracell 3.2v LifeP04 - 26 minutes before the light switched off - cell voltage at end was 2.4v
Aw 3.2v LifeP04 - 31 minutes before the light switched off - cell voltage at end was 2.3v
AW IMR16340 - 47 minutes before light started to flicker - cell voltage at end was 2.5v
Yezl 3.7v 16340 - 1hr 11 minutes before light started to flicker - cell voltage at end was 2.8v
Here’s a couple of pictures to show the AW IMR, and Yezl 16340’s. Notice the longer Yezl protrudes, but does NOT affect the tail cap being screwed on fully.
Update: After using the S10 for a few days now, i’m really liking it, and it’s now my new EDC. The run time using the Yezl cell is great.
For me, everything is pretty much perfect about the S10, except for one thing - The ‘Low’ mode is too low, and too close to the moonlight mode. If there wasn’t a moonlight mode, then the 5 lumen low would be good, but i think a 10 or 15 lumen low would be better, especially since medium is all the way up at 70 lumens(or possibly more on RCR).
But, High and moonlight are usually the only modes i use(with this light anyway), so it’s not a problem.
As you can see from the pics below, the reflector in the S10 is almost identical to the Mini-01, except in the S10, the reflector is narrower at its base where it meets the Led.
