Perhaps it looks better, but the second is nice too.
But my tripod-Base has a diameter of 25mm. That means the second one with 28mm space for the tripod would be better.
With this head design i totally agree with you, it looks silly.
I will have a go at it too, see if it’s otherwise doable.
I will continue to base it on the Q8 for now.
And i hope 5ar won’t mind if i use his drawings to work on.
Another thought:
IF it’s not gonna be based on the Q8, how about a wider tube with 4x 26650?
Because i feel there’s a lot of enthusiasm for a short tube.
I think a wider 4x 26650 tube would certainly help the appearance as well as weight distribution for “short-tubers”.
Edit: I do not like the stacked tubes look. I prefer one long tube instead of stacking two short tubes. But never mind me. This isn’t gonna be my light anyway.
Pretty much depending on what happens when we find a manufacture. Not a lot of point in making a light with a much smaller reflector as there are already options on the market.
The entire idea with this light is monster throw, monster size reflector, monster size light. This thing is meant to be a monster lol.
4x26650 will not be able to be held in the hand and would thus be very impractical. This is something better suited to the “box style light” talked about earlier although that i NOT what we are doing here.
You are welcome to keep working with a Q8 based design but there is really no need to do that as all the parts will be custom made for this light anyways, as such it would cost no more to change the design where necessary. So feel free to think outside the Q8 “box”.
4x 26650 cells would need ~63mm interior diameter. With a couple extra millimeters for wall thickness, it’s still small enough to fit in hand, I’m pretty sure. And it will look a lot better than a thinner tube with this huge head.
4x26650 will not fit in one hand unless you have a very large hand, and that is not good for something that weighs over 1kg and probably costs a lot of money. Too easy to drop.
Going 4x26650 would definitely require a handle.
I agree.
Although 120 mm is quite huge, i think it’s the way to go for the GT.
4x 26650 will fit in a 6.5 x 6.5 cm tube, or a 7.0 cm round tube with 4 flattened surfaces.
Yes, that’s quite large…
Could use a handle though.
But it would be nice and short, but FAT.
Okay.
This boils down to the LED choice i.m.o.
But i think most of us prefer the XPH35 (HI).
But since the XPH35 is ‘only’ 25 Watts, 4x Panasonic 3400mAh would last almost 2 times longer than 1 x 3400mAh in a 10 Watts C8.
I measured the XHP35 HI die size to be close to 2.50mm across, so ~1.56x the area of the XPL die size.
Based on my measurements it has close to 1.5x the lumens of an XPL V6 at ~6A and will throw close to the dedomed XPL V6 when driven at ~2.5A. Also DBCustom put a highly driven XHP35 HI in a Maxtoch 2x shooter and got close to the same throw as the dedomed XML U4 (driven at 4.5A) that it came with.
The XHP35 can throw farther than current bins of XPL HI. Here user Mitko put an XHP35 HI driven at only 1.5A in a convoy L2 and got 228Kcd, which is roughly what an XPL HI V2 will give.
In this beginning stages of the Q8 development, someone (I believe it was The Miller) mentioned that the design could be scaled up or down to accommodate larger or smaller cells.
Could this light become the scaled up version using 26650s?
It is unlikely to happen for several reasons. Although a quad reflector for this light is something I would like to see happen.
Converting this light to 26650’s would be a completely new light, so thus there would be no reason to stick with the current design at all if doing that. Better to start fresh and work from scratch for that goal.
For 26650’s I think the box shape proposed by Djozz would be ideal and this is a good option for a future light.
In this case having 8x 18650’s will give us more runtime, better usability and more compatibility then 4s 26650. Not to mention it would cost less then the 26650’s.
Those numbers all add up to what I have also learned in my research. It is also why I want to use the xhp35 and why I think all the other major throwers out there do as well.
Although I will say that an XHP70 @ ~6000 lumens dedomed would be interesting in a reflector this size.
Thats the idea, a big light to end all big lights. This is why the short tube doesn’t make a lot of sense to me. Will that ~60mm worth of length savings really be worth unbalancing it so much?
I am betting that running the long tube with 1 cell carrier full in the back and the other empty would feel lighter then a short tube that is horribly unbalanced.
