Then, a 13cm diameter, 4cm deep reflector will throw more than 13cm diameter, 10cm deep reflector? And have more spill at the same time? How come the Jacob A60 was such a good thrower with the deep reflector, and the was the ultimate buy? If it is not a problem, I am really interested in the logic.
That’s something you will need advanced calculations to figure out. I was considering writing a program to calculate this but currently I have a lot of work in school and wouldn’t be able to, maybe in the future.
Basically you need to take a point on the reflector, analyze the projection of the LED die onto that point based on the LED’s surface brightness, then calculate the projected image at a certain distance (like 100m or something for example) due to that point, then do this for at least a few million points on the surface of the reflector. Take the sum of all the projections at that 100m and you will end up with a spot profile and intensity at all the points on the spot.
(like this but with mathematically calculated intensity at every point)
With a program it would be easy to vary the diameter of reflector, depth of reflector, and size of the LED to find exactly where the theoretical max is achieved.
Stuff like surface quality of the reflector or efficiency losses would also need to be factored in somehow, probably at the time the calculation is made for the light hitting a point on the reflector.
I looked online and found no programs written to do this, but maybe with matlab or something it would be possible to make. Usually manufacturers just make several prototypes and pick the best performing one rather than tediously calculate a theoretical maximum which may or may not have a confound variable (aka something else that will affect the real world results that you didnt account for)
Yes that’s because the outer part is farther from the LED than the inner part is.
The inner part still focuses light forward which adds to the throw/lux and also needs to be calculated.
Also, making the LED smaller will reduce this “fuzzy” effect, but almost nobody wants an XP-G2 or even an XP-L in the GT.
I think I got the point after reading that topic. The intensity allegedly stays the same, but the form of the beam changes between corona and spill. Dr Jones has made something resembling a calculator as I see, and can help a lot.
But, Since the reflector is more or less hard to find, the choice is very limited. Bordering on irrelevant if the throw is maximized. :student:
I was looking for more advanced ray tracers, most of them are paid and really expensive meant for professional use, but there are a few free options I might try out.
And what do you mean by “hard to find” reflector? You mean how they are trying to find a source of reflector for the GT?
I was thinking more about calculating an optimized reflector and then getting it custom built by phoenix or optiforms, obviously for personal use, since it would cost more than the entire GT flashlight
And if the throw is the same, then the reflector does not matter a lot. All we need is a 12-13cm parabolic reflector. If it can be shallower then 15-20cm is not out of the question also. Anyone will do.
Yeah Jack has done a lot of translations for the Q8.
When we have a better grasp of the specs I will again ask him to translate it (post already reserved) He runs it by a Chinese staffso we know those translations are of excellent quality.
Asking to really call or email is much more work and cannot be done at a moment of hoosing or after Chinese working hours so I a hesitant to ask this.
Googling pointed me to this software on so many pages, I highly doubt they are interested in doing something, but what the heck, I just send the the following mail via their online form:
_Hi there,
Is there somebody who really likes/loves flashlights working at your company?
If so could you give me the phone number and/or email so i can get in touch?
Thanks and regards_
You should sell little cannisters of that racing fuel for all to de dedome
Very interesting what your finding will be testing it with the Thrunite light!
OP list updated and start of groups forfuture mass PM made.
It’s tough to prove that hypothesis because of how many variables that are in play. There are numerous things that could make a light throw further than another (you know that), the light having a deeper reflector could very well just be a coincidence.
Well, one thing we do know. A deeper reflector reduces spill. If this is to be a specialized ultra thrower, we should cut the spill. Let’s not mess around with this.
But what is the advantage? Is less pill for sure better? We do know that it would make the light longer, heavier, and a little more expensive to produce.
I say go for a ‘traditional’ ratio of length/diameter, something in the middle.
I wouldn't call the BOSS1 a deep reflector, fairly shallow, and it can do about the same distance as the stock TN42, but with a dedomed XPL V6, UCLp, least with tuning the focus. I hit over 700 kcd tuning it at just over 10 meters on the meter.
Well, I believe that this light is already over-the-top ridiculous. It’s already longer, heavier, and more expensive to produce. Anybody who really needs/wants extreme throw like this light promises will most likely want NO spill. The reason is that any spill light is going to negatively affect night vision, which will make it harder to see that object a mile away that you’re lighting up. If you aren’t going to optimize everything for the light down range, then why put the light down range in the first place? For me personally, I’d rather have a light that’s more usable in the mid-range, but that’s NOT what this light is. It’s a thrower. Close-range and mid-range spill WILL negatively affect the performance of this light from the POV of the end user.
