Done ![]()
Good luck with the work!
Thanks! You’re first who payed =)
Red should be possible without any problems. The AMC7135s will drop down the voltage and feed them a constant current.
I will make an order once I sort out the address I will be at in a few months time.
Is there a reason for 18+18 instead of the evenness of 20+20? Is it space needed for pcb trace routing?
yes, from out - and from +
so, 18+18 it is maximum
They will be MUCH brighter?
Do you know when these will become available?
Do you have any data to compare to the 2nd generation SOL2835?
Id assume they will be more efficient at the same current (Higher flux BIN/higher lumen per watt).
If that’s the case, Id rather wait for the 3rd gen SOL2838 to justify the emitter swap and proposed higher efficiency.
First, need to raise money at all to start this project. And after pcbs are ready, it will be very easy to solder any other LEDs there. But at this rate of raising money, I suspect that the 5th generation will come out before the boards will be ready…
My intention was to first check how many people would be interested in this idea and if we had the interest, then we would go ahead and take the steps towards making it.
If we didn’t have the interest for about 100 orders, it wouldn’t be worthwhile trying to put this into production.
Personally I think it is a bit premature to be fundraising before we really have an idea of how many people would be interested.
If I thought exactly the same, then my SunLike light bulbs would appear in 2020, but they appeared at the very beginning of 2018
s And at all. I said that 10 customers would be enough. You were talking about 50 or 100
pps. I already ordered the red ones 2835 660nm. But with flashlight some problems… Sofirn official store on aliexpress did not answered about shipping inside China and discount with it ![]()
interested
It will need 2-4 jumpers…
only 3v and 2.4A and not so much space for lines (tracks)
like here
I have sent my order and am ready to pay ![]()
I think 16+16 would be best so the brightness is more even. Wouldn’t 18+18 make the brightness less even without increasing the overall brightness by much?
Do you need jumpers? Wouldn’t something like this work where the red highlight is the (+) and the black is the Warm white Negative and the blue is the Cool White Negative work?
Order sent, asking for Paypal
I have sent my order and am ready to pay :+1:
Yes, it is possible to do like that. I will check size of the lines. I hope it will be enough, because jumpers is pain
paypal is: 50380707[d0g]qq.com
add paypal fee 5%
add mark: for Adam for BLF LT1 pcb order#
P.S.18+18 is better I think
I assume that symbol is an @ sign? 50380707@qq.com ?
What are the benefits of 18+18 other than a bit lower current per emitter and a tiny bit more efficiency?
I feel like the more even beam of 16+16 would be better, or even 20+20 if it can be fit on.
Personally I think I would prefer to sacrifice a tiny % of brightness for for even spacing.
Edit: removed email by request. Use the email above but replace the [ ] and contents inside them with a @
Sent
Edit: I did not know people went around looking for emails to spam
Sunnysunsun
Do you know about spam spiders? hide email please
I find this 2835 660nm
What is the light output and do you have the datasheet?
