This board if you look at it has only at the back 2 traces connected from holes to the springs, while the Q8 has 8 traces to the 4 holes 2 on each side
Anyone else find the spring solder to be especially hard to work with? I had to flow in a bunch of solder to get it to break loose. The stock solder was in weird lumps. Maybe it needed more heat, but didn’t want to over do it.
I'll have to take a closer look, but think I see what you are talking bout with those tail boards.
Just got a 2 LED and 4 LED board from Scott today - no time to try them, been busy with NarsilM tonight, but wow, they do look small, but looks like 0603's to me.
I'l be ordering a bunch of those bigger ones though -- thanks Lexel!
It's horrible stuff, but I've replaced 3 sets of springs so far and yes - load up the iron tip with solder, the work it around the spring bottom - and with a full load on the tip, get between the rings and get it to the center of the pad, gentle pressure to pull it off. Haven't had a problem yet, but it takes time - I take the bad solder all off with solder wick.
Nice boards!
What do you think of modifying the 4 LED board for 2 separate positive LED wire pads (each for 2 opposite LEDs)? I guess it’s only a small modification if you pull the “left” half of the LED pad with the connected traces for the “top” and “bottom” LEDs towards the “left” edge of the board. It would be possible then to control 2 different colors independently. With alternative or modified firmware, of course.
With a small separation line between the LED wire pads they can be solder brigded easily for standard operation.
(“Left”, “top”, “bottom” relating to the OSH park images.)
I don't see how fixing battery disconnect by not fixing battery disconnect is fixing the "root cause" . The cap is a nice solution though, but the light will still blink off, it just won't change modes. I assume that's visible. Very minor in comparison, but still there. I fixed mine by soldering blobbing some already long protected cells. I was thinking of stripping the protection, but enh.. maybe I'll leave it.
It’s hardly visible. And more reliable than your approach. Works with all cells.
I don’t like the idea of squeezing the cells into the light. The springs might wear out, the metal plate at the positive end of the cell may bend inside.
A combination of cap and stiff springs might be the best solution though.
Tom, I would be glad to run around the corner and drop off my Q8 to you for whatever Frankenstein testing you’d like to do, so long as in the end I get it back upgraded in some way. I will pay for whatever parts/time are required.
Interesting:
I can hear sounds from the tailcap, when I switch in strobe modes.
At least it seems to come from the tail.
I had to press my ear on the bottom.
I have a fully stock lamp. And a 1mm thick wire between tube and driver board (as scratch guard). So my springs are less compressed
Without the wire in the head it is much less noisier.
What is this?
Springs moving via current and ringing?
