Is this at the stage where one should consider getting batteries or are we looking at a Christmas time line?
Also, are button tops the recommended batteries?
Gee, I hope it won’t be Christmas! The manufacturer has been given the go ahead to produce the lights.
There has been at least one group buy for cells, but there was also some discussion that the seller might have a package deal on cells.
There has been discussion through out the 10k posts re: the best cells. Samsung 30Q comes to mind for best performance and NRC 18650GA for longest charge life in use. Yes, button tops will work, but if I remember correctly solder blobbed cells performed better. If you want more than that use the search within the thread search function at the top of the page and wade through the what is sure to be hundreds of hits. Maybe someone will remember more than I did and add to this (or correct me if I’m wrong).
Don’t forget Sony VTC6 cells. It might be a moot point because they are a bit more expensive than the 30Q deals I’ve seen, but they’ll work well in this light.
BTW, I remember people asking if these lights would be ready LAST Christmastime…
Yes, that did happen. The timeline was delivery in Nov’ in time for Christmas if I remember correctly. Things are much different now though, and the manufacturer would have a hard time justifying that sort of lag.
I had searched, and already own 18650 GA’s and 30Q flat tops. Just thought button tops would be a cleaner setup.
1st production batch is being made.
Great deal on 30Q BT's from freeme in the OP here: https://budgetlightforum.com/t/-/46324. It's publicly posted so I'd say it's fair game.
But be warned: this is a one time use coupon code!! But $17.75 for 4 30Q BT's shipped is outstanding. I ordered 2 sets of 4 with this coupon code and got the 15% off of both sets.
I believe from my battery tests, VTC5A's solder tops did the best slightly, at first, but VTC6 solder tops don't drop as quick. Again, VTC6's are just slightly better than 30Q's relatively. GA's aren't bad, better runtimes because max amps is lower and capacity is higher.
I couldn’t wait that much longer and I’ve only been following this thread since before I made an account a few months ago.
What’s the status on the production videos did they send more? I’m interested. I liked the Olight factory tour.
With a brass ring for a contact pad on the driver, the button top or solder hump is required to ensure the positive end of the cell makes good contact. I don’t think there’s a short circuit issue potential with this one, as there have been with some other’s that used this contact ring style, but the wrapper on the cell could interfere with a solid contact and cause current drop or lack of connection at all. So, button top or a slight solder bump and then it’s up to you any number of top listed cells depending on what your goal is.
+1 DB. SANYO GA flat tops work because they have a protruding + cell top, but most stock flat tops won't work. The springs have been improved (higher, stiffer) but there's been no prototype testing of them. So I'm thinking the GA flat tops should be more reliable than they were in the prototypes, but still not sure about handling a jolt, like mounted on a bike.
Yes I can’t render the video I made from the four bits of short production videos Barry send.
Also the pics won’t show on tinypic
Will check it all tomorrow morning and if needed post the short videos on my YouTube and in this thread.
So in 12-14 hours you all can see some production stuff going on
FWIW, since the solder bump can flatten over time (being soft solder) I found some small copper buttons and soldered them onto Sony VTC6 cells in a light that needed that button top. This way the copper button makes good solid contact, has excellent resistance properties, and won’t change much if at all over time. It’s not much difference as far as the cell is concerned than putting a solder blob on it. (as far as heating of the cell goes)
This is actually two of the buttons on each cell, as required by this specific light to work.
Please: Link? if possible.
I want to buy these copper buttons.
Greetings.
Pepin from the Faxera
iirc he didn’t really have a source, or it was a while ago and the source dried up. You can get thick copper wire and slice it to make copper nubs. MTN also has these, they’re tiny, but if you only need an extra little bit they should work. There are lots of homebrew buttons you could make with some conductive materials + time.
I have a couple sets of 4 Keeppower 3400 mah PROTECTED button top batteries.Will these work in the Q8 and and the GT ??? or should I buy any of the below.i would not mind a decrease in performance due to protection in battery
MJ1’s
30Q’s
GA’s
Please advise at the earliest.
I have someone in the USA coming to India. (Will order through them).
There is no shipping method for batteries and knives for India.
Thanks not cheers !!!
-DK
Ok what is the lumen output on this masterpiece?
The keeppowers probably use NCR18650B. Those should be fine for the GT (as long as the voltage drop over the springs is sorted out) but I wouldn’t use them for the Q8
I don’t know if Dale bought them or made them. I bought one of these for a previous project, With a sheet of copper, you can make as many of them as you would like at whichever size you choose. I realize that you are not in the states, but a metal hole punch should be available on you side of the pond as well.
The Q8 list (from post #1) sorted alphabetically .
(As of post #9994)
2 DOGS | 186 | |||||||||
264 | 641 | |||||||||
2Ace | 165 | 1119 | ||||||||
5ar | 697 | |||||||||
7pot | 982 | |||||||||
a12luke | 932 | |||||||||
a_idiot | 740 | |||||||||
Aardvark Spleen | 253 | 402 | 403 | |||||||
aaronchen | 1510 | 1511 | ||||||||
Abe87 | 876 | |||||||||
Abqjohnny | 51 | 1169 | ||||||||
abril | 50 | |||||||||
acml | 1455 | |||||||||
acruzangels | 1429 | |||||||||
ada_potato | 1379 | 1411 | ||||||||
adirondackdestroyer | 545 | |||||||||
adrianlights | 255 | |||||||||
adsum | 1477 | |||||||||
AEDe | 923 | |||||||||
Ag76 | 1345 | |||||||||
aggillator | 458 | |||||||||
aginthelaw | 278 | |||||||||
Agiri | 110 | |||||||||
Agro | 1488 | |||||||||
aim120 | 430 | |||||||||
AirBreaker | 155 | |||||||||
akhyar | 387 | |||||||||
akoposilester | 56 | 1111 | 1112 | |||||||
akovia | 937 | |||||||||
alberto7 | 1492 | |||||||||
albertopnp | 365 | |||||||||
Alcius | 105 | |||||||||
alejandrov | 523 | |||||||||
alex64 | 1159 | |||||||||
AlexGT | 495 | |||||||||
Alkpwn77 | 204 | |||||||||
allthumbs | 218 | |||||||||
alphazeta | 335 | |||||||||
alternety | 564 | 565 | ||||||||
Alux | 702 | |||||||||
amplificus | 904 | 983 | 984 | |||||||
Andmiller | 1064 | 1065 | ||||||||
andrewmac | 407 | |||||||||
Andybibbville | 147 | |||||||||
Andyman? | 13 | |||||||||
Angel Martínez | 128 | |||||||||
ant0 | 1195 | |||||||||
Antenne | 801 | |||||||||
Anthon | 568 | |||||||||
antilop65 | 1448 | |||||||||
antiparanoico | 32 | |||||||||
AntLion13 | 1454 | |||||||||
aors10 | 1487 | |||||||||
AppA | 1208 | |||||||||
aprendiz | 1160 | 1261 | ||||||||
apt323 | 47 | 544 | ||||||||
archi | 1157 | |||||||||
archimedes | 67 | |||||||||
arditty | 1577 | |||||||||
aremihc | 910 | |||||||||
ARMS.AARON | 1089 | |||||||||
ARsee | 1228 | 1229 | ||||||||
Arufonsi | 921 | |||||||||
aslpg | 398 | |||||||||
asnidi2 | 1327 | |||||||||
asot | 690 | |||||||||
Astromanic | 424 | |||||||||
AsylumSweep | 863 | |||||||||
atbglenn | 567 | |||||||||
Atom00 | 358 | 359 | ||||||||
Aurora | 1587 | |||||||||
Autistic | 1532 | 1533 | ||||||||
Autoclave | 1099 | |||||||||
autodidact | 1503 | |||||||||
Awdtsi | 1221 | |||||||||
Awkward Stretch | 619 | |||||||||
AwkwardPause | 464 | |||||||||
b1i1l1l1y1 | 1052 | |||||||||
B42 | 685 | 686 | 1019 | 1020 | ||||||
BackpackNY | 571 | 1084 | ||||||||
bakalakos | 202 | |||||||||
balazs1956 | 1341 | |||||||||
baldo21 | 260 | 261 | ||||||||
Bam35 | 1039 | |||||||||
bamawthu | 599 | |||||||||
banker | 1013 | |||||||||
basslovin808 | 446 | |||||||||
Bastarrdo | 117 | |||||||||
Batch1 | 293 | 344 | ||||||||
battletross | 809 | |||||||||
bawilson2 | 500 | 501 | ||||||||
Bc412 | 5 | |||||||||
bd52 | 399 | |||||||||
BDM | 1018 | |||||||||
Bdubelyew | 1542 | 1543 | ||||||||
BDWrabbit | 1244 | |||||||||
beam0 | 1424 | |||||||||
BeardedRaleigh | 662 | |||||||||
bella-headlight | 49 | 411 | 877 | |||||||
Bernard | 232 | |||||||||
Bevo | 1086 | |||||||||
bhuge00 | 1049 | |||||||||
bickle | 1463 | |||||||||
bigpix | 84 | |||||||||
bigrick | 754 | |||||||||
bikedave99 | 1174 | |||||||||
bikenber73 | 14 | |||||||||
Bill 63 | 752 | 1296 | ||||||||
Bill_tong | 896 | |||||||||
Billcheese5 | 949 | |||||||||
BingoThink | 1537 | |||||||||
bionictony | 1338 | |||||||||
bkling | 1067 | |||||||||
BlackList | 1350 | |||||||||
bladesmith3 | 607 | |||||||||
BLFD80 | 933 | |||||||||
BLightSam | 1443 | |||||||||
BlindingL5s | 312 | |||||||||
blinker | 1306 | 1353 | ||||||||
blinky | 1209 | |||||||||
blueb8llz | 70 | 553 | 1120 | 1121 | 1122 | 1123 | ||||
bluecheesbob | 1557 | |||||||||
Bluzie | 785 | |||||||||
bmaddison | 248 | |||||||||
Boaz | 391 | |||||||||
BobbyMK | 462 | |||||||||
bobdotorg | 1271 | 1272 | 1427 | 1428 | ||||||
bobofire | 1313 | |||||||||
Bogdan | 370 | 371 | ||||||||
bogdanr | 466 | |||||||||
Bohemian | 775 | |||||||||
bonfire | 412 | |||||||||
Bong lick | 763 | 1075 | ||||||||
Bonham | 262 | |||||||||
borealis | 1098 | |||||||||
BorisBar | 575 | 1238 | ||||||||
Boro | 360 | 361 | ||||||||
bossf350 | 803 | |||||||||
Box | 671 | |||||||||
boxuvrox | 1559 | |||||||||
Brettg4215 | 864 | |||||||||
brewskVT | 1449 | |||||||||
Brian Metcalfe | 318 | 319 | 374 | |||||||
brianch | 1450 | |||||||||
BrianK | 447 | 560 | 1356 | |||||||
BrianTheJay | 950 | |||||||||
Bribo | 1582 | |||||||||
brightlights | 243 | |||||||||
brittnell | 1523 | |||||||||
brjones | 504 | |||||||||
brno602 | 913 | |||||||||
brted | 249 | |||||||||
brujeria | 1578 | |||||||||
Bruno28 | 513 | |||||||||
BT100 | 1087 | 1138 | ||||||||
Bungle88 | 610 | |||||||||
Buzzy243 | 1179 | |||||||||
bwl123 | 870 | |||||||||
cabfrank | 443 | |||||||||
Caleb | 203 | 547 | ||||||||
Caleb-v | 444 | |||||||||
Calmaja | 35 | |||||||||
Candil | 1397 | 1418 | ||||||||
Cano | 661 | 1151 | ||||||||
Captainvideo | 1302 | |||||||||
caramba | 748 | |||||||||
carmantl | 345 | 346 | ||||||||
casi29061965 | 467 | 490 | 1409 | |||||||
Catul | 1441 | |||||||||
cavesprings | 1406 | |||||||||
cavorite | 1028 | |||||||||
Cawi | 1276 | |||||||||
cbrake10 | 749 | |||||||||
cccpull | 1496 | 1497 | 1498 | |||||||
cclight | 897 | |||||||||
cdjaney | 825 | |||||||||
Chadvone | 63 | 693 | ||||||||
Charga | 124 | |||||||||
charles lin | 1124 | |||||||||
CheapThrills | 469 | |||||||||
cheesecheeks | 816 | |||||||||
ChibiM | 1310 | 1321 | ||||||||
Chicken Drumstick | 131 | |||||||||
chinooker | 1260 | |||||||||
chooma | 210 | 351 | ||||||||
chrisc | 741 | 742 | ||||||||
churchilllafemme | 1230 | |||||||||
CircaM | 894 | |||||||||
Cirnyan | 1445 | |||||||||
CJ Avlis | 1459 | |||||||||
Cjlee89 | 951 | |||||||||
cjoe7 | 146 | |||||||||
CJW | 367 | |||||||||
clagged | 991 | |||||||||
clange50 | 479 | 480 | ||||||||
ClaudeMBallz | 1431 | |||||||||
clinicdoc | 1226 | |||||||||
Cliwilnew | 795 | |||||||||
cloggy | 404 | |||||||||
cmflippen | 83 | |||||||||
cnrffl1 | 577 | 1113 | ||||||||
cocoschnauzer | 363 | |||||||||
compression | 1410 | |||||||||
contigo | 1351 | |||||||||
Coolerness | 664 | |||||||||
coolriku | 517 | |||||||||
Corzy | 308 | |||||||||
Couchmaster | 245 | 551 | 552 | |||||||
cpd800t | 406 | |||||||||
CrashOne | 372 | 377 | ||||||||
Crazyeddie | 98 | 137 | 487 | |||||||
Creepo | 909 | |||||||||
cristhemuso | 388 | |||||||||
crx88ia | 683 | |||||||||
cujo255 | 1191 | |||||||||
cwb | 134 | |||||||||
cypher1024 | 973 | |||||||||
cypherz | 250 | |||||||||
Cythras | 956 | |||||||||
D10ten | 608 | |||||||||
Dadpool | 1161 | |||||||||
dafarui | 1339 | |||||||||
Dakotan2 | 1549 | 1550 | ||||||||
daninho | 468 | |||||||||
DarkerInSol | 615 | 616 | 617 | 618 | ||||||
darkpenguin | 718 | 719 | 735 | 736 | 737 | 738 | 739 | 860 | 861 | 862 |
darol | 798 | |||||||||
darrenm | 1054 | 1055 | ||||||||
darrylo | 507 | |||||||||
DarthTader | 830 | |||||||||
datiLED | 761 | |||||||||
dave101 | 1041 | |||||||||
DavidEF? | 7 | |||||||||
davidkappelt | 1026 | |||||||||
davidvns | 1128 | |||||||||
davos | 1062 | |||||||||
DB Custom | 713 | 722 | 997 | |||||||
dbesselt | 1156 | |||||||||
DBSAR | 136 | 169 | 1281 | |||||||
DBSS | 516 | 779 | ||||||||
deathless | 518 | |||||||||
Deep skull | 977 | |||||||||
DeJaVu | 669 | |||||||||
dekozn | 800 | |||||||||
Dennis | 934 | |||||||||
dentillozie | 488 | |||||||||
Dep668 | 687 | 688 | ||||||||
derfyled | 1237 | |||||||||
derpilgerer | 630 | |||||||||
Desmo | 805 | |||||||||
devdvr | 486 | |||||||||
Dewalt101 | 1552 | |||||||||
dezoe | 1186 | |||||||||
dglb99 | 1553 | |||||||||
dhsvcs | 265 | 1336 | 1337 | |||||||
dicksog | 559 | |||||||||
digitalMessiah | 1566 | |||||||||
digitaltc | 1323 | 1401 | ||||||||
Dimking | 425 | |||||||||
Dirt | 815 | |||||||||
Dirty_Pierre | 1045 | |||||||||
DiscoJoe | 1254 | |||||||||
djburkes | 188 | 878 | ||||||||
Djozz | 3 | 1115 | 1286 | |||||||
dmbaty | 1294 | |||||||||
Dobtruckers | 1058 | |||||||||
DOCFAR | 595 | |||||||||
Docp723 | 347 | 433 | 434 | |||||||
Doctawho | 440 | |||||||||
dodo | 88 | 274 | ||||||||
dogany | 813 | |||||||||
Dogsrule | 508 | |||||||||
donpachi | 1252 | |||||||||
dotBLF | 968 | |||||||||
doubleone44 | 887 | |||||||||
downlinx | 74 | 316 | ||||||||
doxerino | 1304 | |||||||||
Dr Forinor | 873 | |||||||||
Dradge | 1248 | |||||||||
Dralf | 1015 | |||||||||
Dregs | 172 | |||||||||
DrHook59 | 883 | |||||||||
driveX | 659 | |||||||||
DrJones | 75 | |||||||||
DrMcNinja17 | 1507 | 1508 | ||||||||
DT101 | 152 | |||||||||
dudunphy | 389 | |||||||||
duhduhduhdiabeetus | 1461 | |||||||||
Duke | 381 | |||||||||
dukeface13 | 1460 | |||||||||
dumptruck | 971 | |||||||||
Dusty | 327 | 328 | ||||||||
Dutcheee | 68 | 322 | ||||||||
duvallite | 889 | |||||||||
dw911 | 478 | |||||||||
Dwantink | 135 | |||||||||
e10sno | 405 | 1318 | 1319 | |||||||
Easyrr | 6 | |||||||||
eb1888 | 837 | 838 | 839 | |||||||
ebosh | 777 | |||||||||
eddamoo | 1574 | |||||||||
ediaz | 906 | |||||||||
eebowler | 774 | |||||||||
Eggun | 1104 | 1312 | ||||||||
egrep | 594 | |||||||||
Eivwer | 171 | |||||||||
electricjelly | 237 | 256 | ||||||||
ElginAgain | 1204 | 1362 | 1394 | 1395 | ||||||
emarkd | 109 | |||||||||
embee | 511 | |||||||||
Enelooper | 417 | |||||||||
engber | 947 | |||||||||
ERDOS | 1150 | |||||||||
Erethryn | 1259 | |||||||||
erikk365 | 648 | |||||||||
Esskay | 995 | |||||||||
Etex | 829 | |||||||||
etienne440 | 1516 | |||||||||
euphxenos | 408 | |||||||||
everydaysurvivalgear | 103 | |||||||||
Evilc | 65 | |||||||||
Evo1986 | 1554 | 1555 | ||||||||
ExtrabrightExtracheap | 1432 | |||||||||
Eyao | 1529 | |||||||||
EyeballFryer | 189 | |||||||||
Fadetoblack | 1295 | |||||||||
fantomR | 636 | |||||||||
Far Thrower | 148 | 197 | ||||||||
Farmboy24 | 1234 | |||||||||
Farns | 277 | |||||||||
Fatlight | 663 | |||||||||
fatsteve0 | 1361 | |||||||||
FBsLights | 790 | |||||||||
fcrespi | 1262 | |||||||||
fed893 | 307 | |||||||||
fedcas | 902 | |||||||||
feralcomprehension | 1194 | 1311 | ||||||||
ferthur | 1458 | |||||||||
Festizio | 1515 | |||||||||
FindThisHumerus | 1466 | |||||||||
finges | 561 | |||||||||
fireblade893 | 209 | |||||||||
firedome | 324 | 711 | ||||||||
Firelight2 | 397 | |||||||||
fischju | 1462 | |||||||||
fishlite5 | 1046 | |||||||||
fixed it | 78 | 1097 | ||||||||
fixvid | 1264 | |||||||||
Flash Voyager | 652 | |||||||||
Flash-O-Maniac | 1414 | |||||||||
flashination | 87 | |||||||||
FlashMax | 1225 | |||||||||
Flashy Mike | 239 | 410 | 448 | 449 | ||||||
flatbear | 1451 | |||||||||
Flifish48 | 806 | 1096 | ||||||||
Flintrock | 629 | |||||||||
fluffman86 | 958 | |||||||||
FmC | 1182 | |||||||||
fonfan | 234 | 1023 | 1024 | |||||||
fonLED | 725 | |||||||||
Ford Prefect | 1068 | |||||||||
Foston Pete | 453 | 454 | 644 | |||||||
foton | 1030 | |||||||||
fourtogaraffia | 1446 | |||||||||
Fozzy-SP | 317 | |||||||||
Frank A. | 1172 | |||||||||
Frankie Baby | 342 | |||||||||
Franz | 788 | |||||||||
Freddy61069 | 282 | |||||||||
Fredylee | 223 | 1329 | ||||||||
FreeMagenta | 1050 | |||||||||
freeme | 514 | |||||||||
freethink | 1484 | |||||||||
Fritz t. Cat | 484 | |||||||||
Funzel67 | 990 | |||||||||
fuzun | 1074 | |||||||||
fyesilova | 535 | |||||||||
g17jimmy | 1440 | |||||||||
g60 | 290 | |||||||||
g_sintornillos | 126 | |||||||||
gamezawy | 38 | 336 | ||||||||
Gammel | 1544 | |||||||||
gangstead | 53 | 922 | ||||||||
garrybunk | 254 | |||||||||
gboss | 832 | |||||||||
gds95 | 1199 | |||||||||
gearowl | 1415 | |||||||||
gedasd | 1309 | |||||||||
geepaw | 1038 | |||||||||
Geese | 1575 | |||||||||
gehrmo | 289 | |||||||||
geo1952 | 455 | 457 | ||||||||
ger-slash | 416 | |||||||||
Gerrh | 531 | 1163 | 1164 | 1285 | ||||||
Gerrit | 106 | |||||||||
getbully | 609 | 1263 | ||||||||
GF357 | 1509 | |||||||||
Gilatabar | 638 | |||||||||
giorgoskok | 306 | 493 | 1092 | |||||||
GIR | 804 | 818 | ||||||||
gisewhcs | 384 | |||||||||
Givememyhatback | 1520 | |||||||||
Gj | 580 | 581 | ||||||||
Gladimir_Gluten | 1585 | |||||||||
gleamer | 432 | |||||||||
GlinnDamar | 1342 | |||||||||
gnatx | 588 | 824 | ||||||||
goatfarmer | 770 | |||||||||
gokalpm | 1393 | |||||||||
GoldenBatt | 383 | 589 | 590 | |||||||
gorb507 | 811 | 812 | ||||||||
goshdogit | 11 | 12 | 40 | 120 | 121 | 543 | 556 | 928 | ||
Goud | 1468 | |||||||||
gpapa693 | 79 | |||||||||
gravelmonkey | 1027 | |||||||||
green_comet | 601 | |||||||||
GreenShrike | 190 | |||||||||
gregfortune | 1576 | |||||||||
gregor | 215 | |||||||||
Grieflar | 1491 | |||||||||
GTsuperheros | 179 | |||||||||
Gtt980 | 936 | |||||||||
guerrilla154 | 1316 | 1422 | ||||||||
Guggga | 538 | |||||||||
GulfCoast | 880 | |||||||||
gungoat | 44 | |||||||||
Gunnerboy | 252 | 967 | ||||||||
Guns712 | 1300 | 1301 | 1369 | 1370 | ||||||
h2o | 181 | 476 | ||||||||
Hairy_Steve | 340 | 1367 | ||||||||
hank | 258 | 1385 | ||||||||
Hardware | 1071 | 1200 | ||||||||
Hauwexis | 845 | 846 | 847 | 848 | ||||||
haxquiz | 226 | 927 | ||||||||
headburger | 592 | |||||||||
heatwaves | 994 | 1265 | ||||||||
hein11ag | 183 | |||||||||
Herb Tarlek | 931 | |||||||||
Hestbech | 994 | 995 | ||||||||
hexcode | 503 | 672 | ||||||||
Hezekiah | 286 | 759 | ||||||||
hideehoo | 859 | |||||||||
HighCaliber | 177 | 178 | ||||||||
hmihaylov | 502 | |||||||||
Hobo | 220 | |||||||||
hunter1 | 116 | 720 | 721 | |||||||
hurleyy | 993 | |||||||||
I_like_lamb | 915 | |||||||||
Ian2381 | 150 | |||||||||
igeigeige | 890 | |||||||||
IH8MYX | 546 | |||||||||
ii_pennies | 481 | |||||||||
ikaruz_500 | 989 | |||||||||
ikkentobi | 1423 | |||||||||
Illumenated | 426 | |||||||||
illusioned | 954 | |||||||||
Ilmatic | 1253 | 1332 | 1493 | |||||||
ilovejesuschrist | 294 | 295 | ||||||||
ImA4Wheelr | 19 | |||||||||
ISO | 705 | 734 | 929 | 930 | ||||||
Itsme | 1495 | |||||||||
iwandutchy | 1047 | |||||||||
J-Dub74 | 461 | |||||||||
J_R_J | 675 | |||||||||
jack-bkk | 356 | |||||||||
jacktheclipper | 1108 | |||||||||
Jailbrake | 1034 | 1090 | ||||||||
JakeDjanitor | 46 | |||||||||
Jalben | 187 | |||||||||
jama | 635 | |||||||||
Jambo | 912 | |||||||||
james y | 1043 | 1044 | ||||||||
JaredP | 1570 | |||||||||
jarfield | 1558 | |||||||||
JasonWW | 1399 | |||||||||
javipiloto | 1154 | |||||||||
jaynick | 1048 | |||||||||
JayT | 62 | |||||||||
JayWallis | 1387 | 1388 | ||||||||
Jayzed | 1214 | |||||||||
jb1 | 224 | |||||||||
jbailey94 | 1586 | |||||||||
jctron | 1489 | |||||||||
jdunlap27284 | 164 | |||||||||
jealous57 | 81 | |||||||||
jeanlouis | 1478 | |||||||||
Jeffstanton | 1380 | 1381 | 1382 | |||||||
Jensa41 | 731 | 732 | ||||||||
Jerommel | 637 | |||||||||
jerrod | 512 | |||||||||
jescereal | 228 | |||||||||
Jesjes | 153 | 154 | ||||||||
jfalk1 | 918 | |||||||||
jhalb | 297 | |||||||||
JHost13 | 1583 | |||||||||
jhullin | 159 | 751 | ||||||||
JIGHEADWORM | 1413 | 1420 | ||||||||
jingleberry | 1022 | |||||||||
Jinx | 93 | |||||||||
jkbam | 550 | |||||||||
JLAu | 1421 | |||||||||
JM87 | 1470 | |||||||||
jmoots | 268 | |||||||||
jmpaul320 | 95 | 299 | ||||||||
jmwhite151 | 482 | 851 | 852 | 853 | ||||||
Joat | 184 | |||||||||
JockRobbins | 717 | |||||||||
Joe Darkness | 620 | |||||||||
joe1512 | 534 | |||||||||
joeangi | 756 | 1390 | 1391 | 1392 | ||||||
joechina | 633 | 1437 | ||||||||
Joey Adams | 1021 | 1132 | ||||||||
John-Galt | 463 | |||||||||
Johnhywash1 | 966 | |||||||||
johnnydoe | 1227 | |||||||||
JohnnyMac | 496 | |||||||||
johnpc | 955 | |||||||||
johny723 | 1082 | |||||||||
Jonandreadolan | 1072 | |||||||||
JonnyC | 576 | |||||||||
JordanZHP | 1078 | 1196 | ||||||||
JorisFRST | 1404 | |||||||||
josephqool | 1061 | 1417 | ||||||||
jpcuba | 684 | |||||||||
JPLight | 23 | 646 | ||||||||
JPM3 | 263 | 264 | ||||||||
jrummer | 1439 | |||||||||
JS721 | 216 | |||||||||
jsmn4vu | 793 | |||||||||
jtechl | 1513 | 1514 | ||||||||
Jtm94 | 1035 | |||||||||
Juanesdan | 118 | |||||||||
juaquin | 219 | |||||||||
Juggeli | 745 | |||||||||
juhha | 1540 | |||||||||
JulioElGuapo | 1526 | |||||||||
Jump909 | 1569 | |||||||||
jurasik1 | 1231 | |||||||||
justanotherguy | 541 | 712 | 1080 | |||||||
Jvrthp321 | 691 | |||||||||
jycheang | 1009 | |||||||||
k-wong | 542 | 1005 | ||||||||
Kafar | 9 | |||||||||
kahvitahra | 796 | |||||||||
Kalchev | 400 | |||||||||
kali stupa | 1217 | |||||||||
Kalihi | 836 | |||||||||
kalkat | 1373 | |||||||||
KawiBoy1428 | 230 | |||||||||
kaybi | 1033 | |||||||||
Kazik | 1315 | |||||||||
kbmeister | 1589 | |||||||||
kbro | 168 | |||||||||
keengeorge | 309 | 310 | ||||||||
KeepingItLight | 992 | |||||||||
Keepitsharp | 175 | |||||||||
Keisari | 1211 | 1212 | ||||||||
keithd | 753 | |||||||||
kemosabi | 1438 | |||||||||
KenE | 355 | |||||||||
Kenjii | 385 | |||||||||
Kentuckywindage | 797 | 872 | ||||||||
Kepling | 333 | |||||||||
kevinfc | 1426 | |||||||||
KFulton | 1331 | |||||||||
khas | 628 | |||||||||
Khuan | 1148 | |||||||||
KIKY | 1340 | |||||||||
Killforfood | 272 | 379 | ||||||||
Kindle | 698 | |||||||||
KingSmono | 578 | |||||||||
kiriba-ru | 525 | |||||||||
Kiukas | 640 | |||||||||
KiwiKane | 174 | |||||||||
Kkelleher | 99 | 100 | 101 | 102 | ||||||
Kloepper Knife Works | 194 | 195 | 196 | |||||||
knightstalker | 1219 | |||||||||
kntx | 1073 | 1116 | 1189 | |||||||
knudsengj | 1106 | |||||||||
Koaksijalac | 104 | |||||||||
Kodachrome40 | 170 | 1282 | ||||||||
KoekieMonster | 161 | |||||||||
kommessy | 108 | |||||||||
korpzgrinda | 1029 | 1133 | ||||||||
kotobuki | 799 | 1143 | 1144 | |||||||
koyotee | 276 | |||||||||
Kozy | 58 | 129 | ||||||||
krutone | 1298 | |||||||||
kubed_zero | 1442 | |||||||||
Kulumatic | 914 | |||||||||
Kurt_Norway | 593 | |||||||||
Kusie | 8 | 17 | ||||||||
KutKhemist | 123 | |||||||||
Kysumi | 925 | |||||||||
LAB | 259 | |||||||||
lachesis | 673 | |||||||||
lalomt | 1167 | |||||||||
Lamont56 | 808 | |||||||||
lamper | 727 | 1171 | ||||||||
lanceb1b | 884 | |||||||||
laststance | 972 | |||||||||
lawallac | 393 | 394 | ||||||||
Lazy-R-us | 25 | 900 | 1249 | 1250 | ||||||
Le_Zouave | 71 | |||||||||
leaftye | 694 | 1103 | 1183 | 1184 | ||||||
LEDtec | 823 | |||||||||
legan710 | 1088 | 1476 | ||||||||
Legolas Jr. | 130 | |||||||||
leroycp | 236 | 266 | 450 | 451 | ||||||
Lexel | 696 | 1287 | ||||||||
Lfatman | 707 | |||||||||
Liber8 | 537 | |||||||||
lichtpfadfinder | 1292 | |||||||||
Light of Earendil | 700 | |||||||||
lightbulb | 281 | |||||||||
lightknot | 471 | 492 | 598 | |||||||
lightlight22 | 772 | 920 | 1040 | 1328 | 1479 | |||||
LightMan541 | 1469 | |||||||||
lightmog | 72 | |||||||||
lightx | 757 | |||||||||
Lilien | 978 | |||||||||
Lion42 | 246 | 1408 | ||||||||
lionheart_2281 | 33 | |||||||||
litcrit | 871 | |||||||||
Litefighter | 1320 | 1334 | 1335 | |||||||
litenutz | 1371 | |||||||||
LloydV | 767 | |||||||||
Loneman | 510 | 903 | ||||||||
longmire | 1256 | |||||||||
Lopan | 1069 | 1416 | ||||||||
lovetheguitar | 981 | |||||||||
Lowtech | 1042 | 1193 | ||||||||
ludolf | 348 | |||||||||
luisgcan | 1162 | |||||||||
Lumenmaster17 | 1145 | 1146 | 1147 | |||||||
Lumens Industry | 634 | |||||||||
lumiere | 231 | |||||||||
Lund1660 | 64 | 439 | ||||||||
luongshot | 1525 | |||||||||
luxlad | 831 | |||||||||
lyse99 | 1012 | |||||||||
Lyubo Yanev | 427 | 428 | 429 | 536 | ||||||
M4D M4X | 350 | |||||||||
M78 | 157 | 337 | 1007 | |||||||
MACS0647 | 313 | |||||||||
MAD TM26 | 656 | 657 | ||||||||
Magbrite | 584 | |||||||||
magnet | 302 | |||||||||
MagPap | 794 | |||||||||
Maiden666 | 92 | |||||||||
maildroid | 331 | |||||||||
Majoroverkill | 919 | |||||||||
malamask | 113 | |||||||||
MaleNurse | 1472 | |||||||||
mandala | 952 | 953 | ||||||||
Manheim69 | 1518 | 1534 | ||||||||
manithree | 1255 | |||||||||
Manulous | 1270 | |||||||||
ManWithoutShadow | 1100 | 1299 | ||||||||
Mapache | 4 | |||||||||
Marcello | 1456 | |||||||||
marcus_z | 1375 | |||||||||
markalike | 602 | |||||||||
Marothar | 1236 | |||||||||
marsalla | 475 | |||||||||
Martini | 82 | 726 | ||||||||
martook | 48 | |||||||||
martytown | 976 | |||||||||
Masejoer | 842 | |||||||||
Matchoo | 905 | |||||||||
matkovicha | 1185 | |||||||||
Matomoto | 1324 | |||||||||
mattlward | 16 | 34 | 214 | |||||||
MauiSon | 42 | 979 | ||||||||
maukka | 225 | 627 | ||||||||
Maxxsounds | 681 | |||||||||
MBuitendorp | 1210 | |||||||||
mcfarlie6996 | 964 | 965 | ||||||||
MCT | 162 | |||||||||
Mecallie | 1051 | |||||||||
MechEngVictor | 275 | |||||||||
Medvegy | 660 | |||||||||
Melven | 167 | |||||||||
meti | 470 | |||||||||
metz3006 | 843 | |||||||||
Meyer | 138 | |||||||||
mezzmen7 | 1374 | |||||||||
MG | 353 | |||||||||
mhanlen | 77 | |||||||||
mi bill | 127 | |||||||||
Micael | 858 | |||||||||
mightybonk | 1535 | |||||||||
Miguel_79 | 1114 | 1129 | ||||||||
Miguelintegral | 1175 | |||||||||
Mike72 | 1403 | |||||||||
mikeyx | 622 | |||||||||
Mindaugass | 769 | 1081 | 1490 | |||||||
Minimoke | 30 | 975 | ||||||||
miraclenip | 1547 | |||||||||
miswas | 760 | |||||||||
Mitko | 26 | 27 | ||||||||
mitrhandir | 1303 | |||||||||
mizjif | 714 | |||||||||
Mkduffer | 600 | |||||||||
mlodyulek | 1283 | |||||||||
moemin | 375 | |||||||||
MontyPyfon | 66 | |||||||||
moridin | 907 | |||||||||
Morpheus | 613 | |||||||||
MorpheusT1 | 762 | |||||||||
MortyDuck | 764 | |||||||||
MountainKing | 438 | 445 | ||||||||
MountainMan | 786 | 787 | ||||||||
mozart.f | 314 | |||||||||
Mr.Poppy | 192 | 267 | 1247 | 1308 | ||||||
Mr.Scott | 251 | 1077 | ||||||||
mrheosuper | 1110 | |||||||||
mrkelvin | 606 | |||||||||
MRsDNF | 325 | 326 | ||||||||
mrstealyourgains | 1014 | |||||||||
msg1285 | 173 | |||||||||
Mstevens113 | 114 | |||||||||
Mt.B | 392 | |||||||||
MtnDon | 158 | 498 | ||||||||
mud_muncher | 624 | |||||||||
mudguts | 680 | 716 | ||||||||
muellihenry | 1396 | |||||||||
Muto | 20 | 242 | 689 | |||||||
mutts13 | 1343 | 1348 | ||||||||
muzzleblast? | 89 | |||||||||
mxlu | 396 | |||||||||
MyDangus | 1181 | |||||||||
myowin | 213 | 1235 | ||||||||
myst999 | 198 | 728 | 1266 | 1267 | ||||||
nanojack | 1036 | |||||||||
narin000 | 524 | |||||||||
Nathan42 | 946 | 987 | 1365 | |||||||
Navin_R_Johnson | 817 | |||||||||
NavyHammer | 1588 | |||||||||
neckbear | 935 | |||||||||
needmorlts | 911 | |||||||||
Neilyboy | 1307 | |||||||||
netprince | 176 | 378 | ||||||||
Newlumen | 1425 | |||||||||
nexrace1 | 579 | |||||||||
nfetterly | 362 | 366 | ||||||||
Nguyen | 1277 | 1293 | ||||||||
nickdude | 591 | |||||||||
Nickke | 604 | |||||||||
Nicolaas | 857 | |||||||||
Nicolicous | 270 | |||||||||
Night Light | 1093 | |||||||||
NightLight | 369 | |||||||||
Nightshade | 574 | |||||||||
niktak11 | 782 | |||||||||
Nil | 959 | 960 | 1447 | |||||||
Nine9n1ne | 1436 | |||||||||
nishayume | 1419 | |||||||||
Nite Shadow | 1001 | |||||||||
Nitetime | 163 | |||||||||
nitrader0 | 1203 | |||||||||
nnmnu1 | 1349 | |||||||||
No Agenda | 431 | |||||||||
nodoubt | 1591 | |||||||||
noetik | 1572 | |||||||||
nofear87 | 382 | |||||||||
Noki | 573 | |||||||||
noob | 828 | 833 | 1025 | 1386 | ||||||
Nord | 1170 | |||||||||
nordlicht | 1541 | |||||||||
Nortson | 810 | |||||||||
novice1 | 338 | |||||||||
nqcken | 119 | 241 | ||||||||
nskn71 | 1136 | |||||||||
NuggetMcNugget | 166 | 332 | ||||||||
ObiWan-Kenobi | 422 | 423 | ||||||||
octav | 666 | |||||||||
OdorlessCurves | 529 | 530 | ||||||||
Ohmypotatoes | 1517 | |||||||||
ohnonothimagain | 1357 | |||||||||
olivedrab | 658 | |||||||||
OrangePeel | 1275 | 1288 | ||||||||
orinjuse | 835 | |||||||||
Orionz23 | 1168 | |||||||||
osb40000 | 193 | |||||||||
OscarM | 1290 | |||||||||
Oswald3211 | 724 | |||||||||
oto | 888 | |||||||||
Ozythemandias | 625 | |||||||||
Pablogy | 441 | |||||||||
PabloVerde | 1037 | |||||||||
pacbough | 149 | |||||||||
Paetrw | 1519 | 1563 | ||||||||
papaslightsaber | 583 | 1125 | 1126 | |||||||
patchythepirate | 704 | 1364 | ||||||||
patman | 1521 | |||||||||
patmet | 1347 | |||||||||
patmurris | 55 | 1355 | ||||||||
Paul321 | 139 | |||||||||
pawwright | 151 | |||||||||
PBWilson | 557 | 558 | ||||||||
peabody | 207 | |||||||||
Peetz | 311 | |||||||||
Pegaso | 122 | |||||||||
Peho | 112 | |||||||||
pelle470 | 1467 | |||||||||
Penguin | 1433 | 1434 | ||||||||
pepe2017 | 1305 | |||||||||
pepinfaxera | 1158 | |||||||||
perche | 1155 | |||||||||
Perdu | 1571 | |||||||||
peterlcole | 924 | |||||||||
peteybaby | 549 | |||||||||
petr9999 | 1137 | |||||||||
Petroleum Lantern Guy | 891 | |||||||||
Phantom1 | 1372 | |||||||||
Phoenix_FIN | 395 | |||||||||
PickleFuzz | 1531 | |||||||||
Pidro | 465 | |||||||||
pieman7 | 670 | |||||||||
Pin8 | 1528 | |||||||||
pirate joe 22 | 678 | 679 | 783 | 784 | ||||||
pistol86 | 1378 | |||||||||
piyoman | 840 | |||||||||
plntigrado | 1153 | |||||||||
pommie | 54 | |||||||||
pook | 330 | |||||||||
pooptoast | 519 | |||||||||
powerfultorches | 569 | |||||||||
praveendk | 437 | |||||||||
prdonut2k7 | 1579 | |||||||||
prepro | 1580 | |||||||||
presterjohn | 586 | 715 | ||||||||
Presumptuous | 653 | 654 | 655 | |||||||
Primal | 364 | |||||||||
prisma | 401 | |||||||||
Prodeje79 | 1481 | |||||||||
Prometheus | 1149 | |||||||||
ProtaBLF | 419 | |||||||||
pscal | 376 | |||||||||
puccio1969 | 76 | |||||||||
Pukachi | 205 | |||||||||
pukoid | 868 | |||||||||
Pulsar13 | 288 | 1412 | ||||||||
qandeel | 631 | 632 | ||||||||
qBawl | 1539 | |||||||||
R.D. | 974 | |||||||||
radb | 856 | |||||||||
rag | 283 | 298 | ||||||||
Ragsy | 499 | 1117 | ||||||||
raiko | 570 | |||||||||
rajun50 | 651 | |||||||||
ramius | 1584 | |||||||||
Randolph | 212 | |||||||||
RapidLux | 1346 | 1360 | ||||||||
raqin | 1551 | |||||||||
Rat_Racer | 999 | |||||||||
RaVeN | 160 | |||||||||
raynman | 706 | |||||||||
rdoc613 | 879 | |||||||||
ReallyInToCheese | 1568 | |||||||||
red72vw | 521 | |||||||||
RedForest UK | 1366 | |||||||||
redrider706 | 1359 | |||||||||
regaia | 1008 | 1486 | ||||||||
reliant_turbo | 710 | 850 | ||||||||
ReManG | 320 | |||||||||
reno | 1118 | |||||||||
retiro675 | 352 | 826 | ||||||||
rexdog | 442 | 515 | ||||||||
rfd673 | 747 | |||||||||
ricardon | 300 | |||||||||
Ricflair | 323 | |||||||||
Rick | 199 | |||||||||
rizky_p | 1405 | |||||||||
rjorge | 708 | |||||||||
rmkline | 436 | |||||||||
Rob_K | 244 | |||||||||
robbobus | 233 | |||||||||
Roberrt777 | 185 | |||||||||
RobertB | 140 | |||||||||
rocketshipdog | 1500 | |||||||||
RocketTomato | 766 | |||||||||
RockHugger | 1173 | |||||||||
RoloFresh | 1524 | |||||||||
Romey310 | 969 | 970 | ||||||||
RonMuller | 111 | |||||||||
rossysarus | 1465 | |||||||||
Roter | 649 | |||||||||
RotorHead64 | 1284 | |||||||||
rova2014 | 1473 | |||||||||
Royo | 1407 | |||||||||
Rpdos | 1180 | |||||||||
Rska | 650 | |||||||||
Rsqweezy | 814 | |||||||||
rufrydr | 765 | |||||||||
Rufusbduck | 60 | |||||||||
Rxich | 866 | |||||||||
ryukin2000 | 1220 | |||||||||
sac02 | 645 | 908 | 1215 | 1216 | ||||||
saf99 | 755 | |||||||||
Saigon | 247 | |||||||||
saintsagan | 1485 | |||||||||
SamHaLeKe | 485 | |||||||||
samis | 509 | |||||||||
samnavy | 73 | |||||||||
san san | 926 | 1130 | 1131 | |||||||
sandanbob | 532 | |||||||||
Sarge930 | 86 | |||||||||
Savydude | 1222 | |||||||||
SawMaster | 45 | |||||||||
saypat | 141 | |||||||||
sb56637 | 191 | |||||||||
scarnific | 566 | |||||||||
scdaf | 271 | 296 | ||||||||
Schkü | 614 | |||||||||
schlockproof | 612 | |||||||||
Schoki | 1581 | |||||||||
Sciencetists | 257 | |||||||||
SciFiFreak | 31 | |||||||||
Scooby | 582 | |||||||||
Scooter000 | 315 | |||||||||
scootypuffjr | 844 | |||||||||
Scorpia | 596 | |||||||||
scotlarock | 329 | 1085 | ||||||||
Scottland | 334 | |||||||||
Scotty | 746 | |||||||||
scs | 80 | |||||||||
sebastiang | 611 | |||||||||
SebaZ74 | 1239 | 1240 | ||||||||
SeenTheLight | 301 | 819 | ||||||||
SFB | 1109 | |||||||||
Sgtpev | 206 | |||||||||
Shadowcactus | 916 | |||||||||
Shadowfax | 341 | |||||||||
Sharpie | 354 | |||||||||
shimano3000 | 409 | |||||||||
shimey | 211 | |||||||||
shirnask | 61 | 733 | 1384 | |||||||
Shoe | 957 | |||||||||
shogan | 227 | |||||||||
Shur | 284 | |||||||||
SIGShooter | 368 | 1565 | ||||||||
Silent_Star | 1190 | |||||||||
Silentcropduster | 667 | |||||||||
Simplelight | 961 | 962 | ||||||||
slackwolf | 885 | 886 | 1000 | |||||||
slatzman | 1560 | |||||||||
Sledge | 980 | 985 | 986 | 1326 | ||||||
Sledgestone | 677 | 841 | ||||||||
slickpenguin | 643 | 854 | ||||||||
slimkango | 52 | 1207 | ||||||||
slow2go | 221 | 222 | 692 | 1139 | 1140 | 1141 | 1278 | 1279 | 1280 | |
smed1275 | 494 | |||||||||
Smittymojo | 768 | 1142 | ||||||||
SmokinH | 855 | |||||||||
sneakyfart007 | 1522 | |||||||||
Snoballz | 1031 | |||||||||
SoCalTiger | 1344 | |||||||||
sochi111 | 1032 | |||||||||
Sofa | 834 | |||||||||
sol | 291 | 292 | ||||||||
SolarLumen | 776 | |||||||||
solRNY | 1291 | |||||||||
somnambulism | 562 | |||||||||
Sonpham | 621 | |||||||||
Sordoslux | 1402 | |||||||||
southland | 142 | 143 | 144 | 145 | ||||||
sp5it | 94 | 1201 | ||||||||
spade413 | 1178 | |||||||||
sparkyDK | 1188 | |||||||||
specialk | 865 | |||||||||
Speed4goal | 413 | |||||||||
Speedsix | 1083 | |||||||||
spinynorman | 1400 | |||||||||
spkzzz | 474 | 526 | ||||||||
Sprinkles | 279 | 778 | 901 | |||||||
square74 | 1538 | |||||||||
srs2000 | 1187 | |||||||||
stanley-beamish | 107 | |||||||||
starcrazed | 1330 | |||||||||
stareye | 540 | |||||||||
staticx57 | 238 | |||||||||
steel_1024 | 709 | |||||||||
Steenbhg | 701 | 1205 | 1206 | 1268 | ||||||
steepdrop | 435 | 497 | ||||||||
Stephen Elliott | 1322 | |||||||||
stephenk | 269 | |||||||||
steve-o | 1376 | |||||||||
steve42 | 1016 | |||||||||
Stevejj | 1218 | |||||||||
SteveMidwest | 1289 | |||||||||
stevez32 | 822 | |||||||||
StinkyTool | 1480 | |||||||||
Stittville Ed | 85 | 998 | ||||||||
Stoneface | 758 | 1127 | ||||||||
strango | 96 | |||||||||
strayz | 505 | |||||||||
Streamer | 1246 | |||||||||
strmix | 676 | |||||||||
strobed | 1368 | |||||||||
Stud_nut | 1504 | |||||||||
SubSailorVet | 1501 | 1527 | ||||||||
Subterrestrial | 1003 | |||||||||
Sukoi | 642 | 1010 | ||||||||
Sullysat | 418 | |||||||||
Suncoaster | 682 | |||||||||
Swennie | 895 | |||||||||
Syncmasterklop | 867 | |||||||||
syracuse | 349 | |||||||||
T-boon | 304 | |||||||||
T18 | 390 | 1257 | ||||||||
t3rminal | 1213 | |||||||||
Tadashi | 1471 | |||||||||
Tally-ho | 1573 | |||||||||
tapir | 489 | |||||||||
tarver | 132 | 229 | ||||||||
Tarvos | 15 | |||||||||
tas69 | 380 | |||||||||
tatasal | 506 | |||||||||
teacher | 321 | 1134 | ||||||||
tebeve | 893 | |||||||||
techieman33 | 456 | |||||||||
Tecmo | 57 | |||||||||
tekwyzrd | 37 | |||||||||
tenohfive | 802 | |||||||||
Terry White | 1435 | |||||||||
Tete | 217 | |||||||||
Texas_Ace | 472 | 473 | ||||||||
The Burgh | 235 | |||||||||
The Grand Pooh-Bah | 1056 | 1057 | ||||||||
The Imp | 1242 | |||||||||
The Jinx | 522 | 699 | ||||||||
The Last Katun | 90 | |||||||||
The Miller | 1 | 2 | ||||||||
The_Driver | 1352 | |||||||||
thebaum | 585 | 807 | ||||||||
TheConsultant | 1453 | |||||||||
thecrc | 1177 | |||||||||
TheDude | 415 | |||||||||
TheHebrewHammer | 820 | 821 | ||||||||
TheJo | 1053 | |||||||||
Thekernels | 1536 | |||||||||
TheLonelyLumen | 1444 | |||||||||
themacman4 | 1505 | |||||||||
TheMadcap | 97 | |||||||||
themagicconch | 1464 | 1494 | ||||||||
themaindude | 343 | 1094 | 1095 | |||||||
TheManMKD | 1546 | |||||||||
Theodore41 | 520 | |||||||||
theoldbill | 59 | |||||||||
TheOnlyDocc | 1135 | |||||||||
thijsco19 | 24 | |||||||||
tigris99 | 603 | |||||||||
tim_duncan | 1545 | |||||||||
timcodes | 1004 | 1017 | ||||||||
tindrum42 | 1059 | 1060 | ||||||||
tinowrx | 572 | |||||||||
Tixx | 371 | |||||||||
Tjhosan | 273 | |||||||||
Tjohn | 940 | 941 | 942 | 943 | 944 | |||||
Tmik | 287 | |||||||||
tmxod | 771 | |||||||||
Toccata | 1241 | |||||||||
tocirahl | 988 | |||||||||
Tom E | 28 | 29 | 874 | 875 | 1223 | 1224 | ||||
Tom_182 | 695 | 780 | ||||||||
Tomogchi | 1567 | |||||||||
tomtaylor | 201 | |||||||||
tonylim | 43 | |||||||||
torchjunkie | 483 | 597 | ||||||||
toxiccoccyx | 1107 | |||||||||
ToyKeeper | 339 | |||||||||
tracerfire | 1317 | |||||||||
Trashman531 | 285 | |||||||||
Trasnodel | 729 | |||||||||
trevglas | 200 | |||||||||
trevize | 1165 | |||||||||
treysoucie | 789 | |||||||||
tristanxoxo | 240 | 1070 | ||||||||
troisanh | 91 | |||||||||
tronx | 674 | |||||||||
TRoPHeuS | 1152 | |||||||||
tru3s1lv3r | 39 | |||||||||
tucsonmike | 1512 | |||||||||
tugboatcar | 1457 | |||||||||
Tunerman | 1002 | |||||||||
tungkon | 1011 | |||||||||
TurboLion | 917 | |||||||||
turbopscl | 892 | |||||||||
turpulator | 1066 | 1363 | ||||||||
tzmxxhh | 21 | |||||||||
ubermoo | 1561 | 1562 | ||||||||
Ulric | 1198 | |||||||||
unit311 | 849 | |||||||||
unknown00101 | 548 | |||||||||
uqs1000 | 357 | |||||||||
Vagany | 647 | |||||||||
VaKo | 208 | |||||||||
Valdorg | 1202 | |||||||||
Van | 491 | |||||||||
Vanq86 | 1176 | |||||||||
vas | 133 | |||||||||
vasa_visost | 668 | |||||||||
Vattern | 18 | |||||||||
velocraig | 781 | |||||||||
vex_zg | 730 | |||||||||
Viamede | 948 | |||||||||
vinte77 | 414 | |||||||||
vitriolix.com | 1506 | |||||||||
Volks1973 | 743 | |||||||||
vulpes | 539 | |||||||||
vwpieces | 881 | |||||||||
w4rkry | 1548 | |||||||||
Wackyvegan | 156 | |||||||||
walty | 280 | |||||||||
WarHawk-AVG | 420 | 421 | ||||||||
warzi1975 | 528 | |||||||||
wattstar | 791 | |||||||||
WaylonJennings | 1452 | 1499 | ||||||||
wb | 1556 | 1564 | ||||||||
websterjody | 996 | 1105 | 1502 | |||||||
weklund | 460 | |||||||||
Werner | 10 | |||||||||
WestBam | 1333 | |||||||||
westcoastwonders | 639 | |||||||||
what_are_birds | 1377 | |||||||||
whitecitadel | 1354 | |||||||||
Whitty05 | 1475 | |||||||||
Wieselflinkpro | 125 | 750 | 1079 | 1482 | 1483 | |||||
Wildcat | 827 | 945 | ||||||||
wildmermaid | 1091 | 1398 | ||||||||
Wildthing | 533 | |||||||||
willmo | 605 | 882 | ||||||||
WillyD | 303 | |||||||||
wilwok | 1076 | 1258 | ||||||||
Wineslurper | 554 | 555 | ||||||||
wisefire | 869 | |||||||||
wishiwereaskibum | 587 | |||||||||
wkhchin81 | 477 | |||||||||
Wojto | 1325 | |||||||||
WolfA | 69 | |||||||||
Wrathbringer27 | 41 | |||||||||
wunderhe | 115 | |||||||||
Wyre | 1269 | |||||||||
X0R | 1430 | |||||||||
Xandre | 527 | |||||||||
xCentrino | 1314 | 1358 | ||||||||
xed888 | 305 | |||||||||
xelario | 773 | |||||||||
xjsnake | 36 | |||||||||
xray291 | 1192 | |||||||||
xsosx | 1474 | |||||||||
xtrosity | 723 | |||||||||
XXX-Man | 1197 | |||||||||
xzel87 | 665 | |||||||||
yasenf | 1006 | 1232 | 1233 | 1273 | 1274 | |||||
yclongthrow | 898 | 899 | ||||||||
YoFlash | 744 | |||||||||
Yokiamy | 1245 | 1383 | ||||||||
Yourrid | 1101 | 1102 | ||||||||
zachary6227 | 1297 | |||||||||
zak.wilson | 182 | |||||||||
Zanders | 792 | |||||||||
zara | 180 | |||||||||
zelee | 22 | |||||||||
Zeratull | 703 | |||||||||
zeremefico | 1590 | |||||||||
zeroair | 452 | |||||||||
zifzif | 1243 | |||||||||
zipelgas | 386 | |||||||||
zoysiamo | 1251 | |||||||||
ZozzV6 | 626 | |||||||||
Zteduh | 1530 | |||||||||
Zulumoose | 1389 | |||||||||
×73rmin8r | 1063 |
1176 names
1586 lights
- 2 DOGS, 264, 2Ace, 5ar, 7pot, a12luke, a_idiot, Aardvark Spleen, aaronchen, Abe87
- Abqjohnny, abril, acml, acruzangels, ada_potato, adirondackdestroyer, adrianlights, adsum, AEDe, Ag76
- aggillator, aginthelaw, Agiri, Agro, aim120, AirBreaker, akhyar, akoposilester, akovia, alberto7
- albertopnp, Alcius, alejandrov, alex64, AlexGT, Alkpwn77, allthumbs, alphazeta, alternety, Alux
- amplificus, Andmiller, andrewmac, Andybibbville, Andyman?, Angel Martínez, ant0, Antenne, Anthon, antilop65
- antiparanoico, AntLion13, aors10, AppA, aprendiz, apt323, archi, archimedes, arditty, aremihc
- ARMS.AARON, ARsee, Arufonsi, aslpg, asnidi2, asot, Astromanic, AsylumSweep, atbglenn, Atom00
- Aurora, Autistic, Autoclave, autodidact, Awdtsi, Awkward Stretch, AwkwardPause, b1i1l1l1y1, B42, BackpackNY
- bakalakos, balazs1956, baldo21, Bam35, bamawthu, banker, basslovin808, Bastarrdo, Batch1, battletross
- bawilson2, Bc412, bd52, BDM, Bdubelyew, BDWrabbit, beam0, BeardedRaleigh, bella-headlight, Bernard
- Bevo, bhuge00, bickle, bigpix, bigrick, bikedave99, bikenber73, Bill 63, Bill_tong, Billcheese5
- BingoThink, bionictony, bkling, BlackList, bladesmith3, BLFD80, BLightSam, BlindingL5s, blinker, blinky
- blueb8llz, bluecheesbob, Bluzie, bmaddison, Boaz, BobbyMK, bobdotorg, bobofire, Bogdan, bogdanr
- Bohemian, bonfire, Bong lick, Bonham, borealis, BorisBar, Boro, bossf350, Box, boxuvrox
- Brettg4215, brewskVT, Brian Metcalfe, brianch, BrianK, BrianTheJay, Bribo, brightlights, brittnell, brjones
- brno602, brted, brujeria, Bruno28, BT100, Bungle88, Buzzy243, bwl123, cabfrank, Caleb
- Caleb-v, Calmaja, Candil, Cano, Captainvideo, caramba, carmantl, casi29061965, Catul, cavesprings
- cavorite, Cawi, cbrake10, cccpull, cclight, cdjaney, Chadvone, Charga, charles lin, CheapThrills
- cheesecheeks, ChibiM, Chicken Drumstick, chinooker, chooma, chrisc, churchilllafemme, CircaM, Cirnyan, CJ Avlis
- Cjlee89, cjoe7, CJW, clagged, clange50, ClaudeMBallz, clinicdoc, Cliwilnew, cloggy, cmflippen
- cnrffl1, cocoschnauzer, compression, contigo, Coolerness, coolriku, Corzy, Couchmaster, cpd800t, CrashOne
- Crazyeddie, Creepo, cristhemuso, crx88ia, cujo255, cwb, cypher1024, cypherz, Cythras, D10ten
- Dadpool, dafarui, Dakotan2, daninho, DarkerInSol, darkpenguin, darol, darrenm, darrylo, DarthTader
- datiLED, dave101, DavidEF?, davidkappelt, davidvns, davos, DB Custom, dbesselt, DBSAR, DBSS
- deathless, Deep skull, DeJaVu, dekozn, Dennis, dentillozie, Dep668, derfyled, derpilgerer, Desmo
- devdvr, Dewalt101, dezoe, dglb99, dhsvcs, dicksog, digitalMessiah, digitaltc, Dimking, Dirt
- Dirty_Pierre, DiscoJoe, djburkes, Djozz, dmbaty, Dobtruckers, DOCFAR, Docp723, Doctawho, dodo
- dogany, Dogsrule, donpachi, dotBLF, doubleone44, downlinx, doxerino, Dr Forinor, Dradge, Dralf
- Dregs, DrHook59, driveX, DrJones, DrMcNinja17, DT101, dudunphy, duhduhduhdiabeetus, Duke, dukeface13
- dumptruck, Dusty, Dutcheee, duvallite, dw911, Dwantink, e10sno, Easyrr, eb1888, ebosh
- eddamoo, ediaz, eebowler, Eggun, egrep, Eivwer, electricjelly, ElginAgain, emarkd, embee
- Enelooper, engber, ERDOS, Erethryn, erikk365, Esskay, Etex, etienne440, euphxenos, everydaysurvivalgear
- Evilc, Evo1986, ExtrabrightExtracheap, Eyao, EyeballFryer, Fadetoblack, fantomR, Far Thrower, Farmboy24, Farns
- Fatlight, fatsteve0, FBsLights, fcrespi, fed893, fedcas, feralcomprehension, ferthur, Festizio, FindThisHumerus
- finges, fireblade893, firedome, Firelight2, fischju, fishlite5, fixed it, fixvid, Flash Voyager, Flash-O-Maniac
- flashination, FlashMax, Flashy Mike, flatbear, Flifish48, Flintrock, fluffman86, FmC, fonfan, fonLED
- Ford Prefect, Foston Pete, foton, fourtogaraffia, Fozzy-SP, Frank A., Frankie Baby, Franz, Freddy61069, Fredylee
- FreeMagenta, freeme, freethink, Fritz t. Cat, Funzel67, fuzun, fyesilova, g17jimmy, g60, g_sintornillos
- gamezawy, Gammel, gangstead, garrybunk, gboss, gds95, gearowl, gedasd, geepaw, Geese
- gehrmo, geo1952, ger-slash, Gerrh, Gerrit, getbully, GF357, Gilatabar, giorgoskok, GIR
- gisewhcs, Givememyhatback, Gj, Gladimir_Gluten, gleamer, GlinnDamar, gnatx, goatfarmer, gokalpm, GoldenBatt
- gorb507, goshdogit, Goud, gpapa693, gravelmonkey, green_comet, GreenShrike, gregfortune, gregor, Grieflar
- GTsuperheros, Gtt980, guerrilla154, Guggga, GulfCoast, gungoat, Gunnerboy, Guns712, h2o, Hairy_Steve
- hank, Hardware, Hauwexis, haxquiz, headburger, heatwaves, hein11ag, Herb Tarlek, Hestbech, hexcode
- Hezekiah, hideehoo, HighCaliber, hmihaylov, Hobo, hunter1, hurleyy, I_like_lamb, Ian2381, igeigeige
- IH8MYX, ii_pennies, ikaruz_500, ikkentobi, Illumenated, illusioned, Ilmatic, ilovejesuschrist, ImA4Wheelr, ISO
- Itsme, iwandutchy, J-Dub74, J_R_J, jack-bkk, jacktheclipper, Jailbrake, JakeDjanitor, Jalben, jama
- Jambo, james y, JaredP, jarfield, JasonWW, javipiloto, jaynick, JayT, JayWallis, Jayzed
- jb1, jbailey94, jctron, jdunlap27284, jealous57, jeanlouis, Jeffstanton, Jensa41, Jerommel, jerrod
- jescereal, Jesjes, jfalk1, jhalb, JHost13, jhullin, JIGHEADWORM, jingleberry, Jinx, jkbam
- JLAu, JM87, jmoots, jmpaul320, jmwhite151, Joat, JockRobbins, Joe Darkness, joe1512, joeangi
- joechina, Joey Adams, John-Galt, Johnhywash1, johnnydoe, JohnnyMac, johnpc, johny723, Jonandreadolan, JonnyC
- JordanZHP, JorisFRST, josephqool, jpcuba, JPLight, JPM3, jrummer, JS721, jsmn4vu, jtechl
- Jtm94, Juanesdan, juaquin, Juggeli, juhha, JulioElGuapo, Jump909, jurasik1, justanotherguy, Jvrthp321
- jycheang, k-wong, Kafar, kahvitahra, Kalchev, kali stupa, Kalihi, kalkat, KawiBoy1428, kaybi
- Kazik, kbmeister, kbro, keengeorge, KeepingItLight, Keepitsharp, Keisari, keithd, kemosabi, KenE
- Kenjii, Kentuckywindage, Kepling, kevinfc, KFulton, khas, Khuan, KIKY, Killforfood, Kindle
- KingSmono, kiriba-ru, Kiukas, KiwiKane, Kkelleher, Kloepper Knife Works, knightstalker, kntx, knudsengj, Koaksijalac
- Kodachrome40, KoekieMonster, kommessy, korpzgrinda, kotobuki, koyotee, Kozy, krutone, kubed_zero, Kulumatic
- Kurt_Norway, Kusie, KutKhemist, Kysumi, LAB, lachesis, lalomt, Lamont56, lamper, lanceb1b
- laststance, lawallac, Lazy-R-us, Le_Zouave, leaftye, LEDtec, legan710, Legolas Jr., leroycp, Lexel
- Lfatman, Liber8, lichtpfadfinder, Light of Earendil, lightbulb, lightknot, lightlight22, LightMan541, lightmog, lightx
- Lilien, Lion42, lionheart_2281, litcrit, Litefighter, litenutz, LloydV, Loneman, longmire, Lopan
- lovetheguitar, Lowtech, ludolf, luisgcan, Lumenmaster17, Lumens Industry, lumiere, Lund1660, luongshot, luxlad
- lyse99, Lyubo Yanev, M4D M4X, M78, MACS0647, MAD TM26, Magbrite, magnet, MagPap, Maiden666
- maildroid, Majoroverkill, malamask, MaleNurse, mandala, Manheim69, manithree, Manulous, ManWithoutShadow, Mapache
- Marcello, marcus_z, markalike, Marothar, marsalla, Martini, martook, martytown, Masejoer, Matchoo
- matkovicha, Matomoto, mattlward, MauiSon, maukka, Maxxsounds, MBuitendorp, mcfarlie6996, MCT, Mecallie
- MechEngVictor, Medvegy, Melven, meti, metz3006, Meyer, mezzmen7, MG, mhanlen, mi bill
- Micael, mightybonk, Miguel_79, Miguelintegral, Mike72, mikeyx, Mindaugass, Minimoke, miraclenip, miswas
- Mitko, mitrhandir, mizjif, Mkduffer, mlodyulek, moemin, MontyPyfon, moridin, Morpheus, MorpheusT1
- MortyDuck, MountainKing, MountainMan, mozart.f, Mr.Poppy, Mr.Scott, mrheosuper, mrkelvin, MRsDNF, mrstealyourgains
- msg1285, Mstevens113, Mt.B, MtnDon, mud_muncher, mudguts, muellihenry, Muto, mutts13, muzzleblast?
- mxlu, MyDangus, myowin, myst999, nanojack, narin000, Nathan42, Navin_R_Johnson, NavyHammer, neckbear
- needmorlts, Neilyboy, netprince, Newlumen, nexrace1, nfetterly, Nguyen, nickdude, Nickke, Nicolaas
- Nicolicous, Night Light, NightLight, Nightshade, niktak11, Nil, Nine9n1ne, nishayume, Nite Shadow, Nitetime
- nitrader0, nnmnu1, No Agenda, nodoubt, noetik, nofear87, Noki, noob, Nord, nordlicht
- Nortson, novice1, nqcken, nskn71, NuggetMcNugget, ObiWan-Kenobi, octav, OdorlessCurves, Ohmypotatoes, ohnonothimagain
- olivedrab, OrangePeel, orinjuse, Orionz23, osb40000, OscarM, Oswald3211, oto, Ozythemandias, Pablogy
- PabloVerde, pacbough, Paetrw, papaslightsaber, patchythepirate, patman, patmet, patmurris, Paul321, pawwright
- PBWilson, peabody, Peetz, Pegaso, Peho, pelle470, Penguin, pepe2017, pepinfaxera, perche
- Perdu, peterlcole, peteybaby, petr9999, Petroleum Lantern Guy, Phantom1, Phoenix_FIN, PickleFuzz, Pidro, pieman7
- Pin8, pirate joe 22, pistol86, piyoman, plntigrado, pommie, pook, pooptoast, powerfultorches, praveendk
- prdonut2k7, prepro, presterjohn, Presumptuous, Primal, prisma, Prodeje79, Prometheus, ProtaBLF, pscal
- puccio1969, Pukachi, pukoid, Pulsar13, qandeel, qBawl, R.D., radb, rag, Ragsy
- raiko, rajun50, ramius, Randolph, RapidLux, raqin, Rat_Racer, RaVeN, raynman, rdoc613
- ReallyInToCheese, red72vw, RedForest UK, redrider706, regaia, reliant_turbo, ReManG, reno, retiro675, rexdog
- rfd673, ricardon, Ricflair, Rick, rizky_p, rjorge, rmkline, Rob_K, robbobus, Roberrt777
- RobertB, rocketshipdog, RocketTomato, RockHugger, RoloFresh, Romey310, RonMuller, rossysarus, Roter, RotorHead64
- rova2014, Royo, Rpdos, Rska, Rsqweezy, rufrydr, Rufusbduck, Rxich, ryukin2000, sac02
- saf99, Saigon, saintsagan, SamHaLeKe, samis, samnavy, san san, sandanbob, Sarge930, Savydude
- SawMaster, saypat, sb56637, scarnific, scdaf, Schkü, schlockproof, Schoki, Sciencetists, SciFiFreak
- Scooby, Scooter000, scootypuffjr, Scorpia, scotlarock, Scottland, Scotty, scs, sebastiang, SebaZ74
- SeenTheLight, SFB, Sgtpev, Shadowcactus, Shadowfax, Sharpie, shimano3000, shimey, shirnask, Shoe
- shogan, Shur, SIGShooter, Silent_Star, Silentcropduster, Simplelight, slackwolf, slatzman, Sledge, Sledgestone
- slickpenguin, slimkango, slow2go, smed1275, Smittymojo, SmokinH, sneakyfart007, Snoballz, SoCalTiger, sochi111
- Sofa, sol, SolarLumen, solRNY, somnambulism, Sonpham, Sordoslux, southland, sp5it, spade413
- sparkyDK, specialk, Speed4goal, Speedsix, spinynorman, spkzzz, Sprinkles, square74, srs2000, stanley-beamish
- starcrazed, stareye, staticx57, steel_1024, Steenbhg, steepdrop, Stephen Elliott, stephenk, steve-o, steve42
- Stevejj, SteveMidwest, stevez32, StinkyTool, Stittville Ed, Stoneface, strango, strayz, Streamer, strmix
- strobed, Stud_nut, SubSailorVet, Subterrestrial, Sukoi, Sullysat, Suncoaster, Swennie, Syncmasterklop, syracuse
- T-boon, T18, t3rminal, Tadashi, Tally-ho, tapir, tarver, Tarvos, tas69, tatasal
- teacher, tebeve, techieman33, Tecmo, tekwyzrd, tenohfive, Terry White, Tete, Texas_Ace, The Burgh
- The Grand Pooh-Bah, The Imp, The Jinx, The Last Katun, The Miller, The_Driver, thebaum, TheConsultant, thecrc, TheDude
- TheHebrewHammer, TheJo, Thekernels, TheLonelyLumen, themacman4, TheMadcap, themagicconch, themaindude, TheManMKD, Theodore41
- theoldbill, TheOnlyDocc, thijsco19, tigris99, tim_duncan, timcodes, tindrum42, tinowrx, Tixx, Tjhosan
- Tjohn, Tmik, tmxod, Toccata, tocirahl, Tom E, Tom_182, Tomogchi, tomtaylor, tonylim
- torchjunkie, toxiccoccyx, ToyKeeper, tracerfire, Trashman531, Trasnodel, trevglas, trevize, treysoucie, tristanxoxo
- troisanh, tronx, TRoPHeuS, tru3s1lv3r, tucsonmike, tugboatcar, Tunerman, tungkon, TurboLion, turbopscl
- turpulator, tzmxxhh, ubermoo, Ulric, unit311, unknown00101, uqs1000, Vagany, VaKo, Valdorg
- Van, Vanq86, vas, vasa_visost, Vattern, velocraig, vex_zg, Viamede, vinte77, vitriolix.com
- Volks1973, vulpes, vwpieces, w4rkry, Wackyvegan, walty, WarHawk-AVG, warzi1975, wattstar, WaylonJennings
- wb, websterjody, weklund, Werner, WestBam, westcoastwonders, what_are_birds, whitecitadel, Whitty05, Wieselflinkpro
- Wildcat, wildmermaid, Wildthing, willmo, WillyD, wilwok, Wineslurper, wisefire, wishiwereaskibum, wkhchin81
- Wojto, WolfA, Wrathbringer27, wunderhe, Wyre, X0R, Xandre, xCentrino, xed888, xelario
- xjsnake, xray291, xsosx, xtrosity, XXX-Man, xzel87, yasenf, yclongthrow, YoFlash, Yokiamy
- Yourrid, zachary6227, zak.wilson, Zanders, zara, zelee, Zeratull, zeremefico, zeroair, zifzif
- zipelgas, zoysiamo, ZozzV6, Zteduh, Zulumoose, ×73rmin8r,
Over 6200 lumens with the right batteries, i think its also mentioned in one of the first posts.
Thanks I can’t wait to get this …be almost or better than my thrunight 36 ut
