I couldn’t wait that much longer and I’ve only been following this thread since before I made an account a few months ago.
What’s the status on the production videos did they send more? I’m interested. I liked the Olight factory tour.
With a brass ring for a contact pad on the driver, the button top or solder hump is required to ensure the positive end of the cell makes good contact. I don’t think there’s a short circuit issue potential with this one, as there have been with some other’s that used this contact ring style, but the wrapper on the cell could interfere with a solid contact and cause current drop or lack of connection at all. So, button top or a slight solder bump and then it’s up to you any number of top listed cells depending on what your goal is. ![]()
+1 DB. SANYO GA flat tops work because they have a protruding + cell top, but most stock flat tops won't work. The springs have been improved (higher, stiffer) but there's been no prototype testing of them. So I'm thinking the GA flat tops should be more reliable than they were in the prototypes, but still not sure about handling a jolt, like mounted on a bike.
Yes I can’t render the video I made from the four bits of short production videos Barry send.
Also the pics won’t show on tinypic
Will check it all tomorrow morning and if needed post the short videos on my YouTube and in this thread.
So in 12-14 hours you all can see some production stuff going on ![]()
FWIW, since the solder bump can flatten over time (being soft solder) I found some small copper buttons and soldered them onto Sony VTC6 cells in a light that needed that button top. This way the copper button makes good solid contact, has excellent resistance properties, and won’t change much if at all over time. It’s not much difference as far as the cell is concerned than putting a solder blob on it. (as far as heating of the cell goes)
This is actually two of the buttons on each cell, as required by this specific light to work. ![]()
Please: Link? if possible.
I want to buy these copper buttons.
Greetings.
Pepin from the Faxera
iirc he didn’t really have a source, or it was a while ago and the source dried up. You can get thick copper wire and slice it to make copper nubs. MTN also has these, they’re tiny, but if you only need an extra little bit they should work. There are lots of homebrew buttons you could make with some conductive materials + time.
I have a couple sets of 4 Keeppower 3400 mah PROTECTED button top batteries.Will these work in the Q8 and and the GT ??? or should I buy any of the below.i would not mind a decrease in performance due to protection in battery
MJ1’s
30Q’s
GA’s
Please advise at the earliest.
I have someone in the USA coming to India. (Will order through them).
There is no shipping method for batteries and knives for India.
Thanks not cheers !!!
-DK
Ok what is the lumen output on this masterpiece?
The keeppowers probably use NCR18650B. Those should be fine for the GT (as long as the voltage drop over the springs is sorted out) but I wouldn’t use them for the Q8
I don’t know if Dale bought them or made them. I bought one of these for a previous project, With a sheet of copper, you can make as many of them as you would like at whichever size you choose. I realize that you are not in the states, but a metal hole punch should be available on you side of the pond as well.
The Q8 list (from post #1) sorted alphabetically .
(As of post #9994)
| 2 DOGS | 186 | |||||||||
| 264 | 641 | |||||||||
| 2Ace | 165 | 1119 | ||||||||
| 5ar | 697 | |||||||||
| 7pot | 982 | |||||||||
| a12luke | 932 | |||||||||
| a_idiot | 740 | |||||||||
| Aardvark Spleen | 253 | 402 | 403 | |||||||
| aaronchen | 1510 | 1511 | ||||||||
| Abe87 | 876 | |||||||||
| Abqjohnny | 51 | 1169 | ||||||||
| abril | 50 | |||||||||
| acml | 1455 | |||||||||
| acruzangels | 1429 | |||||||||
| ada_potato | 1379 | 1411 | ||||||||
| adirondackdestroyer | 545 | |||||||||
| adrianlights | 255 | |||||||||
| adsum | 1477 | |||||||||
| AEDe | 923 | |||||||||
| Ag76 | 1345 | |||||||||
| aggillator | 458 | |||||||||
| aginthelaw | 278 | |||||||||
| Agiri | 110 | |||||||||
| Agro | 1488 | |||||||||
| aim120 | 430 | |||||||||
| AirBreaker | 155 | |||||||||
| akhyar | 387 | |||||||||
| akoposilester | 56 | 1111 | 1112 | |||||||
| akovia | 937 | |||||||||
| alberto7 | 1492 | |||||||||
| albertopnp | 365 | |||||||||
| Alcius | 105 | |||||||||
| alejandrov | 523 | |||||||||
| alex64 | 1159 | |||||||||
| AlexGT | 495 | |||||||||
| Alkpwn77 | 204 | |||||||||
| allthumbs | 218 | |||||||||
| alphazeta | 335 | |||||||||
| alternety | 564 | 565 | ||||||||
| Alux | 702 | |||||||||
| amplificus | 904 | 983 | 984 | |||||||
| Andmiller | 1064 | 1065 | ||||||||
| andrewmac | 407 | |||||||||
| Andybibbville | 147 | |||||||||
| Andyman? | 13 | |||||||||
| Angel Martínez | 128 | |||||||||
| ant0 | 1195 | |||||||||
| Antenne | 801 | |||||||||
| Anthon | 568 | |||||||||
| antilop65 | 1448 | |||||||||
| antiparanoico | 32 | |||||||||
| AntLion13 | 1454 | |||||||||
| aors10 | 1487 | |||||||||
| AppA | 1208 | |||||||||
| aprendiz | 1160 | 1261 | ||||||||
| apt323 | 47 | 544 | ||||||||
| archi | 1157 | |||||||||
| archimedes | 67 | |||||||||
| arditty | 1577 | |||||||||
| aremihc | 910 | |||||||||
| ARMS.AARON | 1089 | |||||||||
| ARsee | 1228 | 1229 | ||||||||
| Arufonsi | 921 | |||||||||
| aslpg | 398 | |||||||||
| asnidi2 | 1327 | |||||||||
| asot | 690 | |||||||||
| Astromanic | 424 | |||||||||
| AsylumSweep | 863 | |||||||||
| atbglenn | 567 | |||||||||
| Atom00 | 358 | 359 | ||||||||
| Aurora | 1587 | |||||||||
| Autistic | 1532 | 1533 | ||||||||
| Autoclave | 1099 | |||||||||
| autodidact | 1503 | |||||||||
| Awdtsi | 1221 | |||||||||
| Awkward Stretch | 619 | |||||||||
| AwkwardPause | 464 | |||||||||
| b1i1l1l1y1 | 1052 | |||||||||
| B42 | 685 | 686 | 1019 | 1020 | ||||||
| BackpackNY | 571 | 1084 | ||||||||
| bakalakos | 202 | |||||||||
| balazs1956 | 1341 | |||||||||
| baldo21 | 260 | 261 | ||||||||
| Bam35 | 1039 | |||||||||
| bamawthu | 599 | |||||||||
| banker | 1013 | |||||||||
| basslovin808 | 446 | |||||||||
| Bastarrdo | 117 | |||||||||
| Batch1 | 293 | 344 | ||||||||
| battletross | 809 | |||||||||
| bawilson2 | 500 | 501 | ||||||||
| Bc412 | 5 | |||||||||
| bd52 | 399 | |||||||||
| BDM | 1018 | |||||||||
| Bdubelyew | 1542 | 1543 | ||||||||
| BDWrabbit | 1244 | |||||||||
| beam0 | 1424 | |||||||||
| BeardedRaleigh | 662 | |||||||||
| bella-headlight | 49 | 411 | 877 | |||||||
| Bernard | 232 | |||||||||
| Bevo | 1086 | |||||||||
| bhuge00 | 1049 | |||||||||
| bickle | 1463 | |||||||||
| bigpix | 84 | |||||||||
| bigrick | 754 | |||||||||
| bikedave99 | 1174 | |||||||||
| bikenber73 | 14 | |||||||||
| Bill 63 | 752 | 1296 | ||||||||
| Bill_tong | 896 | |||||||||
| Billcheese5 | 949 | |||||||||
| BingoThink | 1537 | |||||||||
| bionictony | 1338 | |||||||||
| bkling | 1067 | |||||||||
| BlackList | 1350 | |||||||||
| bladesmith3 | 607 | |||||||||
| BLFD80 | 933 | |||||||||
| BLightSam | 1443 | |||||||||
| BlindingL5s | 312 | |||||||||
| blinker | 1306 | 1353 | ||||||||
| blinky | 1209 | |||||||||
| blueb8llz | 70 | 553 | 1120 | 1121 | 1122 | 1123 | ||||
| bluecheesbob | 1557 | |||||||||
| Bluzie | 785 | |||||||||
| bmaddison | 248 | |||||||||
| Boaz | 391 | |||||||||
| BobbyMK | 462 | |||||||||
| bobdotorg | 1271 | 1272 | 1427 | 1428 | ||||||
| bobofire | 1313 | |||||||||
| Bogdan | 370 | 371 | ||||||||
| bogdanr | 466 | |||||||||
| Bohemian | 775 | |||||||||
| bonfire | 412 | |||||||||
| Bong lick | 763 | 1075 | ||||||||
| Bonham | 262 | |||||||||
| borealis | 1098 | |||||||||
| BorisBar | 575 | 1238 | ||||||||
| Boro | 360 | 361 | ||||||||
| bossf350 | 803 | |||||||||
| Box | 671 | |||||||||
| boxuvrox | 1559 | |||||||||
| Brettg4215 | 864 | |||||||||
| brewskVT | 1449 | |||||||||
| Brian Metcalfe | 318 | 319 | 374 | |||||||
| brianch | 1450 | |||||||||
| BrianK | 447 | 560 | 1356 | |||||||
| BrianTheJay | 950 | |||||||||
| Bribo | 1582 | |||||||||
| brightlights | 243 | |||||||||
| brittnell | 1523 | |||||||||
| brjones | 504 | |||||||||
| brno602 | 913 | |||||||||
| brted | 249 | |||||||||
| brujeria | 1578 | |||||||||
| Bruno28 | 513 | |||||||||
| BT100 | 1087 | 1138 | ||||||||
| Bungle88 | 610 | |||||||||
| Buzzy243 | 1179 | |||||||||
| bwl123 | 870 | |||||||||
| cabfrank | 443 | |||||||||
| Caleb | 203 | 547 | ||||||||
| Caleb-v | 444 | |||||||||
| Calmaja | 35 | |||||||||
| Candil | 1397 | 1418 | ||||||||
| Cano | 661 | 1151 | ||||||||
| Captainvideo | 1302 | |||||||||
| caramba | 748 | |||||||||
| carmantl | 345 | 346 | ||||||||
| casi29061965 | 467 | 490 | 1409 | |||||||
| Catul | 1441 | |||||||||
| cavesprings | 1406 | |||||||||
| cavorite | 1028 | |||||||||
| Cawi | 1276 | |||||||||
| cbrake10 | 749 | |||||||||
| cccpull | 1496 | 1497 | 1498 | |||||||
| cclight | 897 | |||||||||
| cdjaney | 825 | |||||||||
| Chadvone | 63 | 693 | ||||||||
| Charga | 124 | |||||||||
| charles lin | 1124 | |||||||||
| CheapThrills | 469 | |||||||||
| cheesecheeks | 816 | |||||||||
| ChibiM | 1310 | 1321 | ||||||||
| Chicken Drumstick | 131 | |||||||||
| chinooker | 1260 | |||||||||
| chooma | 210 | 351 | ||||||||
| chrisc | 741 | 742 | ||||||||
| churchilllafemme | 1230 | |||||||||
| CircaM | 894 | |||||||||
| Cirnyan | 1445 | |||||||||
| CJ Avlis | 1459 | |||||||||
| Cjlee89 | 951 | |||||||||
| cjoe7 | 146 | |||||||||
| CJW | 367 | |||||||||
| clagged | 991 | |||||||||
| clange50 | 479 | 480 | ||||||||
| ClaudeMBallz | 1431 | |||||||||
| clinicdoc | 1226 | |||||||||
| Cliwilnew | 795 | |||||||||
| cloggy | 404 | |||||||||
| cmflippen | 83 | |||||||||
| cnrffl1 | 577 | 1113 | ||||||||
| cocoschnauzer | 363 | |||||||||
| compression | 1410 | |||||||||
| contigo | 1351 | |||||||||
| Coolerness | 664 | |||||||||
| coolriku | 517 | |||||||||
| Corzy | 308 | |||||||||
| Couchmaster | 245 | 551 | 552 | |||||||
| cpd800t | 406 | |||||||||
| CrashOne | 372 | 377 | ||||||||
| Crazyeddie | 98 | 137 | 487 | |||||||
| Creepo | 909 | |||||||||
| cristhemuso | 388 | |||||||||
| crx88ia | 683 | |||||||||
| cujo255 | 1191 | |||||||||
| cwb | 134 | |||||||||
| cypher1024 | 973 | |||||||||
| cypherz | 250 | |||||||||
| Cythras | 956 | |||||||||
| D10ten | 608 | |||||||||
| Dadpool | 1161 | |||||||||
| dafarui | 1339 | |||||||||
| Dakotan2 | 1549 | 1550 | ||||||||
| daninho | 468 | |||||||||
| DarkerInSol | 615 | 616 | 617 | 618 | ||||||
| darkpenguin | 718 | 719 | 735 | 736 | 737 | 738 | 739 | 860 | 861 | 862 |
| darol | 798 | |||||||||
| darrenm | 1054 | 1055 | ||||||||
| darrylo | 507 | |||||||||
| DarthTader | 830 | |||||||||
| datiLED | 761 | |||||||||
| dave101 | 1041 | |||||||||
| DavidEF? | 7 | |||||||||
| davidkappelt | 1026 | |||||||||
| davidvns | 1128 | |||||||||
| davos | 1062 | |||||||||
| DB Custom | 713 | 722 | 997 | |||||||
| dbesselt | 1156 | |||||||||
| DBSAR | 136 | 169 | 1281 | |||||||
| DBSS | 516 | 779 | ||||||||
| deathless | 518 | |||||||||
| Deep skull | 977 | |||||||||
| DeJaVu | 669 | |||||||||
| dekozn | 800 | |||||||||
| Dennis | 934 | |||||||||
| dentillozie | 488 | |||||||||
| Dep668 | 687 | 688 | ||||||||
| derfyled | 1237 | |||||||||
| derpilgerer | 630 | |||||||||
| Desmo | 805 | |||||||||
| devdvr | 486 | |||||||||
| Dewalt101 | 1552 | |||||||||
| dezoe | 1186 | |||||||||
| dglb99 | 1553 | |||||||||
| dhsvcs | 265 | 1336 | 1337 | |||||||
| dicksog | 559 | |||||||||
| digitalMessiah | 1566 | |||||||||
| digitaltc | 1323 | 1401 | ||||||||
| Dimking | 425 | |||||||||
| Dirt | 815 | |||||||||
| Dirty_Pierre | 1045 | |||||||||
| DiscoJoe | 1254 | |||||||||
| djburkes | 188 | 878 | ||||||||
| Djozz | 3 | 1115 | 1286 | |||||||
| dmbaty | 1294 | |||||||||
| Dobtruckers | 1058 | |||||||||
| DOCFAR | 595 | |||||||||
| Docp723 | 347 | 433 | 434 | |||||||
| Doctawho | 440 | |||||||||
| dodo | 88 | 274 | ||||||||
| dogany | 813 | |||||||||
| Dogsrule | 508 | |||||||||
| donpachi | 1252 | |||||||||
| dotBLF | 968 | |||||||||
| doubleone44 | 887 | |||||||||
| downlinx | 74 | 316 | ||||||||
| doxerino | 1304 | |||||||||
| Dr Forinor | 873 | |||||||||
| Dradge | 1248 | |||||||||
| Dralf | 1015 | |||||||||
| Dregs | 172 | |||||||||
| DrHook59 | 883 | |||||||||
| driveX | 659 | |||||||||
| DrJones | 75 | |||||||||
| DrMcNinja17 | 1507 | 1508 | ||||||||
| DT101 | 152 | |||||||||
| dudunphy | 389 | |||||||||
| duhduhduhdiabeetus | 1461 | |||||||||
| Duke | 381 | |||||||||
| dukeface13 | 1460 | |||||||||
| dumptruck | 971 | |||||||||
| Dusty | 327 | 328 | ||||||||
| Dutcheee | 68 | 322 | ||||||||
| duvallite | 889 | |||||||||
| dw911 | 478 | |||||||||
| Dwantink | 135 | |||||||||
| e10sno | 405 | 1318 | 1319 | |||||||
| Easyrr | 6 | |||||||||
| eb1888 | 837 | 838 | 839 | |||||||
| ebosh | 777 | |||||||||
| eddamoo | 1574 | |||||||||
| ediaz | 906 | |||||||||
| eebowler | 774 | |||||||||
| Eggun | 1104 | 1312 | ||||||||
| egrep | 594 | |||||||||
| Eivwer | 171 | |||||||||
| electricjelly | 237 | 256 | ||||||||
| ElginAgain | 1204 | 1362 | 1394 | 1395 | ||||||
| emarkd | 109 | |||||||||
| embee | 511 | |||||||||
| Enelooper | 417 | |||||||||
| engber | 947 | |||||||||
| ERDOS | 1150 | |||||||||
| Erethryn | 1259 | |||||||||
| erikk365 | 648 | |||||||||
| Esskay | 995 | |||||||||
| Etex | 829 | |||||||||
| etienne440 | 1516 | |||||||||
| euphxenos | 408 | |||||||||
| everydaysurvivalgear | 103 | |||||||||
| Evilc | 65 | |||||||||
| Evo1986 | 1554 | 1555 | ||||||||
| ExtrabrightExtracheap | 1432 | |||||||||
| Eyao | 1529 | |||||||||
| EyeballFryer | 189 | |||||||||
| Fadetoblack | 1295 | |||||||||
| fantomR | 636 | |||||||||
| Far Thrower | 148 | 197 | ||||||||
| Farmboy24 | 1234 | |||||||||
| Farns | 277 | |||||||||
| Fatlight | 663 | |||||||||
| fatsteve0 | 1361 | |||||||||
| FBsLights | 790 | |||||||||
| fcrespi | 1262 | |||||||||
| fed893 | 307 | |||||||||
| fedcas | 902 | |||||||||
| feralcomprehension | 1194 | 1311 | ||||||||
| ferthur | 1458 | |||||||||
| Festizio | 1515 | |||||||||
| FindThisHumerus | 1466 | |||||||||
| finges | 561 | |||||||||
| fireblade893 | 209 | |||||||||
| firedome | 324 | 711 | ||||||||
| Firelight2 | 397 | |||||||||
| fischju | 1462 | |||||||||
| fishlite5 | 1046 | |||||||||
| fixed it | 78 | 1097 | ||||||||
| fixvid | 1264 | |||||||||
| Flash Voyager | 652 | |||||||||
| Flash-O-Maniac | 1414 | |||||||||
| flashination | 87 | |||||||||
| FlashMax | 1225 | |||||||||
| Flashy Mike | 239 | 410 | 448 | 449 | ||||||
| flatbear | 1451 | |||||||||
| Flifish48 | 806 | 1096 | ||||||||
| Flintrock | 629 | |||||||||
| fluffman86 | 958 | |||||||||
| FmC | 1182 | |||||||||
| fonfan | 234 | 1023 | 1024 | |||||||
| fonLED | 725 | |||||||||
| Ford Prefect | 1068 | |||||||||
| Foston Pete | 453 | 454 | 644 | |||||||
| foton | 1030 | |||||||||
| fourtogaraffia | 1446 | |||||||||
| Fozzy-SP | 317 | |||||||||
| Frank A. | 1172 | |||||||||
| Frankie Baby | 342 | |||||||||
| Franz | 788 | |||||||||
| Freddy61069 | 282 | |||||||||
| Fredylee | 223 | 1329 | ||||||||
| FreeMagenta | 1050 | |||||||||
| freeme | 514 | |||||||||
| freethink | 1484 | |||||||||
| Fritz t. Cat | 484 | |||||||||
| Funzel67 | 990 | |||||||||
| fuzun | 1074 | |||||||||
| fyesilova | 535 | |||||||||
| g17jimmy | 1440 | |||||||||
| g60 | 290 | |||||||||
| g_sintornillos | 126 | |||||||||
| gamezawy | 38 | 336 | ||||||||
| Gammel | 1544 | |||||||||
| gangstead | 53 | 922 | ||||||||
| garrybunk | 254 | |||||||||
| gboss | 832 | |||||||||
| gds95 | 1199 | |||||||||
| gearowl | 1415 | |||||||||
| gedasd | 1309 | |||||||||
| geepaw | 1038 | |||||||||
| Geese | 1575 | |||||||||
| gehrmo | 289 | |||||||||
| geo1952 | 455 | 457 | ||||||||
| ger-slash | 416 | |||||||||
| Gerrh | 531 | 1163 | 1164 | 1285 | ||||||
| Gerrit | 106 | |||||||||
| getbully | 609 | 1263 | ||||||||
| GF357 | 1509 | |||||||||
| Gilatabar | 638 | |||||||||
| giorgoskok | 306 | 493 | 1092 | |||||||
| GIR | 804 | 818 | ||||||||
| gisewhcs | 384 | |||||||||
| Givememyhatback | 1520 | |||||||||
| Gj | 580 | 581 | ||||||||
| Gladimir_Gluten | 1585 | |||||||||
| gleamer | 432 | |||||||||
| GlinnDamar | 1342 | |||||||||
| gnatx | 588 | 824 | ||||||||
| goatfarmer | 770 | |||||||||
| gokalpm | 1393 | |||||||||
| GoldenBatt | 383 | 589 | 590 | |||||||
| gorb507 | 811 | 812 | ||||||||
| goshdogit | 11 | 12 | 40 | 120 | 121 | 543 | 556 | 928 | ||
| Goud | 1468 | |||||||||
| gpapa693 | 79 | |||||||||
| gravelmonkey | 1027 | |||||||||
| green_comet | 601 | |||||||||
| GreenShrike | 190 | |||||||||
| gregfortune | 1576 | |||||||||
| gregor | 215 | |||||||||
| Grieflar | 1491 | |||||||||
| GTsuperheros | 179 | |||||||||
| Gtt980 | 936 | |||||||||
| guerrilla154 | 1316 | 1422 | ||||||||
| Guggga | 538 | |||||||||
| GulfCoast | 880 | |||||||||
| gungoat | 44 | |||||||||
| Gunnerboy | 252 | 967 | ||||||||
| Guns712 | 1300 | 1301 | 1369 | 1370 | ||||||
| h2o | 181 | 476 | ||||||||
| Hairy_Steve | 340 | 1367 | ||||||||
| hank | 258 | 1385 | ||||||||
| Hardware | 1071 | 1200 | ||||||||
| Hauwexis | 845 | 846 | 847 | 848 | ||||||
| haxquiz | 226 | 927 | ||||||||
| headburger | 592 | |||||||||
| heatwaves | 994 | 1265 | ||||||||
| hein11ag | 183 | |||||||||
| Herb Tarlek | 931 | |||||||||
| Hestbech | 994 | 995 | ||||||||
| hexcode | 503 | 672 | ||||||||
| Hezekiah | 286 | 759 | ||||||||
| hideehoo | 859 | |||||||||
| HighCaliber | 177 | 178 | ||||||||
| hmihaylov | 502 | |||||||||
| Hobo | 220 | |||||||||
| hunter1 | 116 | 720 | 721 | |||||||
| hurleyy | 993 | |||||||||
| I_like_lamb | 915 | |||||||||
| Ian2381 | 150 | |||||||||
| igeigeige | 890 | |||||||||
| IH8MYX | 546 | |||||||||
| ii_pennies | 481 | |||||||||
| ikaruz_500 | 989 | |||||||||
| ikkentobi | 1423 | |||||||||
| Illumenated | 426 | |||||||||
| illusioned | 954 | |||||||||
| Ilmatic | 1253 | 1332 | 1493 | |||||||
| ilovejesuschrist | 294 | 295 | ||||||||
| ImA4Wheelr | 19 | |||||||||
| ISO | 705 | 734 | 929 | 930 | ||||||
| Itsme | 1495 | |||||||||
| iwandutchy | 1047 | |||||||||
| J-Dub74 | 461 | |||||||||
| J_R_J | 675 | |||||||||
| jack-bkk | 356 | |||||||||
| jacktheclipper | 1108 | |||||||||
| Jailbrake | 1034 | 1090 | ||||||||
| JakeDjanitor | 46 | |||||||||
| Jalben | 187 | |||||||||
| jama | 635 | |||||||||
| Jambo | 912 | |||||||||
| james y | 1043 | 1044 | ||||||||
| JaredP | 1570 | |||||||||
| jarfield | 1558 | |||||||||
| JasonWW | 1399 | |||||||||
| javipiloto | 1154 | |||||||||
| jaynick | 1048 | |||||||||
| JayT | 62 | |||||||||
| JayWallis | 1387 | 1388 | ||||||||
| Jayzed | 1214 | |||||||||
| jb1 | 224 | |||||||||
| jbailey94 | 1586 | |||||||||
| jctron | 1489 | |||||||||
| jdunlap27284 | 164 | |||||||||
| jealous57 | 81 | |||||||||
| jeanlouis | 1478 | |||||||||
| Jeffstanton | 1380 | 1381 | 1382 | |||||||
| Jensa41 | 731 | 732 | ||||||||
| Jerommel | 637 | |||||||||
| jerrod | 512 | |||||||||
| jescereal | 228 | |||||||||
| Jesjes | 153 | 154 | ||||||||
| jfalk1 | 918 | |||||||||
| jhalb | 297 | |||||||||
| JHost13 | 1583 | |||||||||
| jhullin | 159 | 751 | ||||||||
| JIGHEADWORM | 1413 | 1420 | ||||||||
| jingleberry | 1022 | |||||||||
| Jinx | 93 | |||||||||
| jkbam | 550 | |||||||||
| JLAu | 1421 | |||||||||
| JM87 | 1470 | |||||||||
| jmoots | 268 | |||||||||
| jmpaul320 | 95 | 299 | ||||||||
| jmwhite151 | 482 | 851 | 852 | 853 | ||||||
| Joat | 184 | |||||||||
| JockRobbins | 717 | |||||||||
| Joe Darkness | 620 | |||||||||
| joe1512 | 534 | |||||||||
| joeangi | 756 | 1390 | 1391 | 1392 | ||||||
| joechina | 633 | 1437 | ||||||||
| Joey Adams | 1021 | 1132 | ||||||||
| John-Galt | 463 | |||||||||
| Johnhywash1 | 966 | |||||||||
| johnnydoe | 1227 | |||||||||
| JohnnyMac | 496 | |||||||||
| johnpc | 955 | |||||||||
| johny723 | 1082 | |||||||||
| Jonandreadolan | 1072 | |||||||||
| JonnyC | 576 | |||||||||
| JordanZHP | 1078 | 1196 | ||||||||
| JorisFRST | 1404 | |||||||||
| josephqool | 1061 | 1417 | ||||||||
| jpcuba | 684 | |||||||||
| JPLight | 23 | 646 | ||||||||
| JPM3 | 263 | 264 | ||||||||
| jrummer | 1439 | |||||||||
| JS721 | 216 | |||||||||
| jsmn4vu | 793 | |||||||||
| jtechl | 1513 | 1514 | ||||||||
| Jtm94 | 1035 | |||||||||
| Juanesdan | 118 | |||||||||
| juaquin | 219 | |||||||||
| Juggeli | 745 | |||||||||
| juhha | 1540 | |||||||||
| JulioElGuapo | 1526 | |||||||||
| Jump909 | 1569 | |||||||||
| jurasik1 | 1231 | |||||||||
| justanotherguy | 541 | 712 | 1080 | |||||||
| Jvrthp321 | 691 | |||||||||
| jycheang | 1009 | |||||||||
| k-wong | 542 | 1005 | ||||||||
| Kafar | 9 | |||||||||
| kahvitahra | 796 | |||||||||
| Kalchev | 400 | |||||||||
| kali stupa | 1217 | |||||||||
| Kalihi | 836 | |||||||||
| kalkat | 1373 | |||||||||
| KawiBoy1428 | 230 | |||||||||
| kaybi | 1033 | |||||||||
| Kazik | 1315 | |||||||||
| kbmeister | 1589 | |||||||||
| kbro | 168 | |||||||||
| keengeorge | 309 | 310 | ||||||||
| KeepingItLight | 992 | |||||||||
| Keepitsharp | 175 | |||||||||
| Keisari | 1211 | 1212 | ||||||||
| keithd | 753 | |||||||||
| kemosabi | 1438 | |||||||||
| KenE | 355 | |||||||||
| Kenjii | 385 | |||||||||
| Kentuckywindage | 797 | 872 | ||||||||
| Kepling | 333 | |||||||||
| kevinfc | 1426 | |||||||||
| KFulton | 1331 | |||||||||
| khas | 628 | |||||||||
| Khuan | 1148 | |||||||||
| KIKY | 1340 | |||||||||
| Killforfood | 272 | 379 | ||||||||
| Kindle | 698 | |||||||||
| KingSmono | 578 | |||||||||
| kiriba-ru | 525 | |||||||||
| Kiukas | 640 | |||||||||
| KiwiKane | 174 | |||||||||
| Kkelleher | 99 | 100 | 101 | 102 | ||||||
| Kloepper Knife Works | 194 | 195 | 196 | |||||||
| knightstalker | 1219 | |||||||||
| kntx | 1073 | 1116 | 1189 | |||||||
| knudsengj | 1106 | |||||||||
| Koaksijalac | 104 | |||||||||
| Kodachrome40 | 170 | 1282 | ||||||||
| KoekieMonster | 161 | |||||||||
| kommessy | 108 | |||||||||
| korpzgrinda | 1029 | 1133 | ||||||||
| kotobuki | 799 | 1143 | 1144 | |||||||
| koyotee | 276 | |||||||||
| Kozy | 58 | 129 | ||||||||
| krutone | 1298 | |||||||||
| kubed_zero | 1442 | |||||||||
| Kulumatic | 914 | |||||||||
| Kurt_Norway | 593 | |||||||||
| Kusie | 8 | 17 | ||||||||
| KutKhemist | 123 | |||||||||
| Kysumi | 925 | |||||||||
| LAB | 259 | |||||||||
| lachesis | 673 | |||||||||
| lalomt | 1167 | |||||||||
| Lamont56 | 808 | |||||||||
| lamper | 727 | 1171 | ||||||||
| lanceb1b | 884 | |||||||||
| laststance | 972 | |||||||||
| lawallac | 393 | 394 | ||||||||
| Lazy-R-us | 25 | 900 | 1249 | 1250 | ||||||
| Le_Zouave | 71 | |||||||||
| leaftye | 694 | 1103 | 1183 | 1184 | ||||||
| LEDtec | 823 | |||||||||
| legan710 | 1088 | 1476 | ||||||||
| Legolas Jr. | 130 | |||||||||
| leroycp | 236 | 266 | 450 | 451 | ||||||
| Lexel | 696 | 1287 | ||||||||
| Lfatman | 707 | |||||||||
| Liber8 | 537 | |||||||||
| lichtpfadfinder | 1292 | |||||||||
| Light of Earendil | 700 | |||||||||
| lightbulb | 281 | |||||||||
| lightknot | 471 | 492 | 598 | |||||||
| lightlight22 | 772 | 920 | 1040 | 1328 | 1479 | |||||
| LightMan541 | 1469 | |||||||||
| lightmog | 72 | |||||||||
| lightx | 757 | |||||||||
| Lilien | 978 | |||||||||
| Lion42 | 246 | 1408 | ||||||||
| lionheart_2281 | 33 | |||||||||
| litcrit | 871 | |||||||||
| Litefighter | 1320 | 1334 | 1335 | |||||||
| litenutz | 1371 | |||||||||
| LloydV | 767 | |||||||||
| Loneman | 510 | 903 | ||||||||
| longmire | 1256 | |||||||||
| Lopan | 1069 | 1416 | ||||||||
| lovetheguitar | 981 | |||||||||
| Lowtech | 1042 | 1193 | ||||||||
| ludolf | 348 | |||||||||
| luisgcan | 1162 | |||||||||
| Lumenmaster17 | 1145 | 1146 | 1147 | |||||||
| Lumens Industry | 634 | |||||||||
| lumiere | 231 | |||||||||
| Lund1660 | 64 | 439 | ||||||||
| luongshot | 1525 | |||||||||
| luxlad | 831 | |||||||||
| lyse99 | 1012 | |||||||||
| Lyubo Yanev | 427 | 428 | 429 | 536 | ||||||
| M4D M4X | 350 | |||||||||
| M78 | 157 | 337 | 1007 | |||||||
| MACS0647 | 313 | |||||||||
| MAD TM26 | 656 | 657 | ||||||||
| Magbrite | 584 | |||||||||
| magnet | 302 | |||||||||
| MagPap | 794 | |||||||||
| Maiden666 | 92 | |||||||||
| maildroid | 331 | |||||||||
| Majoroverkill | 919 | |||||||||
| malamask | 113 | |||||||||
| MaleNurse | 1472 | |||||||||
| mandala | 952 | 953 | ||||||||
| Manheim69 | 1518 | 1534 | ||||||||
| manithree | 1255 | |||||||||
| Manulous | 1270 | |||||||||
| ManWithoutShadow | 1100 | 1299 | ||||||||
| Mapache | 4 | |||||||||
| Marcello | 1456 | |||||||||
| marcus_z | 1375 | |||||||||
| markalike | 602 | |||||||||
| Marothar | 1236 | |||||||||
| marsalla | 475 | |||||||||
| Martini | 82 | 726 | ||||||||
| martook | 48 | |||||||||
| martytown | 976 | |||||||||
| Masejoer | 842 | |||||||||
| Matchoo | 905 | |||||||||
| matkovicha | 1185 | |||||||||
| Matomoto | 1324 | |||||||||
| mattlward | 16 | 34 | 214 | |||||||
| MauiSon | 42 | 979 | ||||||||
| maukka | 225 | 627 | ||||||||
| Maxxsounds | 681 | |||||||||
| MBuitendorp | 1210 | |||||||||
| mcfarlie6996 | 964 | 965 | ||||||||
| MCT | 162 | |||||||||
| Mecallie | 1051 | |||||||||
| MechEngVictor | 275 | |||||||||
| Medvegy | 660 | |||||||||
| Melven | 167 | |||||||||
| meti | 470 | |||||||||
| metz3006 | 843 | |||||||||
| Meyer | 138 | |||||||||
| mezzmen7 | 1374 | |||||||||
| MG | 353 | |||||||||
| mhanlen | 77 | |||||||||
| mi bill | 127 | |||||||||
| Micael | 858 | |||||||||
| mightybonk | 1535 | |||||||||
| Miguel_79 | 1114 | 1129 | ||||||||
| Miguelintegral | 1175 | |||||||||
| Mike72 | 1403 | |||||||||
| mikeyx | 622 | |||||||||
| Mindaugass | 769 | 1081 | 1490 | |||||||
| Minimoke | 30 | 975 | ||||||||
| miraclenip | 1547 | |||||||||
| miswas | 760 | |||||||||
| Mitko | 26 | 27 | ||||||||
| mitrhandir | 1303 | |||||||||
| mizjif | 714 | |||||||||
| Mkduffer | 600 | |||||||||
| mlodyulek | 1283 | |||||||||
| moemin | 375 | |||||||||
| MontyPyfon | 66 | |||||||||
| moridin | 907 | |||||||||
| Morpheus | 613 | |||||||||
| MorpheusT1 | 762 | |||||||||
| MortyDuck | 764 | |||||||||
| MountainKing | 438 | 445 | ||||||||
| MountainMan | 786 | 787 | ||||||||
| mozart.f | 314 | |||||||||
| Mr.Poppy | 192 | 267 | 1247 | 1308 | ||||||
| Mr.Scott | 251 | 1077 | ||||||||
| mrheosuper | 1110 | |||||||||
| mrkelvin | 606 | |||||||||
| MRsDNF | 325 | 326 | ||||||||
| mrstealyourgains | 1014 | |||||||||
| msg1285 | 173 | |||||||||
| Mstevens113 | 114 | |||||||||
| Mt.B | 392 | |||||||||
| MtnDon | 158 | 498 | ||||||||
| mud_muncher | 624 | |||||||||
| mudguts | 680 | 716 | ||||||||
| muellihenry | 1396 | |||||||||
| Muto | 20 | 242 | 689 | |||||||
| mutts13 | 1343 | 1348 | ||||||||
| muzzleblast? | 89 | |||||||||
| mxlu | 396 | |||||||||
| MyDangus | 1181 | |||||||||
| myowin | 213 | 1235 | ||||||||
| myst999 | 198 | 728 | 1266 | 1267 | ||||||
| nanojack | 1036 | |||||||||
| narin000 | 524 | |||||||||
| Nathan42 | 946 | 987 | 1365 | |||||||
| Navin_R_Johnson | 817 | |||||||||
| NavyHammer | 1588 | |||||||||
| neckbear | 935 | |||||||||
| needmorlts | 911 | |||||||||
| Neilyboy | 1307 | |||||||||
| netprince | 176 | 378 | ||||||||
| Newlumen | 1425 | |||||||||
| nexrace1 | 579 | |||||||||
| nfetterly | 362 | 366 | ||||||||
| Nguyen | 1277 | 1293 | ||||||||
| nickdude | 591 | |||||||||
| Nickke | 604 | |||||||||
| Nicolaas | 857 | |||||||||
| Nicolicous | 270 | |||||||||
| Night Light | 1093 | |||||||||
| NightLight | 369 | |||||||||
| Nightshade | 574 | |||||||||
| niktak11 | 782 | |||||||||
| Nil | 959 | 960 | 1447 | |||||||
| Nine9n1ne | 1436 | |||||||||
| nishayume | 1419 | |||||||||
| Nite Shadow | 1001 | |||||||||
| Nitetime | 163 | |||||||||
| nitrader0 | 1203 | |||||||||
| nnmnu1 | 1349 | |||||||||
| No Agenda | 431 | |||||||||
| nodoubt | 1591 | |||||||||
| noetik | 1572 | |||||||||
| nofear87 | 382 | |||||||||
| Noki | 573 | |||||||||
| noob | 828 | 833 | 1025 | 1386 | ||||||
| Nord | 1170 | |||||||||
| nordlicht | 1541 | |||||||||
| Nortson | 810 | |||||||||
| novice1 | 338 | |||||||||
| nqcken | 119 | 241 | ||||||||
| nskn71 | 1136 | |||||||||
| NuggetMcNugget | 166 | 332 | ||||||||
| ObiWan-Kenobi | 422 | 423 | ||||||||
| octav | 666 | |||||||||
| OdorlessCurves | 529 | 530 | ||||||||
| Ohmypotatoes | 1517 | |||||||||
| ohnonothimagain | 1357 | |||||||||
| olivedrab | 658 | |||||||||
| OrangePeel | 1275 | 1288 | ||||||||
| orinjuse | 835 | |||||||||
| Orionz23 | 1168 | |||||||||
| osb40000 | 193 | |||||||||
| OscarM | 1290 | |||||||||
| Oswald3211 | 724 | |||||||||
| oto | 888 | |||||||||
| Ozythemandias | 625 | |||||||||
| Pablogy | 441 | |||||||||
| PabloVerde | 1037 | |||||||||
| pacbough | 149 | |||||||||
| Paetrw | 1519 | 1563 | ||||||||
| papaslightsaber | 583 | 1125 | 1126 | |||||||
| patchythepirate | 704 | 1364 | ||||||||
| patman | 1521 | |||||||||
| patmet | 1347 | |||||||||
| patmurris | 55 | 1355 | ||||||||
| Paul321 | 139 | |||||||||
| pawwright | 151 | |||||||||
| PBWilson | 557 | 558 | ||||||||
| peabody | 207 | |||||||||
| Peetz | 311 | |||||||||
| Pegaso | 122 | |||||||||
| Peho | 112 | |||||||||
| pelle470 | 1467 | |||||||||
| Penguin | 1433 | 1434 | ||||||||
| pepe2017 | 1305 | |||||||||
| pepinfaxera | 1158 | |||||||||
| perche | 1155 | |||||||||
| Perdu | 1571 | |||||||||
| peterlcole | 924 | |||||||||
| peteybaby | 549 | |||||||||
| petr9999 | 1137 | |||||||||
| Petroleum Lantern Guy | 891 | |||||||||
| Phantom1 | 1372 | |||||||||
| Phoenix_FIN | 395 | |||||||||
| PickleFuzz | 1531 | |||||||||
| Pidro | 465 | |||||||||
| pieman7 | 670 | |||||||||
| Pin8 | 1528 | |||||||||
| pirate joe 22 | 678 | 679 | 783 | 784 | ||||||
| pistol86 | 1378 | |||||||||
| piyoman | 840 | |||||||||
| plntigrado | 1153 | |||||||||
| pommie | 54 | |||||||||
| pook | 330 | |||||||||
| pooptoast | 519 | |||||||||
| powerfultorches | 569 | |||||||||
| praveendk | 437 | |||||||||
| prdonut2k7 | 1579 | |||||||||
| prepro | 1580 | |||||||||
| presterjohn | 586 | 715 | ||||||||
| Presumptuous | 653 | 654 | 655 | |||||||
| Primal | 364 | |||||||||
| prisma | 401 | |||||||||
| Prodeje79 | 1481 | |||||||||
| Prometheus | 1149 | |||||||||
| ProtaBLF | 419 | |||||||||
| pscal | 376 | |||||||||
| puccio1969 | 76 | |||||||||
| Pukachi | 205 | |||||||||
| pukoid | 868 | |||||||||
| Pulsar13 | 288 | 1412 | ||||||||
| qandeel | 631 | 632 | ||||||||
| qBawl | 1539 | |||||||||
| R.D. | 974 | |||||||||
| radb | 856 | |||||||||
| rag | 283 | 298 | ||||||||
| Ragsy | 499 | 1117 | ||||||||
| raiko | 570 | |||||||||
| rajun50 | 651 | |||||||||
| ramius | 1584 | |||||||||
| Randolph | 212 | |||||||||
| RapidLux | 1346 | 1360 | ||||||||
| raqin | 1551 | |||||||||
| Rat_Racer | 999 | |||||||||
| RaVeN | 160 | |||||||||
| raynman | 706 | |||||||||
| rdoc613 | 879 | |||||||||
| ReallyInToCheese | 1568 | |||||||||
| red72vw | 521 | |||||||||
| RedForest UK | 1366 | |||||||||
| redrider706 | 1359 | |||||||||
| regaia | 1008 | 1486 | ||||||||
| reliant_turbo | 710 | 850 | ||||||||
| ReManG | 320 | |||||||||
| reno | 1118 | |||||||||
| retiro675 | 352 | 826 | ||||||||
| rexdog | 442 | 515 | ||||||||
| rfd673 | 747 | |||||||||
| ricardon | 300 | |||||||||
| Ricflair | 323 | |||||||||
| Rick | 199 | |||||||||
| rizky_p | 1405 | |||||||||
| rjorge | 708 | |||||||||
| rmkline | 436 | |||||||||
| Rob_K | 244 | |||||||||
| robbobus | 233 | |||||||||
| Roberrt777 | 185 | |||||||||
| RobertB | 140 | |||||||||
| rocketshipdog | 1500 | |||||||||
| RocketTomato | 766 | |||||||||
| RockHugger | 1173 | |||||||||
| RoloFresh | 1524 | |||||||||
| Romey310 | 969 | 970 | ||||||||
| RonMuller | 111 | |||||||||
| rossysarus | 1465 | |||||||||
| Roter | 649 | |||||||||
| RotorHead64 | 1284 | |||||||||
| rova2014 | 1473 | |||||||||
| Royo | 1407 | |||||||||
| Rpdos | 1180 | |||||||||
| Rska | 650 | |||||||||
| Rsqweezy | 814 | |||||||||
| rufrydr | 765 | |||||||||
| Rufusbduck | 60 | |||||||||
| Rxich | 866 | |||||||||
| ryukin2000 | 1220 | |||||||||
| sac02 | 645 | 908 | 1215 | 1216 | ||||||
| saf99 | 755 | |||||||||
| Saigon | 247 | |||||||||
| saintsagan | 1485 | |||||||||
| SamHaLeKe | 485 | |||||||||
| samis | 509 | |||||||||
| samnavy | 73 | |||||||||
| san san | 926 | 1130 | 1131 | |||||||
| sandanbob | 532 | |||||||||
| Sarge930 | 86 | |||||||||
| Savydude | 1222 | |||||||||
| SawMaster | 45 | |||||||||
| saypat | 141 | |||||||||
| sb56637 | 191 | |||||||||
| scarnific | 566 | |||||||||
| scdaf | 271 | 296 | ||||||||
| Schkü | 614 | |||||||||
| schlockproof | 612 | |||||||||
| Schoki | 1581 | |||||||||
| Sciencetists | 257 | |||||||||
| SciFiFreak | 31 | |||||||||
| Scooby | 582 | |||||||||
| Scooter000 | 315 | |||||||||
| scootypuffjr | 844 | |||||||||
| Scorpia | 596 | |||||||||
| scotlarock | 329 | 1085 | ||||||||
| Scottland | 334 | |||||||||
| Scotty | 746 | |||||||||
| scs | 80 | |||||||||
| sebastiang | 611 | |||||||||
| SebaZ74 | 1239 | 1240 | ||||||||
| SeenTheLight | 301 | 819 | ||||||||
| SFB | 1109 | |||||||||
| Sgtpev | 206 | |||||||||
| Shadowcactus | 916 | |||||||||
| Shadowfax | 341 | |||||||||
| Sharpie | 354 | |||||||||
| shimano3000 | 409 | |||||||||
| shimey | 211 | |||||||||
| shirnask | 61 | 733 | 1384 | |||||||
| Shoe | 957 | |||||||||
| shogan | 227 | |||||||||
| Shur | 284 | |||||||||
| SIGShooter | 368 | 1565 | ||||||||
| Silent_Star | 1190 | |||||||||
| Silentcropduster | 667 | |||||||||
| Simplelight | 961 | 962 | ||||||||
| slackwolf | 885 | 886 | 1000 | |||||||
| slatzman | 1560 | |||||||||
| Sledge | 980 | 985 | 986 | 1326 | ||||||
| Sledgestone | 677 | 841 | ||||||||
| slickpenguin | 643 | 854 | ||||||||
| slimkango | 52 | 1207 | ||||||||
| slow2go | 221 | 222 | 692 | 1139 | 1140 | 1141 | 1278 | 1279 | 1280 | |
| smed1275 | 494 | |||||||||
| Smittymojo | 768 | 1142 | ||||||||
| SmokinH | 855 | |||||||||
| sneakyfart007 | 1522 | |||||||||
| Snoballz | 1031 | |||||||||
| SoCalTiger | 1344 | |||||||||
| sochi111 | 1032 | |||||||||
| Sofa | 834 | |||||||||
| sol | 291 | 292 | ||||||||
| SolarLumen | 776 | |||||||||
| solRNY | 1291 | |||||||||
| somnambulism | 562 | |||||||||
| Sonpham | 621 | |||||||||
| Sordoslux | 1402 | |||||||||
| southland | 142 | 143 | 144 | 145 | ||||||
| sp5it | 94 | 1201 | ||||||||
| spade413 | 1178 | |||||||||
| sparkyDK | 1188 | |||||||||
| specialk | 865 | |||||||||
| Speed4goal | 413 | |||||||||
| Speedsix | 1083 | |||||||||
| spinynorman | 1400 | |||||||||
| spkzzz | 474 | 526 | ||||||||
| Sprinkles | 279 | 778 | 901 | |||||||
| square74 | 1538 | |||||||||
| srs2000 | 1187 | |||||||||
| stanley-beamish | 107 | |||||||||
| starcrazed | 1330 | |||||||||
| stareye | 540 | |||||||||
| staticx57 | 238 | |||||||||
| steel_1024 | 709 | |||||||||
| Steenbhg | 701 | 1205 | 1206 | 1268 | ||||||
| steepdrop | 435 | 497 | ||||||||
| Stephen Elliott | 1322 | |||||||||
| stephenk | 269 | |||||||||
| steve-o | 1376 | |||||||||
| steve42 | 1016 | |||||||||
| Stevejj | 1218 | |||||||||
| SteveMidwest | 1289 | |||||||||
| stevez32 | 822 | |||||||||
| StinkyTool | 1480 | |||||||||
| Stittville Ed | 85 | 998 | ||||||||
| Stoneface | 758 | 1127 | ||||||||
| strango | 96 | |||||||||
| strayz | 505 | |||||||||
| Streamer | 1246 | |||||||||
| strmix | 676 | |||||||||
| strobed | 1368 | |||||||||
| Stud_nut | 1504 | |||||||||
| SubSailorVet | 1501 | 1527 | ||||||||
| Subterrestrial | 1003 | |||||||||
| Sukoi | 642 | 1010 | ||||||||
| Sullysat | 418 | |||||||||
| Suncoaster | 682 | |||||||||
| Swennie | 895 | |||||||||
| Syncmasterklop | 867 | |||||||||
| syracuse | 349 | |||||||||
| T-boon | 304 | |||||||||
| T18 | 390 | 1257 | ||||||||
| t3rminal | 1213 | |||||||||
| Tadashi | 1471 | |||||||||
| Tally-ho | 1573 | |||||||||
| tapir | 489 | |||||||||
| tarver | 132 | 229 | ||||||||
| Tarvos | 15 | |||||||||
| tas69 | 380 | |||||||||
| tatasal | 506 | |||||||||
| teacher | 321 | 1134 | ||||||||
| tebeve | 893 | |||||||||
| techieman33 | 456 | |||||||||
| Tecmo | 57 | |||||||||
| tekwyzrd | 37 | |||||||||
| tenohfive | 802 | |||||||||
| Terry White | 1435 | |||||||||
| Tete | 217 | |||||||||
| Texas_Ace | 472 | 473 | ||||||||
| The Burgh | 235 | |||||||||
| The Grand Pooh-Bah | 1056 | 1057 | ||||||||
| The Imp | 1242 | |||||||||
| The Jinx | 522 | 699 | ||||||||
| The Last Katun | 90 | |||||||||
| The Miller | 1 | 2 | ||||||||
| The_Driver | 1352 | |||||||||
| thebaum | 585 | 807 | ||||||||
| TheConsultant | 1453 | |||||||||
| thecrc | 1177 | |||||||||
| TheDude | 415 | |||||||||
| TheHebrewHammer | 820 | 821 | ||||||||
| TheJo | 1053 | |||||||||
| Thekernels | 1536 | |||||||||
| TheLonelyLumen | 1444 | |||||||||
| themacman4 | 1505 | |||||||||
| TheMadcap | 97 | |||||||||
| themagicconch | 1464 | 1494 | ||||||||
| themaindude | 343 | 1094 | 1095 | |||||||
| TheManMKD | 1546 | |||||||||
| Theodore41 | 520 | |||||||||
| theoldbill | 59 | |||||||||
| TheOnlyDocc | 1135 | |||||||||
| thijsco19 | 24 | |||||||||
| tigris99 | 603 | |||||||||
| tim_duncan | 1545 | |||||||||
| timcodes | 1004 | 1017 | ||||||||
| tindrum42 | 1059 | 1060 | ||||||||
| tinowrx | 572 | |||||||||
| Tixx | 371 | |||||||||
| Tjhosan | 273 | |||||||||
| Tjohn | 940 | 941 | 942 | 943 | 944 | |||||
| Tmik | 287 | |||||||||
| tmxod | 771 | |||||||||
| Toccata | 1241 | |||||||||
| tocirahl | 988 | |||||||||
| Tom E | 28 | 29 | 874 | 875 | 1223 | 1224 | ||||
| Tom_182 | 695 | 780 | ||||||||
| Tomogchi | 1567 | |||||||||
| tomtaylor | 201 | |||||||||
| tonylim | 43 | |||||||||
| torchjunkie | 483 | 597 | ||||||||
| toxiccoccyx | 1107 | |||||||||
| ToyKeeper | 339 | |||||||||
| tracerfire | 1317 | |||||||||
| Trashman531 | 285 | |||||||||
| Trasnodel | 729 | |||||||||
| trevglas | 200 | |||||||||
| trevize | 1165 | |||||||||
| treysoucie | 789 | |||||||||
| tristanxoxo | 240 | 1070 | ||||||||
| troisanh | 91 | |||||||||
| tronx | 674 | |||||||||
| TRoPHeuS | 1152 | |||||||||
| tru3s1lv3r | 39 | |||||||||
| tucsonmike | 1512 | |||||||||
| tugboatcar | 1457 | |||||||||
| Tunerman | 1002 | |||||||||
| tungkon | 1011 | |||||||||
| TurboLion | 917 | |||||||||
| turbopscl | 892 | |||||||||
| turpulator | 1066 | 1363 | ||||||||
| tzmxxhh | 21 | |||||||||
| ubermoo | 1561 | 1562 | ||||||||
| Ulric | 1198 | |||||||||
| unit311 | 849 | |||||||||
| unknown00101 | 548 | |||||||||
| uqs1000 | 357 | |||||||||
| Vagany | 647 | |||||||||
| VaKo | 208 | |||||||||
| Valdorg | 1202 | |||||||||
| Van | 491 | |||||||||
| Vanq86 | 1176 | |||||||||
| vas | 133 | |||||||||
| vasa_visost | 668 | |||||||||
| Vattern | 18 | |||||||||
| velocraig | 781 | |||||||||
| vex_zg | 730 | |||||||||
| Viamede | 948 | |||||||||
| vinte77 | 414 | |||||||||
| vitriolix.com | 1506 | |||||||||
| Volks1973 | 743 | |||||||||
| vulpes | 539 | |||||||||
| vwpieces | 881 | |||||||||
| w4rkry | 1548 | |||||||||
| Wackyvegan | 156 | |||||||||
| walty | 280 | |||||||||
| WarHawk-AVG | 420 | 421 | ||||||||
| warzi1975 | 528 | |||||||||
| wattstar | 791 | |||||||||
| WaylonJennings | 1452 | 1499 | ||||||||
| wb | 1556 | 1564 | ||||||||
| websterjody | 996 | 1105 | 1502 | |||||||
| weklund | 460 | |||||||||
| Werner | 10 | |||||||||
| WestBam | 1333 | |||||||||
| westcoastwonders | 639 | |||||||||
| what_are_birds | 1377 | |||||||||
| whitecitadel | 1354 | |||||||||
| Whitty05 | 1475 | |||||||||
| Wieselflinkpro | 125 | 750 | 1079 | 1482 | 1483 | |||||
| Wildcat | 827 | 945 | ||||||||
| wildmermaid | 1091 | 1398 | ||||||||
| Wildthing | 533 | |||||||||
| willmo | 605 | 882 | ||||||||
| WillyD | 303 | |||||||||
| wilwok | 1076 | 1258 | ||||||||
| Wineslurper | 554 | 555 | ||||||||
| wisefire | 869 | |||||||||
| wishiwereaskibum | 587 | |||||||||
| wkhchin81 | 477 | |||||||||
| Wojto | 1325 | |||||||||
| WolfA | 69 | |||||||||
| Wrathbringer27 | 41 | |||||||||
| wunderhe | 115 | |||||||||
| Wyre | 1269 | |||||||||
| X0R | 1430 | |||||||||
| Xandre | 527 | |||||||||
| xCentrino | 1314 | 1358 | ||||||||
| xed888 | 305 | |||||||||
| xelario | 773 | |||||||||
| xjsnake | 36 | |||||||||
| xray291 | 1192 | |||||||||
| xsosx | 1474 | |||||||||
| xtrosity | 723 | |||||||||
| XXX-Man | 1197 | |||||||||
| xzel87 | 665 | |||||||||
| yasenf | 1006 | 1232 | 1233 | 1273 | 1274 | |||||
| yclongthrow | 898 | 899 | ||||||||
| YoFlash | 744 | |||||||||
| Yokiamy | 1245 | 1383 | ||||||||
| Yourrid | 1101 | 1102 | ||||||||
| zachary6227 | 1297 | |||||||||
| zak.wilson | 182 | |||||||||
| Zanders | 792 | |||||||||
| zara | 180 | |||||||||
| zelee | 22 | |||||||||
| Zeratull | 703 | |||||||||
| zeremefico | 1590 | |||||||||
| zeroair | 452 | |||||||||
| zifzif | 1243 | |||||||||
| zipelgas | 386 | |||||||||
| zoysiamo | 1251 | |||||||||
| ZozzV6 | 626 | |||||||||
| Zteduh | 1530 | |||||||||
| Zulumoose | 1389 | |||||||||
| ×73rmin8r | 1063 |
1176 names
1586 lights
Over 6200 lumens with the right batteries, i think its also mentioned in one of the first posts.
Thanks I can’t wait to get this …be almost or better than my thrunight 36 ut
LMAO I'm 1400 and some change... Still don't know how I missed this...
Thanks Mr.Scott!!!
MJ1’s
30Q’s
GA’s
-DK
They will work just fine. Only max possible lumens won’t be reached, one can measure it but for the eyes it is hard to see.
Hi.
If it’s not too late, could I please be put on the list to buy one?
Thanks
Dave
Here's a new chart on my round 3 (last rcv'd) ThorFire prototype:
This is from the older prototype:
Note: Oops, updated 1st chart to fix 3500/3000 #'s
Thanks Tom E.
I don’t know if I’m average, I’d like to think I am (for my age). The Manker mk41 has a hidden engineering mode that has 10 or 11 brightness settings for turbo mode. I can’t discern the slight step ups between most of those settings, but when I reach the top and it reverts back to the lowest turbo setting I can easily see that.
Where am I going with this? I’m not going to be concerned about not having VTC6 solder tops, but I might do a spring bypass. That seems to me to give the biggest performance increase, but will it be worth doing? Will my eyes see it? They might not but the output might make a difference in distance seen for these old eyes.
So I pose the question to folks who have done spring bypasses, is the performance difference noticeable to the eye after a spring bypass?
