I guess that’s why multiple proto’s where asked for… If it’s a proto board then the issue could be resolved easy. If not it might be a good idea that the team looks for a mpcb producer? Although I don’t think I ever heard of thorfire lights having this issue or they never designed a light pulling 20A in stock form.
Has any manufacturer EVER made a flashlight that pulls 20A in stock form?
Touché as the french say: you have a point there.
Is there an accelerated-aging test to detect this kind of problem?
I’d guess repeated heat-cycling would provoke it, if it’s going to happen.
That’s a fairly common method of testing for potential failures, isn’t it?
Someone who knows something, please comment ….
That’s one of those QA issues — think of everything that could possibly go wrong, and fix the production
and one of those QC issues — do tests of samples of the produced work to find patterns of errors.
My impression was:
It may be a situation where these mcpcb were made on a older machine that doesn’t get much use anymore. It’s a good machine to use for small batches and prototype stuff, but when full production starts, the newer, faster, fully automated mcpcb machine will be used. That’s the thought that popped into my head.
I’m sure it wasn’t hand made and hand etched, etc…
I’m actually curious if Thorfire makes them or they buy them from another company.
Either way, either it’s a problem they already know happens, and know how to watch for, or it’s one they’ve never seen happen and need to take into account.
Googled: thorfire delamination
Found a BLF hit at What did you mod today? - #2893 by zak.wilson which I think refers to some other flashlight, not to a Thorfire:
The stock MCPCB isn’t DTP and it noticeably delaminated when I reflowed the 319As on to it. I think a couple of the thermal pads delaminated when I reflowed the 219Cs the first time
Someone with more patience could look through the rest of the Google hits or refine a search.
Or, of course, ask Thorfire if they know about this …
If it is a “prototype” MCPCB, used only in these Q8 Prototype 3’s ; that should be easy enough to verify.
If, on the other hand; it is the real deal that was supposed to be used in production…… it is a darn good thing the problem was recognized before production so it can be addressed & FIXED.
Otherwise, as I already said; depending on how bad & widespread the problem is…. it could have spelled a Q8 disaster.
As it stands right now all #3 Prototypes have been received & if I remember correctly, three have had MCPCB problems.
PROTOTYPES ARRIVING
in order of arrival:
- Tom E……………… X
- MRsDNF
- The Miller
- Djozz
- Thijsco……………. X
- Pilotdog68
- DEL…………………… X
X = MCPCB problem
I googled for thorfire pcb delamination . Only a handful of results turned up but none pertaining to Thorfire. Seems like delamination has to do with moisture being trapped inside the pcb but what do I know from a simple google search.
Us painters always say, your work will only be as good as the prep was, and it dont take much to ruin a paint-job.
I would imagine a little moisture or grease the wrong place could cause something like this.
So true…… :+1:
Seem like little margins always attract me, working with microns in painting ( layer thickness ) and working my grinding machine the smallest tolerances i worked with had to be within 4/1000 of a mm ( 0.0001574 inch ) + / - 2/1000 mm ( 0.0000787 inch ) to either side of wiggle room.
Team sports dont do much for me, i like individuals performing great feats.
I went for the enhanced boob job option.
10 Sony VTC6's, 6 for me & 4 for my son, I was bored and after reading about the issue with flat-tops in the Q8 I chopped a bunch of 3mm slices off a soft annealed section of 5mm copper bar I had lying around, hammered them down to ~2mmx6mm. I found my old man's ancient Weller 8200 soldering gun in the garage that I though was long lost and had at the cells with it.
The results are 8 cells with copper button tops & 2 without, plus I gave my 6 cells smart new suits & ID numbers. :D
My sentimental missus noted it was nice to be doing something for my son with one of my late dad's old tools.
nice, she happy, you happy
And looks nice!
Looks good Loneman…… :+1:
If it is a “prototype” MCPCB, used only in these Q8 Prototype 3’s (for whatever reason); that should be easy enough to verify. If, on the other hand; it is the real deal that was supposed to be used in production… it is a darn good thing the problem was recognized before production so it can be addressed & FIXED. Otherwise, as I already said; depending on how bad & widespread the problem is… it could have spelled a Q8 disaster. As it stands right now all #3 Prototypes have been received & if I remember correctly, three have had MCPCB problems. (all listed below) PROTOTYPES ARRIVING in order of arrival: * J-Dub74 * Tom E… X * MRsDNF * The Miller * Djozz * Thijsco… X * Pilotdog68 * DEL… X X = MCPCB problem
Not me, but maybe I didn't look careful enough? The earlier protos held up well with reflowing replacement LED's.
Also of note, J-Dub74 got a round #2 Q8 updated/modded to be more like a round #3 (LED's, firmware, other tweaks), not a round #3.
My bad Tom… I thought I remembered you saying there was a bubble close to one of the pads on yours… I’ll correct my post.
Thanks for the J Dub info too. That was not clear to me in the OP.
Ok…. fixed it.
You seem to do that a lot M8
I have learned to keep my mouth shut and finger off keybord when it come to displays of memory, cuz mine are really flaky to say it in a nice way.
Yeah, I doubt I’ll ever learn. :person_facepalming: That’s why I try to always put a disclaimer in it like…. “If I remember correctly” …. or something similar. That always leaves an out.
It’s forgivable Teacher; you have a lot going on. Wait until you get old and have a lot going on.
But I can remember where I’m going and how to get home, so I’m OK. But small stuff? Forget it. That’s why they make paper and pencils… for reminder notes. Sometimes they actually work.
