Queridos nuevos miembros españoles, bienvenidos a BLF!
La lista no está cerrada y no espero que cierre pronto, cuando usted pide para ser puesto en la lista añado su nombre la próxima vez que lo actualice. Cuando estamos listos para la producción en masa y la venta real recibirá un PM (mensaje personal a través de BLF) con la URL y el código para llegar al precio acordado derecho.
(This is what I typed into google translate)
dear new Spanish members, welcome to BLF!
the list is not closed and i do not expect it to close soon, when you ask to be put on the list i add your name next time i update it. When we are ready for mass production and actual sale you will receive a PM (personal message via BLF) with URL and code to get it to the right agreed upon price.
The switch retaining ring was soaked in Greased Lightning to remove the anodizing, then polished up. Tailcap was left a little more red. darker. I used the rubber switch boot from the other proto that had the short stem (harder to press), and glued an extension- came out well. I'm using a thinner UCLp lens, and found a larger o-ring in the same position under the lens to make up the difference - tried some sanding on the o-ring because it's a bit too big, still can't screw down the bezel all the way.
The switch retaining ring scratches the black off real easy. All 3 I've touched got scratched up. I'd rather have it in silver/aluminum finish just so scratches don't show, and it matches the bezel well.
The tailcap came from another SRK clone. But keep in mind - for the real Q8, you won't be able to LEGO parts with other SRK's because the battery tube threads on both ends are true square, making them no longer compatible.
Inside views:
In pieces:
In the above, you can see the difference in color of the tailcap. The colors vary a bit from picture to picture. Near the bezel, apparently because it's thinner, it heated up a bit quicker, and started changing color to the next shade, slightly more brown, when I turned off the heat.
Did TF say if the anodization on the prototypes was just a quick and cheap job to get the proto out faster and that the production models will get the full on, more expensive and time consuming hard anodization?
I’m hoping the production versions don’t scratch real easy.
Wait, are you saying the black on the body or on the switch ring scratched easily? That’s a big difference.
