I love the UI Tom and I like Phoenix_Fin’s suggestion for 3x26650. I’m planning to get the Convoy L6, L2, and BD06 so if this took 26650 it would be great.
What’s the advantage of 3x26650? I consider the larger diameter as a clear disadvantage, capacity would not be much better either. Please don’t make it larger.
For the 3*26650, it would certainly change everything for the battery tube. 3 26650's needs more width than 4 18650's. A carrier would be needed, and a carrier probably means even more width, more height, more resistance paths, etc. There's also a good reason to stay with 18650's in multi-cell lights - the 18650 has the best density of power for size and weight, and the big 4 make 18650's, and only SONY seem to make 26650's for some reason (Pana/SANYO, Samsung, SONY, LG).
Comparing the top capacity and top performing cells, 18650: 4 * 3500 = 14,000 mAh, 4 * 3000 = 12,000 mAh. For 26650's: 3 * 5200 = 15,600 mAh, 3 * 4200 = 12,600 mAh. 26650's have the slight favor, but 3 26650's would require a larger diameter battery tube, and a 26650 is nearly double the weight of an 18650, but not close to doubling it's capacity. I don't like the tradeoff, though I'm a big fan of 26650's.
With 3x26650 many people would need a handle for this light. My hands are rather large, but still a SRK is the maximum I would like to carry around without handle.
When we were starting this Q8 I asked in a new topic if anybody knows a flashlight that is sold with a AT85 and no answer
But you need something like the parts list in the OP
AT85, fet and 7138 chip
We would love to see people test Narsil, the more the better!
Hmm. Is there a pause once you reach MAX before it starts ramping back down? Or does it stop completely? And will have to press and hold switch again to ramp down.
In video, it looks to start ramping down almost immediately making it very hard to stop at the MAX mode.
Honestly, I wouldn’t mind just having it stop all ramping once it reaches MAX. I have a light that stop ramping and a light that ramps back down, and on the light that ramps back down, I always second guess myself if the light is on MAX or slightly less because of the ramping back down.
But if not, I think it should be at the same pause as on the moonlight.
Ohhh, no - sorry, was hoping you could hear the clicks - the sounds of the clicks make a big difference. It ramps up to max, then stops there. I was releasing the switch, then doing a press&hold to ramp it back down. Sometimes, usually the first time in the video, I didn't hold ot long enough to hit max, so had to press&hold again to hit it.
It will stop ramping at max when going up, and at the lowest level (moon of PWM value of 3) when ramping down.
Below are the new 150 level, 2.4 second PWM level tables, using TK's utility to generate them. Notice in the FET table, the last 29 values are above 50% (128 and higher), and it gets pretty hard to differentiate anything much above 50%, so it's kind of hard to tell the moment it reaches max. Might be easier outdoors in true low light conditions, not sure. Was thinking of adding a real quick blink at max, just to signal you got there, but that might be distracting too, but would make my testing and videos easier .
U hit it right on once again haha. I dunno call me lazy or maybe I just forget instinctly about the double click to high.
But when I turn on the light , and say I need more light, I tend to press and hold switch to ramp up more often than doing a double click.
I may just have a lazy thumb hahha
I think I know what you mean ( I have SRK also), depending on design that could be achieved too.
Thanks for support!
I think advantage would be versatility of cell's by user preference. Of course some might think that too big, but think of having 0,33l soda can in your hand and it would be smaller. If it would be with carrier that would give them ability to make it in series of higher voltage if needed. Please bear in mind that my idea was it being user preferrable between those 2 cells types.
You got nice points there, thanks. And special thanks for your effort in ramping, I really like watching it and look forward seeing it in my hands (with Q8).
I hear you. It is always matter of opinion.
Here is another sketch with little different position of 18650's so they would align different. There is now possibility (blue) for "triangular" shape of tube that could be nicer for hand and also work as antirolling. Downside being it would have to made out of solid bar.
And one more with body tube like, since I realised that there could be fitted 7x 18650 in same place of 3x 26650's (or even little smaller). Here they would certainly outperform.
Thanks for your opinions. And sorry for my "mad" inventions . I really like all of your effort guys. I'ts not like I would make it my own and force it to be too big (or something you dislike) for you. I'ts just me and my idea's, that sometimes I might be re-inventing wheel. Nevertheless I like to say them out and see if they any good. I really enjoy reading this forum, and watching group buy's where is productive conversations.
Like before feel free to shoot my ideas, I appreciate your feedback.
And you’re all conveniently ignoring the springs which won’t line up for both cases. I can’t see how it will happen. Not without the whole thing going downhill with more complexity.
@Tac Gunner : I haven’t thought about handle. And I’m not quite sure did I understand your question correctly? Did you mean mean difference between SRK style 4 cell’s tube vs my sketch tube? If so it would probably be around ~10mm depending on wall thickness so @fixed it has it right.
@fixed it : Depending on sketch it could be done couple ways
1) Solid copper "pole" that is placed correctly to work with different cell's, that would probably reguire spring on negative contact under driver to contact bodytube. Or carried by unanodizided thread that would be long enough to allow different cell lengths.
2) Springs in positive side. For example like a one solid pcb "floating" that got enough surface area to allowing all cell configure's. But that would reguire using button top cell's. Not sure if I can describe it good so that you understant, but like the way Nitecore has it in SRT-7, only bigger.
3) Using spring contact pin, like this (only of example probably not the correct one for the job, but there is plenty of others with different specs like this.)
But you are right at it, probably would be more complex. But I'd like to think every obstacle can be overcome it's just matter of time.
Moinsieur you own flashlights with at85 i think how about the x5 and x6 they both have the att85 does ths nasril work on them ??? i would flashit it right now
Yes that it was I referring to. Not sure why I said “handle end” instead of battery tube, I’ve edited my above post. With the increase in size that would probably put it at around a 70-73mm diameter? If so then never mind on the 3x26650, that would just be to large, mid 60-65mm is large enough for me. As for the springs I’m sure that could be worked around but at the point Fixed It is right, to much complexity to stay with in the price range set.
