[RD power supply]assembled set for RD6006/RD6012/RD6018/RD6024
the output cable matters for power supply for voltage drop!
RD6012P 5 digit 60V 12A power supply feedback
This power supply is awesome, powerful and stable. And the design is also very fashionable and beautiful!
RD6006 power supply feedback
Let’s talk about the quality of the product first. The voltage and current output are accurate, It is completely sufficient for me. The product is generally good, and the packaging was complete when I received it.
I received my RD6006P-W kit today and assembled. Sadly I forgot to buy the battery, so will have to tear apart and put it in next week.
My temporary electronics corner is now ready. Looking good! Thank you RD Tech!
thank you so much for your share
for the battery , it is button cell ? the name is CR1220 , it is for system time , don’t affect normal work
if you like , you can share more picture , thank you
Yes, I am already using it until the cell comes - I will still put it in. Clock is nice to have, especially since I will be using the data logging feature a lot and the clock gives me correct time in files :slight_smile:
This is after unpacking, I ordered the kit to assemble myself.
Just some short tests. Accuracy of idle voltage measured with an accurate multimeter, and a test of the on-screen graphing view. Very satisfied so far.
RD6024 60V 24A power supply feedback
before purchasing this model, I compare it with other power supplies for long time and finally I choose this model, the customer service is great
https://www.aliexpress.us/item/3256803558326998.html
thank you, if there is any question when using the product, just contact us
I have a question.
At 60V 24A what are the time of usage?
I don’t find timing anywhere
Can you help me?
do you mean the device working time? sorry it does not have this function
I mean the timing for RMS or peak with load
As long as you can ensure heat dissipation, 60V/24 can work 24 hours a day
RMS or peak with load-- I don’t know
Can you ask to technician please?
Every power supply can generate (when stressed) an amount of power for an amount of time
How can I know if at full power it’s safe?
1500W are so much power😌
Not 100% sure if I understood your question, but as far as I know the RD60xx PSUs all have a duty cycle of 100%, so they can deliver full power permanently. Not that much power for a decently sized SMPS.
Keep in mind that the non-P units have pretty high ripple voltage. Only the newer gen RD60xxP models have the awesome 20-30 mV ripple.
in fact, i already told you that it can work 24 hours only you ensure heat dissipation
our psu is 1500w , so it can let RD6024 fully work, there is not any problem
which usb meter ?
We are designed according to the room temperature environment. As long as it is under room temperature conditions and not sealed, high temperature or high altitude conditions, our products have no task at full load output.
