[RD power supply]assembled set for RD6006/RD6012/RD6018/RD6024
So they can run 60V 24A load out for 24 hours?
yes, you can
but you need to ensure heat dissipation
Thank you
you are welcome
hope you can share more interesting things for our products
RK6006 power supply feedback
Shipped fast and arrived fast. Very well packaged and all as described. Working just fine and without the I noise described by the seller, fortunately. The Bluetooth and the app working fine. 100% recommended seller.
https://www.aliexpress.us/item/3256805243272337.html
I received my RD6024 about 2 weeks ago. Great packaging and Super Fast shipping ( 10 days to Louisiana )
I finally got around to putting it together today, used a power supply I already had. Now to have some fun and learn how to use it.
that looks good, you also add fan control? if there is any question you meet when using this power supply, just contact us
if you find any interesting things for our products, you also can share here
When I’m using the IOS App, why doesn’t the battery voltage show . Temp, Mah show, the battery voltage shows on the Main Screen
sorry I tried it, it should be the IOS app problem
RD6006P 5-digit 60V 6A power supply feedback
Great little power supply. Completely silent in idle, only starts spinning up under heavy load. User interface is great, very easy to use. Very accurate output voltage throughout the entire range
RD6012P 60V 12A power supply feedback
it is easy to operate, and the display is clear, I test it and recommend it
RK6006-C 60V 6A AC to DC power supply feedback
I choose it because it does not take too much space, easy operation and it has PC software, good
https://www.aliexpress.us/item/3256805584703349.html
RD power supply is still good. Small size is more convenient. The cable is soft, can also be connected via Bluetooth. Recommend
RD6024 AC to DC power supply feedback
always buy power supply in this store, I have a 5 digit RD6012P set, it is accurate but I need higher current, so that I choose RD6024
https://www.aliexpress.us/item/3256803558326998.html
RD6006W power supply feedback
just order a RD6006W and I will make a DIY case for it, good under 60V DC, and comes with a spare fuse
https://www.aliexpress.us/item/2255800096237178.html
RD6012P 60V 12A AC to DC power supply set feedback
it is not as big as I expect, looks good, and the output can be adjusted, this is what I need
RD6006PW 60V6A power supply feedback
Bought for electrochemical experiments, it is more stable and more accurate than ordinary power supplies. It is also small in size, about the same size as a stirrer, and is very space-saving.
RK6006-C 60V 6A power supply feedback
Ripple, power have been tested. It is small in size and feels good in the hand. After upgrading to the new firmware, the fan problem has been solved. I found that I can change the startup page. It is worth buying.
OVP/OCP setting problem for RD/RK/DPS power supply
