RK6006-C power supply feedback
A compact power supply with a suitable weight. It is suitable for friends who are short of space. This manufacturer is very reliable, the PC software is also very easy to use. If you need it, you can buy it.
RD6024 AC to DC 60V 24A power supply feedback
after using for a couple of days, good display, easy operation, really recommend it
RD6012P 5-digit 60V 12A power supply feedback
good power supply, if the screen can be bigger, it would be perfect
RD6024 60V 24A power supply feedback
Great seller and product. Highly recommended the product, The treatment and communication with the seller has been excellent. I had a problem and he solved it right away
DPS3005 power supply feedback
Works great as a tiny desk PSU in a little 3d printed case.
Everything arrived in good condition, I would recommend it now, I will try to assemble it after a while to see if it works properly, but I am sure that there will be no defects during transport due to its good packaging
RK6006 60V 6A power supply feedback
compact design, compared with RD6006P, it is much smaller, both of them are 360W, recommend
https://www.aliexpress.us/item/1005005429587089.html
I ordered RD6018 before and I realize that I use 7-8A only so that I order RD6012P, high accuracy and big current, I recommend it
good power supply, good to use it, and I recommend my friend to get one
https://www.aliexpress.us/item/3256805243272337.html
RD6018W 60V 18A power supply feedback
Very well packed. Original box like a smartphone, good materials of the front panel. Waiting for the second part of the order - switching power supply.
RD6024 60V 24A AC to DC power supply set feedback
Great lab power supply. Very satisfied with the purchase.
When is the RK6006 Fan suppose to come on — Assembled mine today with the with C400 case – At 122F the fan was still not running – If I touch the two fan pins together with the fan run all the time
hello, for RK6006, the Cooling fan start condition:Output current>5A or System temperature>65℃, this is for the RK6006 control, if the input 400W PSU is hot, the fan will also work, and do you insert the fan cable to the correct socket? there are 2 sockets on the back panel, one is fan socket and the other one is external temperature sensor cable
perfect product and I do not know how to express my feelings, will order more next time
Amazon: Amazon.com
RD6012P power supply feedback
fast delivery, convenient to use, good product, I use it for phone repair
Aliexpress: 66.86€ 23% OFF|Rd rd6012p rd6012pw USB WiFi 5 stellige DC DC Step Down Strom versorgung einstellbare Buck Konverter 60V 12a Telefon Reparatur & 800W Netzteil|Multimeter| - AliExpress
Amazon: Amazon.com
RK6006-C 60V 6A AC to DC power supply feedback
good power supply, small sized, noise not loud, convenient to use
Aliexpress: 98.55€ 22% OFF|RK6006-C 60V 6a 4-stellig AC zu DC einstellbare digitale Steuerung stabilisierte Labor bank Strom versorgung Batterie Lade einfache Bedienung
Amazon: Amazon.com
RD6012 60V 12A power supply feedback
I use the power supply I have to power on it to make it a adjustable power supply
Aliexpress: 66.49€ 23% OFF|Rd rd6012 rd6012w usb wifi dc dc spannung step down bank netzteil einstellbarer buck konverter 60v 12a & 800w psu|Schaltnetzteil| - AliExpress
Amazon: Amazon.com
RK6006-C 60V 6A power supply
Thank you so much for your high quality and professional help! This is the best seller on aliexpress!
Amazon: Amazon.com
