which one do you prefer? will you tilte the display for a better view?
[RD RD6024 RD6024W 60V 24A USB WiFi DC DC einstellbare Step Down spannung bank Netzteil Buck converter & 1000W 1200W AC DC NETZTEIL|Multimeter| - AliExpress]
I prefer the bottom type of display.
I have a small shelf on the wall and above the work surface that I use for holding items like this at eye level so no need for me to tilt.
i like the big one too , it also have key board
new firmware of RD6012 and RD6018
CutOff current and CutOff temperature to protect the battery for charging
In this photo you can see the clear differences between RD series and DPS series, bigger screen, keypad control for quick setting, battery charging terminal…for the performance,still need to check the parameter
if you have good design, you can also show that
(it is so convenient that we can upload local picture directly now)
is it necessary to add a hanle on the S400/S800 case? we do research before so that we do not add that when we make the custom case for RD series power supply, will you need that?
RD6006P assembled set feedback The product came perfectly packed with only a slight delay. Delivery to the pickup point The set is complete. Everything works, the device is fine, tested for a few days.
https://aliexpress.com/item/1005002185722889.html
if you have any good suggestions about our products, just contact us
RD6024 feedback
The quality of the product is good, the details are very good, the delivery is fast, great
hello, will you use the battery charging terminal when charging a battery? or just use the normal red terminal as output+? because there are customers who use the red terminal and connect the battey in the wrong way, then the fuse will be burnt
if you are choosing input power supply For RD power supply, do not use electric bike charger, second-hand power supply, modified power supply, bad PSU will have peak overvoltage to damage RD power supply, please use stable DC input
if you are using wooden case, make some holes and make good heat dissipation system, so that the device can work for long time, otherwise the power supply may not work due to the over high temperature
Yes, very important. Whoever made that case did a marvelous job, though…it’s beautiful!
yes, it is made by a China Customer, he post it at the product feedback
if you have any good DIY ideas about our products, or any suggestion to improve our devices, or share how you use our device in your daily life, you can post them under this twitter, we will send some gifts from the replied messages(pens, or USB testers if there are more reply)
RD6012P feedback
stable output, easy to charge battery, like the output power limit function to protect the load, and it is soft start, no inrush surges
https://aliexpress.com/item/1005003472332331.html
last 2 days, we will randomly choose one to send our USB tester
