Inspired recently by Gords… I am looking into ‘flaming’ my Trustfire TR-3T6. Surprizingly it was much simpler to disesmble than I expected. EXCEPT… How do I remove the rear clicky without destroying it?
This made I giggle like a maniac, for the sake of clarity for anyone reading, please really don’t do this, unless you don’t like the microwave or its owner.
Just to clear up, lastime I used a butane torch, that did the job.
This time I’m planning on using oxy-propane in the hope I can get the heat in quick and more concentrated, before cooling, rotating and doing the next area. I have no idea if this will have the desired effect or not, but I’m hoping for a sort of scollaped design.
The only other way I can think of getting a design is by getting some of the panel beaters heat soak putty, forming the design, heating and see what happens.
Have you tried the old incan light bulb in a bowl of water microwave trick? That’s fun and another reason to dislike CFL’s, I figure the plastics will make a mess before the desired result.
