Welcome everyone to my new searchlight build ![]()
I have been away from the forums for several years since my last build, the SyniosBeam, but have returned with some newfound inspiration to build another superthrower!
The goal for this build is to improve on what I learnt during my last project, which was a liquid-cooled recoil reflector LED build achieving close to 5k lumens and 10Mcd.
These are the goals for this build:
- Recoil reflector (but this time glass instead of electroformed, for more precision and rigidity)
- Laser-phosphor (LEP) light source (going for intensity over lumen output this time)
- Heat pipe passive cooling (no moving parts, fans, or pumps)
- Full billet aluminum construction
- Glass AR-coated front lens
- 4 or 8 high capacity 21700 cells
- Built-in USB C fast charging
The reasons for going with recoil reflector this time again is for the following reasons:
- The 220mm diameter reflector only costs ~$1300 CAD while a 150mm lens would have cost me $3500 CAD and resulted in less area and therefore lux
- The recoil reflector results in a clean beam with no chromatic aberration (lenses will have a slight rainbow effect as the red light bens differently from the blue light)
- Recoil reflectors are cool and I can make the flashlight flatter instead of longer
So, based on this, I began the design in CAD.
It is a 240mm diameter, 180mm height (4:3 radio) perfect cylinder, with only the handle protruding from the side.
The handle is an off-the-shelf camera top handle from Smallrig, but this specific model is discontinued. A latching push-button switch is installed at the front of the handle.
Other than some fasteners at the bottom face and around the front lens, the body is clean. It will be made from black anodized 6061 aluminum, fully CNCd.
The front of the light I tried to optimize to be as much optic as possible. Body diameter was minimized, and the only obstruction is the single arm holding the laser phosphor emitter in the center.
Underneath the light there is not much going on other than a 1/4"-20 tripod mount and 6 screws holding the back panel on.
Inside you will find a custom PCB with 21700 cells, a USB C charging circuit, and a constant-current buck LED driver.
Here I have the cells arranged in 2p4s configuration, which theoretically allows for almost 10h of continuous runtime at max power.
I might decrease this to 4 cells just for the first revision, but we will see.
The goal is to have a single PCB that can do everything (battery holders + charger + driver) all in one in the future, but I am very new to PCB design so to start I will be using an off-the-shelf driver and charger.
The charger is the LiPow USB C fast charger which can do up to 60W fast charging, and the driver is a buck constant-current driver from MTN electronics.
I plan to use Amprius SA112 21700 cells as they have the highest capacity and I need very little current.
In the cross-section of the light you can see how the reflector is held in front of the laser phosphor diode.
It appears to be floating right now because to aid in vibration and impact dampening I will be using RTV silicone to hold the reflector to its mounting ring.
It is a very expensive and fragile glass reflector so hard impacts would shatter it without a shock absorbing mount.
Looking from a horizontal cross-sectional view we can see the aluminum arm holding the laser in place.
Two 200mm heat pipes are run through the arm to contact near the diode and provide heat transfer from the center to the outside of the searchlight body for cooling.
Because this laser only uses 15W, there is a very minor amount of heat being generated.
My hope is that the heat pipes are enough to keep it within adequate operating temperatures, but we will have to see during testing.
Overall it is a simple and clean design, which should be robust and water resistant while providing excellent range.
To aid with the water resistance the USB C port will be sealed on the back using silicone and a rubber cap will also cover it from the front to prevent dirt ingress.
The charger has an LED to indicate the battery charge state, and this will be routed to the second hole using a flexible light pipe.
Using my recoil reflector calculator I am estimating approximately 600 lumens OTF and over 25Mcd, which will result in a 10km ANSI beam distance to 0.25 lux.
This is more than 2x the intensity of my last build!
Stay tuned because in the next few months I will be putting this together and testing it ![]()
Parts list:
- Edmund Optics 220mm dia 100mm FL precision parabolic reflector (received)
- Edmund Optics custom 232mm dia 3mm thick AR coated glass window (received)
- Custom 1100lm 1000cd/mm2 laser-phosphor module from whitelaserlighting.com (received)
- Custom 4s input MTN Electronics 3.5A buck driver (received)
- LiPow USB C fast charger (received)
- USB C port cap (received)
Vapcell F63Amprius SA112 21700 cells (received)- Battery holder PCB (received)
- Heat pipes (received)
- Handle and pushbutton switch (received)
- Aluminum parts for body (received)
- Fasteners (received)
Latest updates:
