Acronis True Image is the best for windows. I’ve tried Clonezilla, it works. I know others who used to use Ghost religiously.
Get Acronis though. It’s so easy you can’t really mess anything up and compresses your .tib file. I have to run automated backups on our network because of my wife Like she wanted to play hayday on her computer recently. So instead of asking me she went on google and trojaned her machine. I can’t count the amount of times she’s done this on windows 7. Microsoft security essentials is useless nowdays too if a woman is on the other end (heheh ok I kid, but no really). I run linux, so I don’t really sweat it, know exactly what I’m putting into my rig.
So it’s either restore points or acronis. Beats reinstalling.
You don’t need too, windows 8 has a built in day one restore that will wipe all data and return to day one.
But if you have a spare hard drive you could use macrium reflect. I use it all the time on customers computers.
Then you will be somewhat proud of me, its a removable drive in a case that spends most of its life in the closet and gets connected occasionally when i need data from it, or when i want to back up or for whatever reason i want to use it, so that does mean my data is not backed up every day but when i forget to unplug it and put it away then my data is backed up daily. Lately i am not adding or subtracting to my files by much so if it gets backed up weekly i can’t lose much. When i am using data i connect it more frequently so it does get backed up, having lost data before i know the value of backups.
I installed macrium on my new windows and made a backup last night after it was installed with updates and firefox, i will install drivers, and a few more pieces of software then make another backup.
I use Macrium Reflect to make system images and another little program called Syncback (also just the free edition) for managing day to day backups. http://www.2brightsparks.com/download-syncbackfree.html
With Macrium, make sure to create AND TEST your rescue media. I keep a copy of my system images stored on external USB drives. The Linux based recovery environment works on most machines but I have found some PCs cannot access the USB drive in recovery mode. It's probably just a matter of fiddling with drivers but I don't use Linux much so haven't played around with this. The WinPE recovery environment seems much more consistently able to access USB devices.
Good to hear you are keeping your backup drive unplugged. Now - do you also keep an offsite copy?
Frankly, if your backup is stored in the same building (I would even say the same town) as the original data it isn’t a backup. Tornados, floods, fires, etc need to be considered. I had a friend lose pretty much a life’s work when a tornado nuked his house and his parents house across town. There is NO substitute for distance as far as backup storage is concerned…
To hell with practical… find a way and JUST DO IT!… maybe safe deposit box in a bank. I know a guy that rented a post office box and kept a backup hard drive in it.
Cloud storage for critical small files. (Not containing PIN numbers, passwords, etc. Impractical for large media collections)
Burn data to optical media and leave a copy with a friend/relative/attourney/accoutant/etc - preferably in another suburb, better in another state. Specify cool dark storage conditions and replace every 5 years or so.
Buy another external USB drive and keep TWO copies. When visiting said friend/relative/etc, swap over hard drives leaving the newest backup offsite. Do this as often as possible.
Backup to data keys and bury deep in a watertight container in the back yard. (Tornado, fire, flood.)
OR
Resign yourself to the fact that your data probably wasn't all that important anyway.
Can anyone else help Bort out with offsite backup suggestions?
And don’t get me started on data centers in building basements… great fun was had by all when a water main broke in downtown Dallas and flooded several basement data centers… including city hall… Like it wasn’t like the first time we’ve had a water main break around here… and the goombas didn’t know water tends to flow downhill.
i’ll bet $60 a year that a certain government agency is reading or trying to read through the stored data
thats witchcraft, a few centuries ago you would have been burned alive for claiming such nonsense
interesting ideas people have come up with for old bunkers, apparently a company tried to buy one to use as a paintball arena, among other creative usage ideas
Actually a nas is good for most people. Just as long as it isn’t on or attached to the same machine it’s backing up. Ups isn’t a bad idea if you live in a lightning prone area. The problem with having backups on the same rig is if the power supply goes (rarely happens today), but let’s say it was like back in the 90’s, a power supply spike takes out all the drives, everything in one swoop. People running raid 1 are screwed as the mirror drive goes along with the main. Making a nas isn’t expensive anymore and gives you a nice central server. If you want to get anal about it, attach a external drive(s) through esata or usb 3 and take it off site. But imo that’s really out of control for the type of material most people are storing.
Definitely get one that has RAID-5…redundancy in the harddrives, as long as you don’t loose all the drives at the same time, just pull the bad drive, plug in new drive, it will rebuild the data on the fly
And/or if you have an old computer just collecting dust
It can be simple, just an old board with drives attached. No need to buy one pre built. You just have to setup the network. Nice having a central server to store your files. If you have good drives and a fast bus, you can even use it as a media server or use it to stream to your roku, ect…
Hey B, I’ve used these before. Really cheap way to add esata ports to your rig if it’s older.
