Reinstalling Windows 8 on SSD, how can i make a backup onto another drive so i can go back to fresh windows in future quickly?
My computer is a year old, so they should have worked out the USB 3 bugs by now, its a Western Digital mybook 1140, apparently others have had this issue but i was not able to find a solution.
It does not take SATA, i’m sure if i pull the drive out it should be able to be installed in the computer but that is not my goal, also i read some reports that the drive uses some kind of encryption, if the case fails the data is irretrievable.
Try running this… It might tell you what’s up, if it’s a driver or hardware issue
http://support.wdc.com/product/download.asp?groupid=113&sid=3&lang=en
For cloud storage of personal data its SpiderOak or nothing.
True Encryption. Zero-Knowledge. Spideroak never has your key. Keeps a Warrant canary.
Others who claim encryption are straight up lairs imho. They possess your key which equals worthless “security”. They are only good for storing mp3, movies, junk that needs zero security. Spideroak is the only one with true encryption. You could setup you own encryption to use with other services but most people don’t want to expend the effort &/or don’t know how to do it safely.
Or you could encrypt before uploading to cloud storage. I’d encrypt anything you were leaving with others for safe-keeping.
Now back to building my faraday cage safe room… :ghost:
This is where truecrypt comes into play :wink:
Are people still using TrueCrypt? I thought it was discontinued:
Well poo
Its not dead.
The anonymous developers of TrueCrypt just abandoned it & tried to kill it off. Its believed they may have done so because they don’t trust others to take it over.
Yes . . . TrueCrypt is still safe to use.
People will be working on forking TrueCrypt and continuing it, likely under a new name.
TrueCrypt security audit presses on.
Or they were “encouraged” to abandon it?
I was afraid I saw the “tinfoil hat” moment in those posts…seems the government doesn’t want people hiding stuff…now wonder why that is?
from the forbes writeup
Ok, we went way off the rails on this one…sorry OP
If you believe your government might be interested in you, you really need to use layers of security & encryption.
I find some great stuff on BLF is off topic.
Have you tried the provided System Image utility?
It’ll make an image which you can use to restore with a bootable disc.
A tutorial can be found here.
I should mention that the system image utility will only image the boot partition.
I suspect that you’ll probably find it more practical to copy files from other partitions/drives to a back up drive or use something else to automate it, such as rsync.
I certainly hope the utility in Windows 8 is a bit less brain-dead than the one in Windows 7.
When 7 first appeared I experimented with the built-in imaging utility but found that you are unable to restore from it if the image had been moved in any way at all. Copying it to an external drive or even moving it to another folder within the original hard disk partition would render it completely inaccessible to the joke of a recovery process.
To image 10 machines in my then work environment meant that I had to individually move the external USB drive to each of them one at a time and run the utility. God help us if that external drive ever failed because the Windows 7 utility wouldn't access a copy of the image stored on another device or location. It could only access images that had been directly written there by itself.
At the time I couldn't find a workaround or solution for this issue and gave up in disgust. That's when I started using Macrium Reflect or reverting back to Symantec Ghost.
Kryten, I'd be very interested to know if you could test this scenario with your Windows 8 installation and see if you run into the same problem.
I’ve just tested this under Windows 8.1 as follows.
  • I copied the WindowsImageBackup directory to another external drive
  • Started the procedure by starting Windows in the recovery mode (Recovery Options > Advanced Startup > Restore System Image)
  • After logging into a safe-mode-like environment, it detected the image on the attached drive with the copy
  • Disconnected the drive and refreshed the list of images
  • The entry disappeared
  • Reconnected the drive and refreshed the list of images
  • The entry reappeared
I didn’t go through the actual restoration but it did find the image.
I think the limitation might be that the directory can’t be renamed and has to be in the root directory so it has the same overall structure as the original, but that’s just a guess.
I hope this helps.
Thanks for that.
Certainly couldn't make Windows7 do that a few years back.
