The OTC tool isn’t nearly as precise, since it depends on a human to remove power for a measured amount of time… and even the most precise person probably can’t get an accuracy of a tenth of a second. But it still at least gives a general idea of a value to start with before tweaking.
Oh, and, um… the OTC values do not follow a linear curve. They’re on something like a logarithmic decay curve, and you’ll need to directly measure each time period you care about… and then probably tweak it for a while during actual use.
Build a board
Flash the MCU with Battcheck
Dial in Low voltage with the lab PS and read the blinks
Dial in Crit voltage and read the blinks
Load the main firmware in Studio x.x, change the Low and Crit settings, flash, and you should have LVP that takes into account the peculiarities of your build.
LED Boatguy, yes, that is correct. It’s still a good idea to measure the voltage with a DMM since lab power supplies are often not terribly precise, but the general approach is exactly what battcheck is intended for.
(well, at least my lab power supply isn’t very precise… it consistently reads about 0.1V low)
Hey guys! Quick question for you. I ordered 12 of these to build new version Convoy C8's as the retaining ring doesn't clear the 7135s on the 105C. Of course swapping two 7135's from back to front is much easier than transferring everything over to one of these boards, but it's a fun project (although soldering all of these components can be quite the pain). Anyways, the first one I built is having off-time issues.
Every build I've done with the 105C and a CAP_THRESHOLD of 130 has worked great with maybe a 1 second off-time. This one is more like 5 seconds. I haven't tried swapping out the capacitor to see if it somehow went bad (it's the same 1uF like I always use), but has anyone had this issue before? Could it have anything to do with board differences, or is it most likely a bad component or a bad connection somewhere?
I’m not very good at hardware, but from what I’ve heard many offtime-calibration issues are due to the resistor values. Could the resistors perhaps be swapped, or different types than usual?
I had to change the offtime cap values quite a bit on another custom-built driver. Instead of the usual (and nice) values around 130, it ended up with a threshold of about 250. I needed to dump out the raw ADC values with offtime-cap.c in order to even get in the ballpark at first. Even after sitting off overnight, it reads out a value of about 40.
If you’re not able to get the OTC to work as desired, you can still switch to the memory decay method. I made a version of STAR specifically for this, changing as little as possible to make it work that way:
Jonny, I've never built this particular board, but I've built thousands of others with off-time capacitors on them and I've never had to change the OTC values that much. Is it possible that you got a 10uF cap. in place of the 1uF?
I'd try another board just to make sure it's not one of the components before you end up chasing your tail.
i think this may be another area where wight just did things “differently” with unintended consquences. With this board, and a few others of his design, I have to use an OTC value of about 245 to get it to my liking. That’s with a 1uf cap.
There is a short discussion about itrelated to it on page 3 of his 22mm 7135 board.
Ahh, it might be the diode bypass feature which I haven't looked into yet (to even understand what it does). So I'm not going insane then. I'll play around with values around 240 for the OTC. Thanks guys!
Well, if that were the case then all of my FET drivers (unless zener modified) and the BLFxxDD "1.0" drivers would also need higher OTC values, but they don't. I use the same OTC values across the board. All of those (except my zener mod) have the capacitor before the diode instead of after.
That is interesting. Sometimes even with these simple drivers something as simple as changing trace length and proximity to other components can have unexpected results.
I don't have any 105D's, but my 105C's have the 7135 all of the way up to the edge of the board :( I can just move the two that are and stack them on the other side, which is much easier than swapping all of the components.
Sorry, can someone point me to a description of what "memory decay" is? Does it make the whole off-time cap stuff obsolete?
If you only want short/long presses and don’t mind the threshold being hardwired to about 0.6s, then yes, it can obsolete the off-time cap stuff. But if you want other thresholds or more than one threshold, you still need the OTC.
This thread describes the method in more detail:
I hope it’s okay that I made a version of STAR_offtime which uses memory decay instead of the OTC. People were requesting it and it was an easy change, so I made it.
Awesome, thanks for the link! That is an elegant solution.
[quote=ToyKeeper]
I hope it's okay that I made a version of STAR_offtime which uses memory decay instead of the OTC. People were requesting it and it was an easy change, so I made it.
[/quote]
