UPDATE 18.5.2017
Deal is alive!
i sent PMs to user 1-50 on the list and mailed all participants from the form!
(please check your spam folder ;) )
Hey my friends!
i will get a nice deal for the:
Klarus G35
XHP35 HI D4 2000LM 18650 Outdoor Illumination 1000m LED Flashlight
Features:
1. Newest XHP35 HI D4 LED, 50,000 hours life.
2. Max beam distance 1000M, best suited for outdoor adventures; search and rescue operation
3. Dual Switch design for convenient and easy operation- Independent tail and side switch, each with full set offeatures and easily adapted to any scenarios
4. Unique lockout mode prevents accidental operations; avoiding battery drains during storage or travel and prevents unintended direct shining into eyes
5. Battery capacity indicator display enables controlled usage based on remaining battery charge
6. ITS (Intelligent Temperature System) temperature control monitors internal temperature and adjusts outputs for balanced brightness;
protects the LED and internal components; ensuring safety, stability and optimal performance
7. Dual Switch for one-touch turbo and one-touch low, plus mode memory
8. Reverse-polarity protection prevents damage due to incorrect battery orientation
9. Integral body design eliminates battery holder for superior comfort
10. Aircraft-grade aluminum alloy (Mil-Spec HAIII), lightweight and abrasion resistant
11. Tempered glass lens with AR coating; scratch resistant
12. Updated reflector design, coated to provide the perfect beam spot for exceptional distance illumination
13. G35: With its Extreme output, Easy interface, Far-reaching beam, and Long run time all packed into a compact body, far outperforms the competitors
Package included:
1 x Klarus G35 XHP35 HI D4 2000LM LED Flashlight
1 x O-ring
1 x Lanuard
