ledoman’s 6x XM-L Bike Light (Stock)
I finally received the giveaway from ledoman and as agreed, here’s my brief review of bike light in stock form:
The bike light came together with the DX driver, 2 silicon rings, wall charger, cable and circuit of its original battery pack, and its battery pack holder.
Here are the measurements taken on the light. A 2S2P 18650 battery case using 4x Sanyo 2600 mAh was used. The present voltage reading is 7.95 volts
| width | 56mm |
| length | 49mm |
| high | 1.28 amps |
| low | 0.48 amps |
| strobe | 0.64 amps |
Here’s the 6x XM-L beside the MagLite 4D which I earlier modded to 6x XR-E. Its heads are about the same width.
And here’s the 6x XM-L BL together with my other multi-XM-L Lights: Modified BTU Shocker, TrustFire X100, BlackShadow Terminator, 6x XM-L BL, and Modified Sky Ray King
Lux readings were taken at 11 meters (and used to compute Candela values) and here’s the result of the 6x XM-L compared to some of my bike lights and multi XM-L lights:
| Light | |
| 6x XM-L | 7.9 |
| SolarStorm X2 (mod) | 7.4 |
| SingFire SF90 | 10.3 |
| BTU Shocker (mod) | 297 |
| TrustFire X100 | 49.2 |
| BlackShadow Terminator | 57.6 |
| Sky Ray King (mod) | 25.9 |
Beam Shots of some my Multi-XML Lights were taken at a tree 60 meters away:
Black Shadow Terminator (stock)
TrustFire X100 (stock)
Sky Ray King (mod with 3x XM-L2 T6 3Bs on SinkPads
6x XM-L Bike Light (stock)
Beam Shots of my bike lights attached to my Mountain Bike were also taken:
SolarStorm X2 (mod with 2x XM-L2 T6 3Bs on direct aluminum MCPCB), my Low Beam
SingFire SF90 (stock), my High Beam
Low Beam and High Beam both on making me the brightest MTB on the road at night
6x XM-L BL - a bit floodier than the two combined but definitely needs more throw.
This 6x XM-L Bike Light, though a multi-XM-L light, is not at par with my other muli-XM-L lights. It doesn’t break away from my X-2 and SF90 either. Hopefully after the driver mod (and of course the cable and lead wire mods), this light would function to its full potential. Until then, I would say that there’s nothing special with this light in its stock form.
. There's no point in showing 100th's or more of kcd since our meters are no where near that accurate anyway.
