Acebeam E70 Mini
At the end there will be a summary for those who like only particulars. In each topic I will bold the key sentences, so it will be easier to notice what's the most important. Enjoy!
Table of Contents:
- General parameters
- Package content
- Appearance, parameters
- UI, runtime and charging
- PWM
- Waterproofness
- Light pattern, tint
- Beamshots
- Usage and my experiences
- Summary
General Parameters
LED: 3 x High CRI Nichia 519A LED with a lifespan of 50,000 hours
------- Modes -------
Ultra-Low: 12 lumens; 100 hours; 20 meters; 104 cd
Low: 60 lumens; 19 hours; 39 meters; 375 cd
Mid1: 170 lumens; 7 hours; 52 meters; 675 cd
Mid2: 380 lumens; 3 hour 15min;71 meters; 1,275 cd
High: 900 lumens~600lumens; 2min + 1 hour 55min; 102 meters; 2,625 cd
Turbo: 2000 lumens~600 lumens; 40s + 2 hours; 153 meters; 5,875 cd
Strobe: 1000 lumens; 2 hours; 112 meters; 3,150 cd
Max. output: 2,000 lumens
Max. beam distance: 153meters (787feet)
Max. runtime: 56 hours
Peak beam intensity: 5,875 cd
Size: 4.37''/111mm (Length) x 1.02''/26mm (Head Dia.) x 0.92''/23.4mm (Body Dia.)
Weight: 72g (2.53oz) without battery, 120g(4.23oz) with battery
Package content
Pretty standard content, a big fat + from me for the silica gel bag!
Flashlight itself is pretty small and compact. It can serve well as an EDC light.
More details:
- Black stainless steel bezel - I am a big fan of steel bezels in flashlights
- AR coated glass lens, and clear TIR optics - well done Acebeam, firstly for covering plastic TIR with glass, and secondly for choosing this type of optics instead of e.g. 3x OP reflector. Why? Because this way beam pattern is nicely and evenly distributed, like every EDC light should be.
- Next we have a very interesting pattern - it makes this flashlight unique
- Next we have more unique pattern! Yeeeeeey!!!
- Clip is also very stylish, with interesting screws and shapes
- I almost forgot... LED. Of course, the LED. It is important, for sure
- What about the battery tube? We saw what it looks like from the outside, let's see what it looks like from the inside
Because the flashlight has e-switch, it has to have this inner metal tube, well visible on the first picture. Blue finish gives it a nice touch
- Single, but stiff spring provides enough contact and current flow for a single 18650 cell flashlight
- All threads are smooooth and so well lubricated, I am impressed
- E-switch that I mentioned earlier has a nice click - and it is all metal. Even a switch is a piece of art here
- Last, but not least, the lanyard - standard quality, but better than nothing - and has Acebeam logo
UI, runtime, heat dissipation and charging
UI
Pretty...different. Let's say that. To turn it on, you need to double click the switch. Click and hold to change modes. Single click to turn it off. I mean, if you get used to it it feels normal, but if you have more flashlights, you have to remember to double click for on, not single click.
Runtime
I tested Mid2 brightness, which is 380lm. Why this brightness? Because it is the most common.
200 minutes, which means more than 3 hours of stable output. Very well done, Acebeam!
Charging
The flashlight itself does not have charging port, but included battery does - USB type C, and even has a small indicating LED, so you know then it's charged. You can charge it in external Li-Ion battery charger as well. Battery has discharge protection, so it discharged to 2.725V during my runtime test. Charging took 3h 19min.
Everything great and all, but there is a problem. A big problem: my cell is broken, self discharging really quick, ending up at 0 Volts is a week or two. Luckily, it is possible to charge it using its charging port. It is impossible to charge it with external charger, though.
I don't know if it is just my sample that is broken, or this is more common problem, but as you probably guessed, this cell is not very useful.
Sooo... just take any other cell, right? Wrong. This included one is very long, because it has built in charging and is button top. It is as tall as 21700 cell!
If you want to use another battery, you need to use button top one, or stick a magnet on top of the flat top cell.
PWM
I did not observe any flickering on the lowest mode. Good.
Waterproofness
I will test its waterproofness in the future
Light pattern, tint
3x Nichia 519A 5000K CRI > 90
I was impressed by its tint. It is simply amazing. 5000K looks more like 4500K, it is on the warmer side. Light is evenly distributed thanks to TIR optics. Acebeam did a great job combining this LEDs with this TIR, if you ask me.
Beamshots
ISO200, t2s, f/3.5 sunlight white balance
General picture of what the forest looks like:
Beamshots of Acebeam E70 Mini:
Shining straight ahead:
Shining under my feet:
The same pictures, but bigger:
The beam is very nice, evenly distributed, without greenish tint, and of course high CRI. Modes spacing could be better, there is too little brightness difference between modes.
What about CRI and great tint? I made a small comparison:
(there is a typo, it is 5000K, not 4500K)
Everything looks so much better, dirt, green grass and brown trees.
I like this flashlight. Why? Because it is small, has a great design, and great tint as well. But why the UI is different than in almost all other flashlights? I need to get used to it. Not a big deal, of course. What bothers me the most is its incompatibility with flat top 18650 batteries. If you want to use it, you need to add a magnet on top to make it longer.
Summary
Acebeam E70 Mini is a very good flashlight. Versatile piece of a great design. Equipped with 3x Nichia 519A 5000K high CRI LEDs, combined with clear TIR optics can output up to 2000 lumens. It can be used as a backup flashlight in a car, you can use it when hiking and in other scenarios - but with that unique design better not scratch it!
Pros:
+ Very good tint, without greenish haze
+ High CRI > 90
+ Outstanding design
Cons:
- Battery is self discharging very quickly, ending up at 0V in a week
- Not compatible with flat top 18650 cells (too short)
If you have any questions, put them below, thanks for sticking for a while :)
