1) Disclaimer
2) Introduction
3) Packaging
4) Materials, assembly, processing, finishes, anodizing
5) Specifications
6) Specifications
7) User interface
8) LEDs, light output
9) User experience and beamshots
10) Conclusions
11) Aspects positive
12) Negative aspects
13) Neutral aspects
14) Final grade
15) Bonus
1) Disclaimer
If my English is good, you can congratulate me. If my english is bad, you can blame google translate ;)
More and more often I find myself using flashlights during my excursions or in daily life, therefore I define myself as a user who has also become passionate over time.
In addition to indicating objective data and measurements, I will always try to be very clear in highlighting strengths and weaknesses, in explaining the impressions during use and what I would like to see or obtain.
All photos, info, measurements, unless otherwise indicated, are my own work. The measurements are carried out with amateur tools and methodologies, so when you read the data always consider a fair margin of error.
I do all this because I enjoy it, mine is a hobby and a pleasure, in life I do anything else, so I apologize in advance to the professionals of the sector, to the enthusiasts and to the simple users for the mistakes that surely are and will be present in mine pages.
If you notice errors, typos or have other reports to make, please let us know, I will be happy to update my pages with your reports.
2) Introduction
The flashlight was sent to me by Armytek for review.
The name of Wizard indicates a series of head flashlights declined in different form factors and with different characteristics.
The Wizard C2 Pro Max Magnet USB represents the top model of the front lineup, characterized by the classic Armytek family feeling and with outstanding specifications, functions and accessories.
3) Packaging:
The flashlight comes in a single layer hardcover, with the typical stylistic features of the brand.
On the outside of the package clear, complete and easy to read infographics with the most important information and also a QR code which refers to the official website.
The contents of the package are really rich and complete with everything:
- black plastic blister
-torch
- instruction manual (English, German, French, Russian, Finnish, Swedish, Norwegian and Polish)
-2 spare o-rings
- 21700 battery
-clip
-front elastic band
- adapter for 18650 batteries
- magnetic charging usb cable
- bike handlebar support + rubber shims
-2 sachets
4) Materials, assembly, processing, finishes, anodizing:
The flashlight is made of aeronautical aluminum characterized by a matte black finish which is defined as Premium type III hard anodizing 400HV.
Aesthetically, I find this treatment very appealing, the color is full-bodied and uniform, it avoids any type of reflection and provides excellent feedback to the touch, difficult to explain, but which I would define as almost velvety.
Using it, small marks may remain, but just pass your hand over it to make them disappear.
The metal working and the assembly are impeccable, the finishes are treated in detail, the lettering is precise, has no smudges and is symmetrical in relation to the shapes of the torch.
Bezel:
The bezel is made of steel and is mounted almost flush with the head, protruding only by 1mm.
The shape is very reminiscent of the internal bezel of some watches and I find it very pleasant, just as I find the slightly satin finish pleasant.
It doesn't have slots for a removal tool, so it's safe to assume it's press-fit and glued.
Lens:
tempered mineral glass with anti-reflection treatment.
Optic:
There is a TIR optic.
The following image is taken from the Armytek website:
Head:
It has six faces:
-Upper: flat, present the graphics with the brand and model of the torch.
-Front: the bezel, the lens, the reflector and the LED are present.
-Right side: flat.
- Left side: flat, the backlit switch is present, surrounded by a connecting and closing ring.
-Back: flat.
-Lower: there is no real lower face, because the head is one with the body.
Inside, on the positive pole there is a spring which allows for better heat dissipation and better absorption of kinetic energy during any falls.
I really appreciated the switch, because it provides visual information on the battery charge status and the flashlight temperature, it is also clearly visible in the dark and can be easily operated even with gloves.
The actuation is smooth and the tactile and audible feedback is good.
Clip:
In steel, slightly satin.
Possibility of using it in both directions so that you can fix it according to your needs.
Body:
it has a constant diameter and has three transversal processes that improve grip and offer two sections to house the clip.
Tail:
cylindrical.
The upper face is flat and characterized by an external raised ring and a central pin, both in steel, necessary for recharging.
The lateral surface is smooth, except in the upper third where there is a transverse channel.
There is a magnet that allows you to place the torch in any position in absolute safety.
The magnet is a feature that you love or hate, but in this case given the design purposes of a multifunctional torch to be used in the round, I'd say it's a good choice.
Magnetic Charging Connector:
Well made, the lower surface is in transparent dark plastic which allows the status LEDs to be viewed.
Just bring the tail of the flashlight close to the connector, so that the latter is quickly magnetized.
It is certainly a convenient additional function that allows you to recharge the battery without the need to unscrew the cap or to have ports on the head or body that could affect the waterproofing.
It allows you to combine ease of recharging and excellent impermeability.
Full charge in 5h20min.
ATTENTION:
to start the refill it is necessary to unscrew the tail by a 1/4.
Threads:
Well made, there are no burrs or manufacturing defects, the segments screw on very smoothly and easily.
There is a uniform layer of fat.
O-ring:
There is a pair of o-rings for better protection when diving in water.
The double o-ring solution is typical of diving torches and it is a pleasant surprise to find it on this model designed for other uses.
Elastic band:
Classic elastic band equipped with adjustment in the front and rear portion.
At the front we find the plastic support: the flashlight is inserted with a decisive click and remains stable even after having rotated it.
An o-ring is present to ensure greater stability and prevent the torch from disengaging after shocks or in the event of vibrations.
The support is well made but in the back I would have preferred a soft pad, so as to wear it comfortably even without a helmet or hat.
Bicycle stand:
The handlebar mount has a maximum diameter of 32.5mm, is well made, the plastics are solid and the knob to screw the nut is large enough to be used with gloves.
The flashlight fits into the holder with a decisive click, remains in place in a stable manner even after being rotated.
Also in this case there is a rubber o-ring which ensures greater safety in the event of shocks or vibrations.
I really appreciated the handlebar mount, because flood torches find their natural location right on the handlebar, perhaps combined with a throw light on the helmet.
Present rubber shims, for thinner handlebars as in the case of old bikes.
During use, the support was stable and I did not notice any vibrations in the light beam.
Battery:
The battery supplied with the Wizard is a protected 21700 branded Armytek.
There is a disclaimer on it which reads:
High-quality battery cell
Possibility To work under heavy load
Flat top battery
Safety vent with thermal cut-off protection
WARNING! Risk of fire and burns.
Do not disassemble, incinerate or heat above 100°C
Do not use battery if wrap is damaged.
From the capacity test it is observed that the recorded values deviate by about 7% compared to the declared ones.
Below is a comparison with other angle torches.
From left to right:
-Sofirn SP40 18650
-Nextorch P10 18650
-Armytek Wizard C2 Pro Max Magnet 21700
5) Specifications:
• LEDs: Cree XHP70.2
• UI: proprietary
• Material: 6061-T6 aluminum alloy
• Anodizing: Premium type III hard anodizing 400HV
• Low voltage warning: yes
• Lens type: tempered mineral glass with anti-reflection treatment
• Optics: TIR
• Switch position: head
• Memory: yes
• Below is a page of the user manual with some specifications:
The luminous flux and runtime data declared on the package are as follows:
-Turbo2 4000.00lm-->3h15min (900lm after 50sec)
-Turbo1 1300.00lm-->3h20min (900lm after 12min)
-Main3 450.00lm-->7h
-Main2 150.00lm-->21h
-Main1 45.00lm-->64h
-Firefly2 4.60lm-->14d
-Firefly1 0.35lm-->64d
-Strobe3 4000lm 10Hz 5h50min (900lm after 2 min)
-Strobe2 4000lm 1Hz 14h
-Strobe1 150lm 1Hz 90h
6) User Interface:
There is a proprietary UI that I consider well structured and with well-spaced levels.
There are essentially two main modes:
1) General mode
2) Advanced mode
Of the two, I prefer the advanced mode because it allows you to have Turbo1 and Turbo2 available at the same time.
Below is the user manual with the settings and instructions of the UI:
8) Led, light output
The light emitting diode is a CREE XHP 70.2
Measured data:
The data shows some aspects:
1) the measured output has a value quite close to the declared one.
2) the CCT has a good value we are almost in the neutral zone
3) The CRI has a value of 70 in all modes
4) the throw is slightly higher than declared
Below measured DUV and Flicker:
Turbo2
Turbo1:
Main3:
Runtime
The Wizard in Turbo2 starts very strong, with a very high light output, but the performance cut comes immediately and in a few minutes we are around 20-25% of the peak output.
The duration is in line with what was declared.
Also in Turbo1 the readings are in line with the declared data.
Light beam
The light beam is of the alluvial type, with wide diffusion of light in all directions and with a 110° spot and a 150° spill it could not be otherwise.
The light is uniform, there are no rings or artifacts and the transition between sport and spill is very soft and impossible to catch.
If you are looking for a flood torch this Wizard will not disappoint.
Some comparative shots with other flashlights.
From left to right:
1) Sofirn SP40 LH351D 4000K Hi-CRI 18650
2) NexTORCH P10 5000-5500K 18650
3) Armytek Wizard C2 PRO MAX Magnet USB XHP70.2 5500K 21700
WB 5000K
Compared to the SP40 and P10, the Wizard has a more flood and uniform beam, the transition between spot and spill is soft and gradual, so much so that the transition is not perceptible, it also has a more neutral tint with less color cast.
9) Experience of use and beamshots:
The first field test I do is the immersion one:
torch in 25cm of water for 20 minutes.
During the test, the mechanical switch was activated and the head partially rotated to change the light output.
No lens fogging and no water seepage inside.
Exam passed with flying colors and from a flashlight with IP68 certification, a pair of o-rings and with diving specifications up to 10 meters for 5 hours, I would not have expected a different result.
The flashlight is aesthetically appealing and the satin finish gives a really pleasant feedback to the touch.
The Wizard grips well and the switch is always easy to operate even with gloves.
The Armytek family feeling is clearly visible and successful, different models of the house have the same finish, same color and quality of details, aspects that give us some indication of quality control during production. Very good.
Some shots at night:
Auto WB
iso1000
1/20s
26mm f1.6
Control-Main3-Turbo1-Turbo2
Auto WB
iso1000
1/20s
26mm f1.6
Turbo 2
As you can see from the photos, the light spreads almost 180° so as to illuminate the user's feet.
In Turbo2 there is an avalanche of light, really impressive for a torch of this size, and it also ensures a decent shot, however you only have a couple of minutes at full power, because the thermal control intervenes and there is a drastic cut of current.
Turbo 1 is certainly the most interesting turbo because it has a good duration with an excellent light output.
Main 3 has excellent durability and a good power even for working easily outdoors.
I consider the levels from Main 2 down to be useful indoors or to illuminate a few meters away.
9) Conclusions
Although the Wizard has been on the market for some time, it has been updated and evolved over time, while maintaining the original philosophy, representing an excellent choice for those looking for a multifunctional all-round angular torch.
It is a flood torch with excellent light output and excellent performance and the complete kit offers all the accessories you may need.
The data collected are perfectly in line with those declared and I would say that they are excellent.
If you are looking for an all-around flashlight, to be used at work, while hiking, by bike and at home, this Wizard could be the egg of Columbus.
In conclusion I can say that I really liked it.
10) Positive aspects:
1) Build quality
2) Data in line with the declared
3) Excellent efficiency
4) UI
5) Ability to use it in many different scenarios
6) 10-year warranty
7) Full kit
8) Magnetic charging
11) Negative aspects:
1) Absence of a comfortable pad behind the front support
12) Neutral aspects:
1) Manual not in Italian.
2) I would have preferred a slightly higher CRI value, but if you are looking for a Hi-CRI model there is the version with Nichia Led.
13) Final rating:code:
8,5/10
14) Bonus:
Discount code:
By applying the coupon: SCONTO15 it is possible to receive a 15% discount during the purchase on the Armytek store.
The end.
