Imalent DM70
First things first. This review is translated from Polish by Google Translate (hope you will suffer reading), with my further corrections. But it is not perfect, hope you forgive me.
You can see original review, https://www.swiatelka.pl/viewtopic.php?t=23950
But you may ask: Dude, why would we want to see it, if it is in Polish? You may see it because I need views you can translate it directly to your own language if something here is unclear. It is always better to translate from original than from already translated.
You know, translation of the translated translation may be completely different. For example:
Lubię podróżować pociągami, mam nadzieję, że jeszcze kiedyś wybiorę się w daleką podróż (PL) -> I like traveling by train, I hope that I will go on a long journey one day (EN) -> 我喜欢坐火车旅行,我希望有一天我会继续长途旅行 (ZH) -> Me gusta viajar en tren, espero que algún día continúe viajando largas distancias. (ES) -> أحب السفر بالقطار ، وآمل أن أواصل ذات يوم السفر لمسافات طويلة. (AR) -> मला ट्रेनने प्रवास करायला आवडतं, आणि मला आशा आहे की एक दिवस लांब पल्ल्याचा प्रवास सुरू ठेवावा. (MR) -> Ninapenda kusafiri kwa gari moshi, na natumai kuendelea na safari ndefu siku moja. (SW) -> Ngiyakuthanda ukuhamba ngesitimela, futhi ngithemba ukuqhubeka nohambo olude ngolunye usuku. (ZU) -> איך ליבע טראַוואַלינג דורך באַן, און איך האָפֿן צו פאָרזעצן די לאַנג נסיעה סאַמדיי. (YI) -> I love traveling by train, and I hope to continue the long journey someday. (EN)
You see?
*ahem*
Check my review anyway!
A word of introduction on the review itself: Apparently you can't please everyone. Some prefer short ones, others medium ones, others long ones. I will try to please everyone and make a 3 in 1 review. At the end there will be a summary for those who like only particulars, in each topic I will bold the key sentences for those who read a little more, and a long waffling for everyone else. Enjoy!
I got the flashlight for review from Imalent, thanks!
Contents:
- Package content
- Appearance, parameters
- UI, runtime
- PWM
- Water resistance
- Beamshots
- Usage and my experience.
- Gallery
- Summary
The day did not promise to be good, despite the beautiful August weather. In local shopping mall card payments did not work, my downstairs neighbour decided to do a renovation and drilled from the very morning, and guys were mowing the grass around my house.
Only Imalent (or an IT specialist repairing terminals in shopping mall) could control the situation. He came to me (Imalent, not an IT specialist) in a yellow envelope.
Escaping the ubiquitous hustle and bustle, I went to a nearby park for unboxing.
5 years warranty, a kind of quality indicator.
Inside, apart from the flashlight with a 21700 cell inside was:
- case
- metal clip
- 2 spare O-rings
- leash
- micro USB cable for charging the battery
- user manual
- shoe sachet
(I didn't put everything in the picture)
Description of parts from left to right:
There was a protective film on the glass.
Unity
- Battery: Imalent 21700, 5000mAh with built-in 1A charger, 5 hours to full charge. The capacity test under 1A current showed 4800mAh. A very good result.
1 click on, 1 click off, press and hold to change modes (low - med low - med - hi). Mode memory only works for these 4 modes, without turbo, strobe or red light.
2 click turns on turbo from any position, on or off. 2 click from the turbo position turns on the strobe. High frequency, too high and in my opinion ineffective to blind someone or draw attention ... I did not measure, but maybe it is 20 Hz, while 14 Hz would be good. Well, but nobody uses it anyway.
Special features include:
From off position:
- Holding down for 2s starts the backlight of the switch in green. It will stay on for 3 hours or until off by pressing again. In my opinion, a great feature that I often use, no more looking for a button on the housing.
- 3 clicks start the red "sleeping light", which is in theory and according to the manufacturer "help to fall asleep and have a restful, refreshing sleep, relief for body and spirit. Wake up after such a heavenly night is like a new birth, will give you a new lease of life, and the darkness of everyday life goes into oblivion, giving way to dreams and lofty goals. "
Low power bulbs also glows red.
'The experiment was carried out on a group of hamsters. As a symptom that determined better or worse well-being, scientists recognized the amount of fresh water drunk. If the rodent was rested and felt well, he drank more. A tired and depressed animal practically did not approach the container with liquid.
Animals spent the night with a red, white and blue night lamp, as well as in complete darkness. It soon became apparent that the worst effect on the animals was white light. Behind him was blue. Cold lighting made the animals drowsy, refusing to take food and water.
In turn, red light and complete darkness meant that the animals were calmer. More rested, they were more likely to participate in games with other individuals, and the amount of fresh water drunk was greater than individuals from the cold light group. It also made them fall asleep more easily, and their sleep was definitely calmer and deeper. "
Another interesting thing is the study of the effects of green light on mouse sleep by Oxford University researchers. Apparently it works like red on them, except that:
"The obvious disadvantage of our study is that it was conducted on mice that are nocturnal animals. We suspect that green light can have the opposite effect on people - increase alertness and reduce drowsiness. We also think that blue light can also promote vigilance because it causes an increase in stress hormone levels, "concludes Dr. Peirson. (PAP)
It just so happens that the backlight of the switch on the DM70 is green, quite bright. So two functions: Do you want to sleep? Turn on the red light. Do not you want to sleep? Turn green. How many functions!
- 4 click is a lock against accidental activation, works until 4 clicks again. You can block the flashlight with the red light on or with the switch backlight on. The lock does not work in normal modes.
Runtime
Medium low mode, 300lm without cooling - candlelight simulator
Medium mode 1200lm with fan cooling - more everyday conditions simulator
PWM
After unboxing, I took some "pretty" pictures in the water. The flashlight is so epic even fishes jump out of the water to see it.
Test passed very well :)
Convoy M3 - turbo 4300lm
Low mode, distance to the black spot on the ground 5m
In the distance test, to the woods around 190m,
Imalent DM70. The forest is barely visible.
Light layout. The spot diameter from 70 cm is about 120 cm. On the right Convoy M3 with a 90 cm spot. If you can notice, the black dot in the center on the ceiling means ... center, each line is 15 cm apart.
In the set we get a lot of accessories, such as SACHET, or a holster or a leash (and, precisely, the attachment on the leash is at the head, a good solution for walking and lighting, when you let it hang so that it hangs on the leash, it sets at such an angle, that shines straight in the eye.
What bothered me the most was the light tint. Convoy 5000K on the left, Imalent on the right.
The only reasonable thing that comes to my mind is:
Pros:
- waterproof
- high capacity cell with charger
- good brightness levels and useful functions
- lightweight and small
- SACHET
Cons:
- cold white tint
- heats up quickly in turbo mode
- incompatible with flat "+" cells
- weak magnet
