I think it should be fine so long as the material used is average.
As for size. Well look at the small size of ur cellphone charger and some are capable of more then 25 watts. Not to mention the new slim laptop usb type c 65watt chargers.
Probably not the best charger in thebworld though jason
Driver Ur question did make me think of one myself. What sort of batteries are they using in the 4s2p configuration and i think usualy for most of the lipo batteries they suggest a charge speed of .5amps.
I know they have to give a faster charger for shorter charging times of 6 to 8 hours but if we want can we use an even slower charger?
I for one will have a day or 2 of free time before using the torch weekly so i dont mind the extra charge time if it prolongs battery life. Ideas?
Imalent uses Samsung 30Q then adds their own protection circuits. I don’t think anyone has taken this battery pack apart, but they use their own cells a lot and they are a great fit for this light.
With 4S2P configuration you have a different max charging voltage, and minimum low voltage protection value anyway. Of course to use eight protected cells increases safety, but technically it’s redundant. And Imalent is not exactly known to use top notch components…
In the meantime I’m more excited about the MF01.
This is definitely a pleasant surprise alright. Some time ago I asked HKJ to test this battery, as well as the 26650 battery. I mean, with discount code it’s like less than $8. That’s a bargain.
I actually thought about getting some for my non Imalent lights…
I haven’t seen any serious reviews of those cells, just regular folk who have tested them out and said they do an actual 15 amp. Sooo, I assume they measure properly?
All I know is that protected GAs can handle about 7 or 8 amps, and the DT70 pushes about 14000 lumens or so from four XHP70s. So it should be about 10A each. Don’t know much about electronics, but I believe the new generation PCB that can handle about 15A also has a lot less voltage sag. So I’m really eager to see HKJ’s results.
I would expect each individual cell in the pack to be unprotected.
The protection for each cell would be in the BMS board. I would expect the battery to be built like a drill pack.
Could be. I wonder who has the balls to be first to cut open the battery pack and find out.
I don’t think they currently offer the battery pack for sale. So if you cut it open, you may be stuck with a light you can’t use until you can get a replacement battery pack.
