LetterFire LF-838
Reviewer's Overall Rating: ★★★☆☆
Reviewer's Mod Host Rating: ★★★½☆
Quick Summary:
| Battery: | 4x18650 |
| Switch: | Electronic sideswitch |
| Modes: | High, medium, low + hidden strobe |
| LED Type: | Cree XM-L2 |
| Lens: | Normal glass |
| Tailstands: | Yes |
| Price Paid: | This light was provided by Gearbest.com Price: 44,25$ |
| Date Ordered: | Ordered 4th april 2014 Received 24th april 2014 |
Pros
Mine came with XM-L2 emitters (description said XM-L)
3 normal modes and hidden strobe
Centered emitters and good reflectors
Lots of flashlight for the money
Decent range (for a quad light with low current)
Cons:
Loose head. I had to turn/tighten it around 35 degree in order for it to be tightened, which makes the light look weird.
No lockout (batteries will always be drained when they are inside the light)
Weak output considering the size of the light (3,3A divided on 4 emitters)
Scratches and imperfections
Not waterproof
No charger circuit inside the flashlight (I would just avoid the charger)
Heat sinking could have been better (partially hollow pill, good enough for stock output though)
Introduction
I was approached by Gearbest to do a review on a light. I decided to go for it and chose the LetterFire LF-838 since I had not seen much info about these lights, and was curious about it. Hopefully others are too. It looked similar to Ultrafire S4 and some other lights, but Gearbest sold this light cheaper than I had seen others sell it these lights for. Less than 45$. Could it be a budget bargain? Its certainly one of the cheapest lights of its formfactor and size. Sadly Gearbest failed to my only request, so I had to pay about 33$ in VAT/Taxes for my "free review sample". No so free after all. But lets see what I got..
Unboxing:
Notice the loose charger..
Design/build quality: ★★★
Scratches on the head (from the charger?)
Its unique, and different, but I kinda like it. Its well balanced.The handle is a bit sharp on the edge, but not bad.
What I don't like is the loose head. It needs to be tightened. When its tightened it, it just looks wrong..
Some rubber to cover the charging hole on the bottom.
The button. (and some scratches on the head)
Some scratches on the handle too. (Only visible in the right light)
Mediocre tailcap threads. No lockout. Notice that piece of aluminium..
..lots of leftovers from the machine work..
Tailcap. This goes round and round when tightening it.
Contact path from circuit board to tailcap seems good when its tightened down. Its a large area.
Nicely centered XM-L2s. Nice surprise, because I though this came with XM-L emitters, like description and sales picture showed.
Glass is not AR coated like description on Gearbest webpage says (,and probably not toughened either).
One large MCPCB.
Lots of space between mcpcb and all the way down to the driver circuit. Pill is hollow, but the emitters are partially over thick aluminium. Thermal paste is used. Each emitter is given less than 1 amp, so heatsinking is adequate for the stock light. I would not have worry about increasing output in the light a bit either, but you cant make it into a proper hot-rod without some work to the head..
No O-ring in between the head and body.
Sense resistors. Its easy to bump up the current in this light.
Its also easy to ruin the electronic switch button wire if you decide to try and mod the driver without taking the driver out or being caution with the switch wire are a retard. Yeah yeah, I know. Should have taken the driver out first instead of trying to solder down there. But the retaining ring was not super easy to unscrew. I drilled two holes in it. That made it easy to unscrew and screw tightly back in.
Here is the switch:
You are not supposed to take it off the light.
UI
The light always starts on high. And you have to cycle through the tree modes in order to get to off.
High - 3,3 Amp
Medium - 1,7 Amp
Low - 0,4 amp
Its also got hidden strobe if you hold the button for about 1,5 sec in any of the three modes. Strobe is full output. When you exit strobe you exit to high-mode.
3,3 Amp dived on 4 x M-L2s is still more than 1000 lumen OTF. Enough to make any non-flashoholic seem very impressed with the light. Also, with 4x18650 and a low mode with 0,4A (when batteries are full), you will get very long runtime. Runtime is not anything special though. Its just average considering what it is.
Ill give ★★★½☆ for runtime based on amp draw. I did not perform any runtime tests.
As a flashoholic, I would say peak output is weak considering that its a decent sized quad XM-L2 light..
Mod/ increasing output:
I copper braided tailcap springs and changed to 18 awg emitter wire.
I did not care much for the drivers low output, so I tested with a bridge (literally) over one of the resistors and hoped the driver would handle it. With 4 NCR18650PF @ 4,12v emitter current was bumped up to about 9,4A on high. Medium was also 9,4A (same as high, so ruined) and low was 3,3A (way too high for a low) No good then.. No damage to driver either.
I removed the bridge and added one R100 on top of each of the two resistors (not pictured). This got me about 6,4A on high (sinking), 3,3A on medium (same as high was before), and 0,79A on low (double of stock).
The light now have pretty decent output, but low is not that low anymore.
Size comparison with other lights:
Here it is gathered with some other fatties with a handle. And a classic king for reference. (don't mind my temporary button on the LF-838. 0:) )
Lights below:
-LF-838,
-Solarstorm SP-03
- 5x XM-L2 Yupard (its actually a no name light, these go under many names)
- Another no-name cheapo XP-G thrower light
- Nage 3x XM-L2
- SRK 3x XM-L2
As you can see, compared to the Yupard and Nage, its a step up in size. And a SRK is a bit small in comparison.
Light output, tint and beamshots: ★★★☆☆ (stock)
Tint is just an typical CW tint around 6500K. Its not bad, for a CW, so cant complain.
Manufacturer rate the output to 4500 lumen.. 4500 LUMEN! Bwahahahha. At 0,825amp to each emitter? NO. About a 1000+ lumen, yes.
After the simple resistor mod it does have pretty good output though.
Here are some mouseover comparisons vs some floody rivals.
LF-838 at about 6A vs a the 5 XM-L2 Yupard (pictured above) at about 10A.
LF-838@6A vs 3x XM-L2 Nage at about 9A
LF-838 @ about 6A vs SRK at about 9A (SRK have 80+ CRI and is warmer)
All in all. Despite the "conservative" current at 6A (which could probably have been pushed a bit higher), its quite easy to see that the LF-838 have fairly good throw, but also not as wide spill as some of its more floody alternatives. Spill is more similar to a single emitter light, like a C8.
Value: ★★★½☆
This is a 44$ light. Mine came with 4x XM-L2 emitters. Its also a step up from a Quad SRK in reflector size and overall size. Its got several flaws, but at the same time, its a lot of light for the money too.
Detailed summary (numbers by me)
Power Source Options:
4x18650 batteries in parallel (means you can use less batteries)
Switch type:
Modes, PWM, drain
Modes: High, medium, low + hidden strobe
Emitter Amps stock: 3,3 – 1,7 – 0,4
Current drain in standby: 0,0117A (measured after mod I believe)
PWM: 31.62 kHZ
PWM whine: No, not audible
Memory:
No memory, always starts on high
Dimensions:
Overall Length: 165mm
Height from top of handle to bottom of the light: 98mm
Head Diameter:81mm (widest part)
Body Diameter: about 54 mm
Tailcap Diameter: 54,9mm
Reflectors Inner Diameter: 26 mm
Reflectors Outer Diameter:27,7 mm
Reflectors Depth: 22,7mm
Reflectors emitter hole Diameter:8,9 mm
Lens Diameter: 4x 27,8mm
Lens Thickness: 4x1,5mm
Emitter star diameter: Special size
Driver diameter: About 44,3 (slightly smaller than typical SRK driver)
Misc:
Waterproof: No
Anodizing: Probably HA-II «light grey» + bare aluminium
Bezel material: Aluminium
Weights :
Overall: 564g without battery
Ready to use: 757g
Conclusion: ★★★☆☆
Getting a quad light of this size with 4x XM-L2s and a driver that have 3 decent spaced modes and hidden strobe is kinda impressive considering the price. It also looks more expensive than it is IMO (unless you are close and studying the scratches). Its also refreshing to see something a bit different than the usual black or grey standard looking lights. But, I can not overlook the several flaws of this light. I give it a decent and solid 3 out of 5 stars.
Its an easy light to work on, good space inside, and easy to open. Although you might want to drill two holes in the locating ring in order to make it easy to unscrew and tighten. Its easy to double the emitter current in this light. And it seems to handle it nicely. You then get good output and a light that can handle 5-6A much better than a SRK sized light due to its physically larger size.
Making it into a hot rod requires more work with the driver (rebuild or replacement) plus work in the the head. And you might want to look into improving the head angle too, for better looks. And maybe the the lockout if it bothers you.
All, in all. A fairly nice mod host.
Ill keep mine lightly modded for now, and then Ill see if it take it further some time in the future.
