I bought the NAGE 6xXM-L, I bought it out of curiosity and also because I wanted a flashlight with 26650 in parallel without spending much.
The torch is cheap but, in my opinion, has a few weak points, and once remedied can go on well and give a lot of satisfaction.
_
removed the crown of the head, which has an O-ring, comes off the glass from 3mm thick and then the plate that holds the six parables that are retained on the plate of black rubber.
The six LEDs are on a single aluminum plate that also contains the electrical connections, the dissipation is very good. The plate is integral with the head of the torch, I could not move it.
The weak points are two:
- The thread is short and the pitch is small.
- The springs, to the negative, are too strong, to screw the battery holder to the body must exert a pressure of more than 10 kilograms.
For the thread: I wrapped the cloth plasticized adhesive tape to add a thickness. Screwed now well, in a soft but solid
I have also reduced the strength of the springs softening three wires (for each spring ) with a small flame.
before modifications:
after modifications:
This is the tape that I used:
_
The Nage weight (with batteries) over 870grams.
The handle is removed without difficulty and is perfectly aligned with the base.
After these little but important changes to the Nage satisfy me. As light intensity is comparable to the Trustfire TR-J12 5Leds. When I have time I take pictures outdoors.
_
The power up sequence is:
on one LED, three LEDs, six LEDs, strobe, SOS; off. At any level if you hold three seconds, the flashlight turns off.
_
The handle is perfectly aligned with the base of the flashlight.
I do not know the use of the jack, I try to understand the next few days.
Added the Beamshot 17/09/2013
The front wall is 23 meters. — 2sec f:5,6
Control:
Low:
Mid:
Hi:
current draw
Hi: 4,03 Amp (after twenty seconds)
Mid: 2,77 Amp
Low: 1,36 Amp
_
I made a short video (53 sec). It’s not perfect because I was on the roof of my house. (it is better to see it directly on youtube)
_
_
