Hello
I will do a deep review of this light provided by ENOGEAR seller and it seems very interesting !
Enogear link for purchase :
http://www.enogear.com/pd.jsp?id=22#\_pp=0_455_5
Group buy
Description:
CREE XHP70 Emitter ; Cool white 6500K , Neutral white 4800K
maximum output of 3600 lumens; Powered by single 26650/18650 battery.
Tactical forward switch for momentary on/off + side switch for mode-changing.
10mm thick copper pill stamps into the head to enhance the heatsinking ability.
With battery Power indicator
Dimension: 161mm length x 48mm head diameter x 37mm body diameter
Netweight: 350 gram
Stainless Steel bezel
Brightness and Runtime
modes Turbo (4.8A) High (2.2A) Mid (1.2A) Low(0.5A) Ultra Low(10ma)
brightness 3600 Lm 2000 Lm 1200 Lm 600 Lm 7 Lm
Runtime 75 mins 90 mins 180 mins 600 mins 300 hrs
Range 350 meters 260 meters 200 meters
145 meters /
User Interface
Dual Switch Design—-Tail switch controls on/off , half press for momentary on/off; Side switch controls mode-changes. Double click gets into Turbo mode directly.
My review:
Output (ceiling bounce test)
I did a comparaison with haikelite DT70 and my others lights
Turbo is something like 3000lm (spec 3300)
High is more like 1500-1600 (spec 2000)
Moonlight is not working on my sample
Color:
my neutral white is just fantastic
you can see the picture from left to right
haikelite SC02 MTG2 / Nightwatch / astrolux MF01 / haikelite DT70
UI:
Simple UI, tail switch ON/OFF, side switch cycle from OFF, low, mid, high
Double clic get you to turbo mode
Long press get you to moonlight mode
Output runtime VS temp:
Woua i’m impressed with the output it is thermal regulated and turbo last 2 to 3min then it just step by step to get to the high output within 5min…
Temp rise up tp 47°C on fins and 36-37°C on battery tube. It does confirm the graph from the manufacturer :
Beamshots :
16meters:
25meters
42meters
Pro:
Very compact
Good machining quality
Like the SS Bezel
Like the tail switch to secure the OFF state
Cons:
No spare oring (because of sample for review, comercial comes with oring spare)
