Review : NITEYE MSC10
From Flashlight’s Military Series Niteye (MS)
Purchased in http://www.doingoutdoor.com/ 29/01/2013.
Price: 58,99$ - 2$ coupon = 56,99 $
Battery 1xcr123a
Led Type XM-L U2
3 Modes Strobo / Preset (ramping) 8-150 lúm. / Turbo 280 lúm.
Low battery measuring
Voltage input: 2-3.2 V, I did not try it with rechargeable batteries, (there are good prices on the web of cr123a primary)
Comes in cardboard box quality, with a set of O-rings and instructions in English and Chinese, that’s all.
The anodizing is great quality, the walls are thick.
The weight is 65 grams without battery, the flashlight is not light, but is very comfortable in the hand.
Size measurement: 87 mm x 24 mm
Comparing with other EDC, to get idea of the size;
Labels on the flashlight body;
Led XM-L U2. Perfectly centered.
The tint is very nice, is neutral - kinda cool, but not too much. The reflector is not too deep, it’s rugged, thanks to those 280 lumens give us enough throw to perfectly as EDC, and also for outdoor (as an emergency).
The battery fits perfectly, no rattle.
3 Parts ; Head , Body and Tail.
In the head there lanes facilitate heat dissipation.
Reverse polarity protection.
The knurling is not strong, but it is enough.
User Interface:
Tail Magnetic Ring with 4 positions (I’d like to see a mark to the selected mode).Strobe - Off (green or red indicator tail-cap for 2 seconds according to battery voltage) - Preselected mode (ramp from 8 to 150 lumens)- Turbo 280 lumens. The rotation of the magnetic ring is approximately 120 degrees.
Electrical switch in the tail. It has dual function, with ring in position off, press switch 2 seconds and you can see if the battery is low (red) or ok (green). With magnetic ring in position strobe, preset or turbo press shortly switch and the flashlight is on or off in the selected mode. In the Preset position, a long press of the switch and start the ramp (between low and high about 4 seconds). The ramp stops to arrive at 8 lumens or 150 lumens. The selected power is stored.
The interface is easy, but I prefer the magnetic ring on the head. Still very usable.
Perfomance; Turbo 1.880 mA (nitecore cr123a)/ 280 Lumens
RUNTIME TEST
For the runtime I use a Nitecore primary CR123A battery completely new. 3.28 V measured before starting the test.
The flashlight do what he promised. After 60 minutes has only dropped 10% intensity (1360 Lux). It is a highly regulated.
Considering that the maximum 1-minute touches to 1500 lux for 67 minutes provides 50%. So will assign that value to the runtime on high “67 Minutes”. Drops rapidly from 63 minutes to process the test 80 minutes at 230 lux, still usable.
Flashlight in hand has not overheated when I left 10 minutes without grabbing, the temperature rises rapidly, but dissipates in hand well.
I’ve checked the low battery warning from the 45th minute, in the 68th minute with only 650 lux, gets first red. (turned off the flashlight 2 seconds every 3 minutes for testing).
For the preparation of the table data I have used lux at 1 meter measurements obtained every minute for 80 minutes.
An hour and a quarter off the flashlight, the battery has recovered to 2.5V and low battery warning turns green again, down to 2.4V as redials red. So between 2.4-2.5V is when you start dialing low battery (always turn off the flashlight to see the display).
Official data:
280 lum.————————— 1 hour
8-150 lum ———————— 10 hours
280 lúmenes ………………Strobo
Beam distance ————————–133 meters
Intensity ——————————- 4400 cand.
Waterproof ——————————IPX-8
Impact Resistant ——————— 1 meter
68 gr.
88 x24 mm
I Like;
- Perfect taistand
- Low Battery Indicator
- Finishes, anodized, …. High quality materials and finishes
- New interface, very “tactical”. Quick access to high mode, low or strobe.
I do not Like:
- Magnetic-Ring unmarked
- No clip, no hole for a lanyard, and rolls on smooth surface. It is a serious error and easy to repair. I do not understand. And for me the flashlight makes losing a point in the final score, sometimes the little things prevent something perfect.
For these reasons I can only give it 4 stars, but in other respects is outstanding.
Rate
Would I buy it?, Knowing what I know now, I certainly would buy it, but again, it’s a bit heavy for its size, and rolls easily. CR123A Not a first choice, but if you like this type of flashlights, This should be on the wish list. I love it
Compared with all my CR123A.
(My apologies for using google translate)
