Purchased after reading this post:
https://budgetlightforum.com/t/-/1532?page=240#comment-699045
...via ebay: http://www.ebay.com/itm/281399892000 - $6.05 today, was about .20 higher when I bought mine.
Interesting single-cell AA/14500 light with some thought in the design. Hampered by small reflector diameter relative to the diameter of the host.
Here, alongside my FastTech C20 (single 18650) TrustFire F20 (single 14500/AA) and an unprotected 18650 cell:
It is only slightly larger than the Trustfire light, but somehow feels significantly larger in the hand.
The bezel is aluminum and has sharp crenelations, but the soft material could be Foyzeled down with some sandpaper or a file easily. The big problem is the relatively small reflector diameter relative to the thickness of the light. As seen in the photo, the reflector is only 15mm in diameter, and extends only to the inner ID of the GITD O-Ring. The overall diameter of the light is 22mm. The bezel has a recessed groove on the ID to seat the O-Ring, while the glass(!) lens is pressed in place between the edge of the plastic reflector and O-ring.
Surprisingly, this light has a proper threaded-in pill with a solid (albeit, thin) base. The driver is a 17mm three-mode boost that will allow operation from 14500 cells, and AA, although at reduced brightness. Another suprise is that the light has a no-mode-memory driver, which always starts on high; this is much better than the common next-mode-memory driver found on many lights. The factory emitter is a basic XP-E on a 16mm board. The standard PCB and driver sizes allow for easy mods, so this light has some decent host/mod potential. The included aluminum PCB is a thinner style, so you would have trouble fitting a thicker PCB in without further modification. The pill was also assembled without any heat-sink compound. The pill is deep enough that you could sand it down to fit a deeper reflector or thicker PCB while still retaining room for the driver.
The red ring on the tailcap is just a threaded retaining ring for the pocket clip; this clip is one of the strong points on this lamp, is very well made, and removable if needed.
The tailcap on this light is interestingly assembled, but can be fully disassembled for repair, if needed:
Lots of pieces for such a budget-priced AA light:
The light has some decent mod potential due to the solid pill and use of standard PCB/driver sizes. The biggest drawback (that I see) is the small reflector diameter. I'm looking for a decent option to replace the current 8mm x 15mm factory reflector. The design would allow the use of a reflector a couple of mm larger in both directions. If I could locate such a reflector, I could drop an XP-L, XM-L, or XP-G type of emitter and get a decent EDC light.
(using IMGUR for picture hosting, as my workplace is blocking Photobucket. I hope this goes well.)
