The JM26 is another of Shadow's recent releases. It can be considered the fraternal twin of the SL3 in that it bears the same looks in a slightly longer form factor owing to the deeper reflector:
Therein the reflector lies the main difference in that the JM26 features a single emitter that while outputting roughly half of the SL3, bests it in throw. By how much you ask? Let's find out...
MFG SPECS
• Cree XM-L U2 LED with lifespan of 50,000 hours, Maximum output of 800 lumens.
• Digitally regulated output, maintains constant brightness.
• Low voltage warning flash.
• Side switch on body of flashlight for on/off operation (Hold button for more than 1 second). Hold switch further to enable mode switching between 3 light modes (High, Medium, Low) and 1 strobe mode accessed via quick double click
(Strobe can be accessed regardless if the flashlight is on or off) • Smooth Aluminum reflector.
• Long throw flashlight with illumination past 300 meters. (36,000 lux @ 1m) • Made of durable 6061 aluminum alloy.
• CNC manufactured.
• Stainless steel bezel.
• Toughened ultra-clear glass lens.
• Premium Hard Anodized Type III grey finish. Scratch resistant and anti-abrasive.
• IPX-8 waterproof.
• 142mm(Length)x32mm(Body)x63.5mm(Head).
• 220g weight (batteries not included).
• Powered by Li-ion battery: 1x26650.
• Test run(Powered by 1x26650,capacity of 3.7V/4000mAh,Kingcell brand in China):
High mode: 1.6 hrs,800lm.
Med. mode: 4.7 hrs.
Low mode: over 35 hrs.
• Versatility of exploration,searching,camping,hunting,cycling,patr ol,outworks etc.
• Included accessories: lanyard/O rings/glass lens.
PACKAGING / CONTENTS
The JM26 arrived in generic Eco packaging with decent foam cushioning:
Accessories included are:
- 2 x small o-ring's
- lanyard
- spare lens (& corresponding o-ring)
CONDENSED VIDEO SUMMARY
Here is a complete video summary of the JM26:
http://www.youtube.com/embed/fN7Cv0bopi0
DESIGN & FEATURES
The JM26 features a removable flat SS bezel:
There is no AR coating on the lens.
When removed, the lens and emitter should be easily replaceable for upgrades. The reflector is a nice hunk of Al and while it's a nice size in diameter (56.2mm/2.2"), it's relatively shallow (32mm/1.26") thus gives the JM26 a nice balance between flood and throw. It's centered around the emitter by the black plastic disc (to right of o-ring in top left pic):
Speaking of the o-ring, it's a little tricky to mount around the reflector and took some patience and deft maneuvering to align it properly. One slip and the reflector can be marred so best to leave this alone if one has limited adroitness in their digits.
As can be seen in this close-up, there is ample room to work on swapping out the emitter board to a higher output bin or perhaps different tint to suit one's needs:
The aforementioned black centering disc simply goes around the base of the emitter board.
There are many machined grooves and design motifs that subjectively I find aesthetically pleasing, additionally, the grooves around the head function as heat fins:
As with their other lights that feature a side-switch, it's adorned with a SS ring (it might actually be Al since it failed the magnet test). The collar that the side-switch rests in features alternating textured curved and flat sides.
With the exception of a "plug" at the base (more later), the battery tube is milled as a single piece (that is, there is no tailcap) and again features a blend of symmetrical machined grooves and design motifs that I feel works well:
There are two flat surfaces where the model and company name are laser etched.
The base of the tube is finished off with milled grooves that run parallel with the tube:
Carrying on the "milled as a single piece" theme, the lanyard holder holes are drilled directly into the base. The base is nice and flat so allows for pretty stable tailstanding. The non-anodized piece is actually a "plug" that is non-removable. It was explained to me that this was done for aesthetic purposes but I would've preferred that they had simply removed the anodizing rather than incorporating a separate piece but ultimately, it shouldn't compromise the water resistance.
There is a brass nodule at the base of the head, it's recessed ever so slightly so as to require a magnet when using flat-top cells:
There is however a large spring in the base of the tube.
There is an optional 18650 sleeve that allows the use of said cells:
[pic]
SIZE / HANDLING
L to R: SHADOW SL3 | SHADOW JM26 | SHADOW JM07-Pro | SHADOW JM07| Elektro Lumens Big Bruiser
The above is a quick shot of the JM26 compared with other single-cell 26650-sized lights. It's got a nice stout form-factor but isn't exactly pocketable except perhaps in cargo pants.
Overall the diameter of the JM26 fits very nicely in my medium-sized hands. With an overhand grip, the side-switch can be activated by one's pinkie:
FIT & FINISH
The JM26 is roughly on par with the rest of their newer releases; that is to say that while it's not bad and improved from the very early JM07 I have, it could still make do with some additional refinement. Starting with the anodized finishing, the body is a different hue vs. the head:
NOTE: Flash intentionally used to highlight shading differences.
Overall, the anodizing has been applied well with none missing in the crevices, texturing or around edges:
The SS bezel threads on flush and the laser engravings are also nice and sharp with no blotchiness:
While the threads are not square-cut, they came decently greased and proved to be trouble-free during use.
Overall, the JM26 is a solidly constructed light that should stand up to a fair amount of abuse especially in consideration of its two piece build. If there is but one nitpick I can fault it with is the glue overrun from the switch:
There is also the matter of some minor blotches in the anodizing that I can't quite capture in pics but is there if one is intently looking for it.
UI
The UI on the JM26 is very straightforward. To turn it on, depress and hold on the side-switch for at least two seconds. Once on, each depress of the side-switch will cycle through the three output levels: H > M > L. Strobe can be activated at any time with the light on or off by depressing the switch twice; this can also be used as a work-around to the two second-delay by activating the strobe first and then depressing the switch one more time to exit out of it and activating H. To shut off the light, hold the side-switch again for two seconds or just quickly lock-out the light and twist the tube back on.
As with the rest of their lights with a side-switch, it is fairly easy to accidentally activate the strobe while cycling through the output levels since the spacing isn't tight enough. There is no memory so it'll always come on in H, to expound; if you last used the light in L and then either shut-off the light or change the batteries, the light will always come on in H. There is no electronic lock-out but the light can be physically locked-out since the threads are anodized.
BEAMSHOTS
Indoors (5m)
High
Med
Low
For details of the above indoor shots and comparo vs. many other lights, please check Epic Indoor Shots Trilogy
RUNTIME & OUTPUT
The relevant battery stats are provided above each runtime graph along with:
- Voltage of the battery at the start and end of the test
- Current draw
- Actual runtime using ANSI FL1 (first in HR and then in M so for the RL3100 on High, read this as 1.6hrs or 98min)
- As of May 2012: Lumens measured on my PVC LMD @ 30 seconds
- Also for High, captured the temperature: ambient, the head/fins at start and the max it reached (fan was used for all bats)
Max output measured @ 30 seconds was 839lms w/a KK 26650E (note: although I calibrate my PVC LMD before each runtime/lumens testing, the ambient temp will also cause a slight deviation in readings).
After an initial slight dip, the JM26 runs pretty well regulated until it can no longer sustain the current draw and starts a gradual decrease. Not surprisingly, the KK with the highest capacity of the batteries tested takes home the runtime crown yielding 98 minutes before the LVW (Low Voltage Warning) kicked in. As with the SL3 and JM07, the JM26 is capable of running on a single 18650 cell utilizing an optional spacer (must be able to handle 3A draw sustained). The RL3400 isn't terribly far behind the KK, producing a total runtime of 83min but with a overall lower output once it drops out of regulation. Despite not having a step down, the JM26 doesn't get all that hot.
Here in order for each cell are measurements for:
* regulation; time in minutes the JM26 is able to stay in regulation before output starts dropping
* medium; average lms in first minute + current draw and calculated runtime
* low; average lms in first minute + current draw and calculated runtime
* stand-by; since the JM26 utilizes an electronic switch, the current draw + calculated time* before cell is drained
* does not take into consideration the cell's self-discharge rate so real-life times would be lower
CONCLUSION
The JM26 is a very nice light and I'm quite taken with it. Both it and its fraternal twin, the SL3, feature very solid builds and should stand up to some hard use. Subjectively, I really like the styling; some may find that all the machined grooves lead to a busy look but it's got an industrial design to it. I feel Shadow is moving in the right direction with their recent releases but while the overall fit and finish is pretty good, I'd like to see them bump it up a notch. They seem to have done that between the first JM07 release and this batch so I'm optimistic they'll do it again with their future models. In particular, I'd like to see them revise the UI but for now though, here are my thoughts:
turboBB-licious
- optional sleeve allows use of 18650 cells thus increasing flexibility of fuel source
- anodized threads allow physical lock-out
- decently regulated even on 18650's (albeit with reduced runtime)
- two-piece setup feels very solid
turboBB-cautious
- brass nodule in head slightly recessed requiring use of magnet with flat-top cells
- some blotches in the anodization
- quick cycling of output levels can accidentally trigger strobe
turboBB-wishes
- holster
- spring in place of the brass nodule positive contact point
- revised driver that would allow 2-cell operation with extension tube
- reduce time required to turn on light from two-seconds down to one
- tighten-up timing required to activate strobe
- electronic lock-out feature
- AR coated lens
- more output levels implemented via different UI (a la Zebralight)
JM26 GALLERY
JM26 provided by sbflashlights.com for review.
